Sample projects can be imported into CSS6 and build/run without problem with default TI compile toolchain, while I need to switch to GNU compile tool since one lib I used contains GNU assemble files and don't want to rewrite with TI assemble, while during the switch, seams all configs are empty, tried to config all include/lib paths and still see other errors when link, eager to know if TI already has some guide on this. thanks for any hint.
