测试代码
static int PingTest(unsigned long ulIpAddr)
signed long lRetVal = -1;
SlPingStartCommand_t PingParams;
SlPingReport_t PingReport;
PingParams.PingIntervalTime = 1000;
PingParams.PingSize = 20;
PingParams.PingRequestTimeout = 3000;
PingParams.TotalNumberOfAttempts = 3;
PingParams.Flags = 0;
PingParams.Ip = ulIpAddr;
UART_PRINT("Running Ping Test\n\r");
/* Check for LAN connection */
lRetVal = sl_NetAppPingStart((SlPingStartCommand_t*)&PingParams, SL_AF_INET,
(SlPingReport_t*)&PingReport, NULL);
ASSERT_ON_ERROR(lRetVal);
g_ulPingPacketsRecv = PingReport.PacketsReceived;
if (g_ulPingPacketsRecv > 0 && g_ulPingPacketsRecv <= 3)
UART_PRINT("\r\n115.159.226.240 Ping Info:\r\n");
UART_PRINT(" DataPackets: Sent %d,Received %d,Lose %d\r\n",PingReport.PacketsSent,PingReport.PacketsReceived,PingReport.PacketsSent-PingReport.PacketsReceived);
UART_PRINT("RoundTime Info(ms):\r\n");
UART_PRINT(" MinRoundTime %dms,MaxRoundTime %dms,AvgRoundTime %dms,TestTime %dms\r\n\r\n",
PingReport.MinRoundTime,
PingReport.MaxRoundTime,
PingReport.AvgRoundTime,
PingReport.TestTime);
else
// Problem with LAN connection
ASSERT_ON_ERROR(LAN_CONNECTION_FAILED);
return SUCCESS;
打印信息
DataPackets: Sent 3,Received 3,Lose 0
RoundTime Info(ms):
MinRoundTime 155ms,MaxRoundTime 257ms,AvgRoundTime 142ms,TestTime 12000ms
