Part Number: CC3501E
CC3501ETIARSHR 烧录不了,对调芯片,把能烧录的CC3501ETIARSHR换上去能烧录,不能烧录的换到另外一个板子,还是不能烧录。
如果现象跟随芯片并且芯片是从TI官网购买,可以联系客服中心做失效分析。
好的,关于这个烧录不了的log,能帮忙看看具体是什么问题吗?报-1141错误代码。
2026-09-04 18:42:51,071: Reading binary file: d:\test\programming\mainchip\bin\windbound\p\programming_instructions_image.sign.bin
2026-09-04 18:42:51,071: Loading binary using bulk function
2026-09-04 18:42:51,071: Loading ...
2026-09-04 18:42:52,731: Download process failed.
Error message: Last operation <function PyXds110._secap_bulk_write at 0x000001BC068DF130> return error code -1141 stopping process
2026-09-04 18:42:52,731: Failed loading binary with error code: -1141
