定时器事件捕获模式下如何触发溢出中断
定时器事件捕获模式下定时器为24位,事件可以触发中断,但不能触发溢出中断
要捕获长间隔信号24位计时不够,想用溢出中断延伸,但溢出不能触发.
int main()
// Initialize Board configurations
BoardInit();
// Pinmux for UART
PinMuxConfig();
// Configuring UART
InitTerm();
// Display Application Banner
DisplayBanner(APP_NAME);
// Enable pull down
MAP_PinConfigSet(PIN_05,PIN_TYPE_STD_PD,PIN_STRENGTH_6MA);
// Register timer interrupt hander
MAP_TimerIntRegister(TIMERA2_BASE,TIMER_A,Timer2AIntHandler);
// Configure the timer in edge count mode
MAP_TimerConfigure(TIMERA2_BASE, (TIMER_CFG_SPLIT_PAIR | TIMER_CFG_A_CAP_TIME_UP));
// Set the detection edge
MAP_TimerControlEvent(TIMERA2_BASE,TIMER_A,TIMER_EVENT_POS_EDGE);
// Set the reload value
MAP_TimerPrescaleSet(TIMERA2_BASE,TIMER_A,0Xff);
// Enable capture event interrupt
MAP_TimerIntEnable(TIMERA2_BASE,TIMER_CAPA_EVENT|TIMER_TIMA_TIMEOUT ); //定时器中断使能捕获和溢出
// Enable Timer
MAP_TimerEnable(TIMERA2_BASE,TIMER_A);
while(1)
// Report the calculate frequency
// Report("Frequency : %d Hz\n\n\r",g_ulFreq);
// Delay loop
MAP_UtilsDelay(80000000/5);
