Part Number: CC3235MODASF
Other Parts Discussed in Thread: CC3235SF
Hi,
At first glance, the HTTP Get Request flow looks fine. In general, error -111 means that the server is either not listening on the socket or is actively refusing the connection made by the CC3235SF. Can you ensure that the server is listening and allowing connections?
I see that the hostname you are trying to connect to is some IP address referenced as gStationIp. Are you trying to send a GET request to a station?
Thanks.
