CC3200 I2C 引脚 更改 P01、P02
请教一下TI的工程师, 我想把I2C的引脚设置成P03、P04, 我是这样修改的:
// Enable Peripheral Clocks
PRCMPeripheralClkEnable(PRCM_GPIOA1, PRCM_RUN_MODE_CLK);
// Configure PIN_01 for GPIO Input
PinTypeGPIO(PIN_01, PIN_MODE_0, false);
GPIODirModeSet(GPIOA1_BASE, 0x4, GPIO_DIR_MODE_IN);
// Configure PIN_02 for GPIO Input
PinTypeGPIO(PIN_02, PIN_MODE_0, false);
GPIODirModeSet(GPIOA1_BASE, 0x8, GPIO_DIR_MODE_IN);
// Configure PIN_03 for I2C0 I2C_SCL
MAP_PinTypeI2C(PIN_03, PIN_MODE_5);
// Configure PIN_04 for I2C0 I2C_SDA
MAP_PinTypeI2C(PIN_04, PIN_MODE_5);
但读写时提示 错误,I2C_MASTER_ERR_ARB_LOST。
请问这是什么原因?
  • 通过Pin MUX工具直接产生硬件I2C的代码如下:
    // pin_mux_config.h
    // configure the device pins for different signals
    // Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/
    // Redistribution and use in source and binary forms, with or without
    // modification, are permitted provided that the following conditions
    // are met:
    // Redistributions of source code must retain the above copyright
    // notice, this list of conditions and the following disclaimer.
    // Redistributions in binary form must reproduce the above copyright
    // notice, this list of conditions and the following disclaimer in the
    // documentation and/or other materials provided with the
    // distribution.
    // Neither the name of Texas Instruments Incorporated nor the names of
    // its contributors may be used to endorse or promote products derived
    // from this software without specific prior written permission.
    // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    // This file was automatically generated on 1/13/2017 at 1:34:40 PM
    // by TI PinMux version
    #ifndef __PIN_MUX_CONFIG_H__
    #define __PIN_MUX_CONFIG_H__
    extern void PinMuxConfig(void);
    #endif // __PIN_MUX_CONFIG_H__
    // pin_mux_config.c
    // are met:
    // distribution.
    // This file was automatically generated on 1/13/2017 at 1:34:31 PM
    #include "pin_mux_config.h"
    #include "hw_types.h"
    #include "hw_memmap.h"
    #include "hw_gpio.h"
    #include "pin.h"
    #include "gpio.h"
    #include "prcm.h"
    PRCMPeripheralClkEnable(PRCM_I2CA0, PRCM_RUN_MODE_CLK);
  • 我是通过Pin MUX工具 产生的, 同时也把P01、P02 作为了一个普通的GPIO口。
    最终还是不行。
    求解答
  • 同时也把P01、P02 作为了一个普通的GPIO口? 你用P01和P02即做I2C又做普通GPIO? 同一个时间只能配置成一种模式,而且注意I2C需要大约10k的上拉电阻支持。
