cc3200延时函数
Other Parts Discussed in Thread: CC3200
工程师您好!我想知道MAP_UtilsDelay这个函数具体定义在哪里
  • 编译后,选择这个函数,点右键,有个定位到这个函数的定义。就找到了。
  • MAP_UtilsDelay(80000);    for delay about 0.5sec
     < CC3200: Delay in seconds/msec/microsecond >
    In http: processors.wiki.ti.com/index.php/CC32xx_Power_Management_Framework, it said:
    • Clock tick at 80 Mhz.
    So MAP_Utilsdelay(8000000)   may delay ~0.3sec or ~0.5sec as you mean.
    But in oob example, Why MAP_UtilsDelay(8000000) is mean ~10sec?
      Wait ~10 sec to check if connection to specifed AP succeeds
    while(!(IS_CONNECTED(g_ulStatus)) || !(IS_IP_ACQUIRED(g_ulStatus)))
    #ifndef SL_PLATFORM_MULTI_THREADED
    _SlNonOsMainLoopTask();
    #endif
    MAP_UtilsDelay(8000000);
    if(g_usConnectIndex >= usConnTimeout)
    break;
    g_usConnectIndex++;
    "Clock tick at 80 Mhz" is correct information.
    Further, in the OOB example you will find that there is a retry count and then timeout. So it means that the loop will execute usConnTimeout number of times. Hence the time it takes is actually -  (usConnTimeout * MAP_UtilsDelay(8000000)). This may have been approximated and mentioned in the comment.
    I am using following macro. Its not exact but close enough (at least for my application)
    #define SEC_TO_LOOP(x)        ((80000000/5)*x)
