CC3100的SPI使用DMA问题
Other Parts Discussed in Thread: CC3100
看了移植文档,如果系统支持DMA,使用MDA会更好。可是DMA一般用于定长数据传输,CC3100的SPI传输不单是数据,还有配置什么的,这些数据的长度都不一,那怎么用DMA,大家有什么好的建议吗?
If your system has DMA you should consider to use it in order to increase the utilization
of the communication channel
If you have enough memory resources you should consider using a buffer to increase the
efficiency of the write operation
