Other Parts Discussed in Thread: CC3200
大家好!
我现在的项目,需要通过CC3200接入到网络传输数据,用HTTPPostMethod 的方法提交数据后,出现一定概率的SimpleLinkSockEventHandler 回调函数,发送失败,而且一旦出现失败,会连续失败,需要重启一下CC3200才能解决。这种情况大家有遇到过吗?
void SimpleLinkSockEventHandler(SlSockEvent_t *pSock)
// This application doesn't work w/ socket - Events are not expected
switch( pSock->Event )
case SL_SOCKET_TX_FAILED_EVENT:
switch( pSock->socketAsyncEvent.SockTxFailData.status )
case SL_ECLOSE:
UART_PRINT("[SOCK ERROR] - close socket (%d) operation "
"failed to transmit all queued packets\n\n",
pSock->socketAsyncEvent.SockAsyncData.sd);
break;
default:
UART_PRINT("[SOCK ERROR] - TX FAILED : socket %d , reason"
"(%d) \n\n",
pSock->socketAsyncEvent.SockAsyncData.sd,
pSock->socketAsyncEvent.SockTxFailData.status);
break;
default:
UART_PRINT("[SOCK EVENT] - Unexpected Event [%x0x]\n\n",pSock->Event);
