CC3200 在使用文件读写时,当WIFI没有连接成功的时候会一直处于_SlNonOsMainLoopTask中
板子已经通过smartLink配置成功
// Device connect ap
deviceConnectWlan();
DeviceDefaultConfig();
while (1)
    _SlNonOsMainLoopTask();
如果我先连接WIFI ,在进行读写文件,就没问题;
如果我先读写文件, 在调用fs_open之后,就会一直处于_SlNonOsMainLoopTask函数中;
void main()
    // Board Initialization
    BoardInit();
    // Initialize the uDMA
    UDMAInit();
    // Configure the pinmux settings for the peripherals exercised
    PinMuxConfig();
    // Configuring UART
    InitTerm();
    // Display banner
    DisplayBanner(APPLICATION_NAME);
	//deviceConnectWlan();
    while (1)
// Close the Doxygen group.
int deviceConnectWlan( void )
      long lRetVal = -1;
      InitializeAppVariables();
    //lRetVal = ConfigureSimpleLinkToDefaultState();
    if(lRetVal < 0)
      if (DEVICE_NOT_IN_STATION_MODE == lRetVal)
         UART_PRINT("Failed to configure the device in its default state \n\r");
     // ASSERT_ON_ERROR(DEVICE_DEFAULT_ERROR);
    UART_PRINT("Device is configured in default state \n\r");
    lRetVal = sl_Start(0, 0, 0);
    if (lRetVal < 0)
        UART_PRINT("Failed to start the device \n\r");
        ASSERT_ON_ERROR(DEVICE_START_ERROR);
    UART_PRINT("Device started as STATION \n\r");
    UART_PRINT("Connecting to AP: %s ...\r\n",SSID_NAME);
    //lRetVal = WlanConnect();
    if(lRetVal < 0)
        UART_PRINT("Connection to AP failed \n\r");
        ASSERT_ON_ERROR(DEVICE_CONNECT_ERROR);
		// Wait for WLAN Event
    while((!IS_CONNECTED(g_ulStatus)) || (!IS_IP_ACQUIRED(g_ulStatus)))
    UART_PRINT("Connected to AP: %s \n\r",SSID_NAME);
    UART_PRINT("Device IP: %d.%d.%d.%d\n\r\n\r",
                      SL_IPV4_BYTE(g_ulIpAddr,3),
                      SL_IPV4_BYTE(g_ulIpAddr,2),
                      SL_IPV4_BYTE(g_ulIpAddr,1),
                      SL_IPV4_BYTE(g_ulIpAddr,0));
	return SUCCESS;
long DeviceDefaultConfig( void )
  	long lRetVal = -1;
    //  create a user file
    lRetVal = sl_FsOpen((unsigned char *)USER_FILE_NAME,
                FS_MODE_OPEN_CREATE(65536, \
                          _FS_FILE_OPEN_FLAG_COMMIT|_FS_FILE_PUBLIC_WRITE),
                        NULL,
                        lFileHandle);
    if(lRetVal < 0)
        // File may already be created
        lRetVal = sl_FsClose(*lFileHandle, 0, 0, 0);
        ASSERT_ON_ERROR(lRetVal);
    else
        // close the user file
        if (SL_RET_CODE_OK != lRetVal)
            ASSERT_ON_ERROR(FILE_CLOSE_ERROR);
	Report("Cread file success.\r\n");
                        FS_MODE_OPEN_READ,
                        NULL,
                        lFileHandle);
    if(lRetVal < 0)
        ASSERT_ON_ERROR(FILE_OPEN_WRITE_FAILED);
	Report("open read is success.\r\n");
	return SUCCESS;
代码如下:
