CC3200 SDHOST_FATFS+DMA
TI工作人员,
我想我需要你们的帮助,
在sdhost_fatfs例程中,我需要添加DMA传出,我参考的是英文论坛中8306.main.c代码:
在写数据时,数据大于1024时,代码一直无法退出;
以下为main.c和diskio.c文件:
下面为main.c
// Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/
//  Redistribution and use in source and binary forms, with or without
//  modification, are permitted provided that the following conditions
//  are met:
//    Redistributions of source code must retain the above copyright
//    notice, this list of conditions and the following disclaimer.
//    Redistributions in binary form must reproduce the above copyright
//    notice, this list of conditions and the following disclaimer in the
//    documentation and/or other materials provided with the
//    distribution.
//    Neither the name of Texas Instruments Incorporated nor the names of
//    its contributors may be used to endorse or promote products derived
//    from this software without specific prior written permission.
//  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
//  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
//  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
//  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
//  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
//  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
//  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
//  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
//  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
//  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
//  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Application Name     - SDHost FatFS
// Application Overview - This application uses the FatFS to provide the block
//                        level read/write access to SD card, using the SD Host
//                        controller on CC3200.
// Application Details  -
// processors.wiki.ti.com/.../CC32xx_SDHost_FatFS
// or
// docs\examples\CC32xx_SDHost_FatFS.pdf
// driverlib includes
#include "hw_types.h"
#include "hw_memmap.h"
#include "hw_common_reg.h"
#include "hw_ints.h"
#include "pin.h"
#include "rom.h"
#include "rom_map.h"
#include "prcm.h"
#include "sdhost.h"
#include "ff.h"
#include "utils.h"
#include "interrupt.h"
#define SDHOSTDMA	1
// common interface includes
#include "uart_if.h"
#include "pinmux.h"
#if SDHOSTDMA
#include "udma_if.h"
#endif
#define APPLICATION_VERSION  "1.1.1"
#define USERFILE        "userfile.txt"
#define SYSFILE         "sysfile.txt"
#define SYSTEXT         "The quick brown fox jumps over the lazy dogThe quick brown fox jumps over the lazy dogThe quick brown fox jumps over the lazy dogThe quick brown fox jumps over the lazy dogThe quick brown fox jumps over the lazy dog\
//                 GLOBAL VARIABLES -- Start
unsigned char pBuffer[1024*4];
#if SDHOSTDMA
volatile unsigned char g_ulDMADone;
#endif
#if defined(ccs)
extern void (* const g_pfnVectors[])(void);
#endif
#if defined(ewarm)
extern uVectorEntry __vector_table;
#endif
//                 GLOBAL VARIABLES -- End
#if SDHOSTDMA
void SDHostIntHandler()
	Message("****SDHostIntHandler********\r\n");
  MAP_SDHostIntClear(SDHOST_BASE, SDHOST_INT_DMARD | SDHOST_INT_DMAWR);
  g_ulDMADone = 1;
#endif
//! List the files in the given directory
//! \param pointer to directory
//! \return None.
static void
ListDirectory(DIR *dir)
    FILINFO fno;
    FRESULT res;
    unsigned long ulSize;
    tBoolean bIsInKB;
    for(;;)
        res = f_readdir(dir, &fno);           // Read a directory item
        if (res != FR_OK || fno.fname[0] == 0)
        break;                                // Break on error or end of dir
        ulSize = fno.fsize;
        bIsInKB = false;
        if(ulSize > 1024)
            ulSize = ulSize/1024;
            bIsInKB = true;
        Report("->%-15s%5d %-2s    %-5s\n\r",fno.fname,ulSize,\
                (bIsInKB == true)?"KB":"B",(fno.fattrib&AM_DIR)?"Dir":"File");
//! Board Initialization & Configuration
//! \param  None
//! \return None
static void
BoardInit(void)
/* In case of TI-RTOS vector table is initialize by OS itself */
#ifndef USE_TIRTOS
    // Set vector table base
#if defined(ccs)
    MAP_IntVTableBaseSet((unsigned long)&g_pfnVectors[0]);
#endif
#if defined(ewarm)
    MAP_IntVTableBaseSet((unsigned long)&__vector_table);
#endif
#endif
    // Enable Processor
    MAP_IntMasterEnable();
    MAP_IntEnable(FAULT_SYSTICK);
    PRCMCC3200MCUInit();
//! Main function
//! \param none
//! \return None.
void main()
    FIL fp;
    FATFS fs;
    FRESULT res;
    DIR dir;
    UINT Size;
    char i = 0;
    // Initialize Board configurations
    BoardInit();
    // Muxing for Enabling UART_TX and UART_RX.
    PinMuxConfig();
       // Set the SD card clock as output pin
       MAP_PinDirModeSet(CARD_CLK_PIN,PIN_DIR_MODE_OUT);
       // Enable Pull up on data
       MAP_PinConfigSet(CARD_DAT_PIN,PIN_STRENGTH_2MA, PIN_TYPE_STD_PU);
       // Enable Pull up on CMD
       MAP_PinConfigSet(CARD_CMD_PIN,PIN_STRENGTH_2MA, PIN_TYPE_STD_PU);
    // Initialising the Terminal.
    InitTerm();
    // Clearing the Terminal.
    ClearTerm();
#if SDHOSTDMA
    UDMAInit();
#endif
    // Display the Banner
    Message("\n\n\n\r");
    Message("\t\t   ********************************************\n\r");
    Message("\t\t        CC3200 SDHost Fatfs Demo Application  \n\r");
    // Enable MMCHS
    MAP_PRCMPeripheralClkEnable(PRCM_SDHOST,PRCM_RUN_MODE_CLK);
    // Reset MMCHS
    MAP_PRCMPeripheralReset(PRCM_SDHOST);
    // Configure MMCHS
    MAP_SDHostInit(SDHOST_BASE);
#if SDHOSTDMA
  	// Register interrupt handler for SDHOST_BASE
    MAP_SDHostIntRegister(SDHOST_BASE,SDHostIntHandler);
  	// Enable DMA done interrupts for SDHOST_BASE
    MAP_SDHostIntEnable(SDHOST_BASE,SDHOST_INT_DMAWR | SDHOST_INT_DMARD);
#endif
    // Configure card clock
    MAP_SDHostSetExpClk(SDHOST_BASE,
                            MAP_PRCMPeripheralClockGet(PRCM_SDHOST),15000000);
    f_mount(&fs,"0",1);
    res = f_opendir(&dir,"/");
    if( res == FR_OK)
        Message("Opening root directory.................... [ok]\n\n\r");
        Message("/\n\r");
        //ListDirectory(&dir);
    else
        Message("Opening root directory.................... [Failed]\n\n\r");
    Message("\n\rReading user file...\n\r");
    res = f_open(&fp,USERFILE,FA_READ);
    if(res == FR_OK)
        f_read(&fp,pBuffer,1024*4,&Size);
        Report("Read : %d Bytes\n\n\r",Size);
        Report("%s",pBuffer);
        f_close(&fp);
    else
        Report("Failed to open %s\n\r",USERFILE);
    Message("\n\n\rWriting system file...\n\r");
    res = f_open(&fp,SYSFILE,FA_CREATE_ALWAYS|FA_WRITE);
    if(res == FR_OK)
    	for(i=0;i<5;i++)
    		f_write(&fp,SYSTEXT,strlen(SYSTEXT),&Size);//SYSTEXT数据长度大于1024就会无法出来,一直进入回调,
    		Report("Wrote : %d Bytes",Size);
        res = f_close(&fp);
    else
        Message("Failed to create a new file\n\r");
    while(1)
diskio.c:
// diskio.c
// Low level SD Card access hookup for FatFS
// are met:
// distribution.
#include "rom.h"
#include "diskio.h"
#include "sdhost.h"
#include "stdcmd.h"
#include "utils.h"
#define SDHOSTDISKIODMA 1
#if SDHOSTDISKIODMA
#include "udma.h"
#include "hw_mmchs.h"
extern volatile unsigned char g_ulDMADone;
#endif
// Macros
#define DISKIO_RETRY_TIMEOUT 0xFFFFFFFF
#define DISKIO_SECTOR_SIZE 512;
#define CARD_TYPE_UNKNOWN 0
#define CARD_TYPE_MMC 1
#define CARD_TYPE_SDCARD 2
#define CARD_CAP_CLASS_SDSC 0
#define CARD_CAP_CLASS_SDHC 1
#define CARD_VERSION_1 0
#define CARD_VERSION_2 1
// Disk Info Structure definition
typedef struct
unsigned char ucCardType;
unsigned long ulVersion;
unsigned long ulCapClass;
unsigned long ulNofBlock;
unsigned long ulBlockSize;
DSTATUS bStatus;
unsigned short usRCA;
}DiskInfo_t;
// Disk Info for attached disk
static DiskInfo_t g_sDisk=
CARD_TYPE_UNKNOWN,
CARD_VERSION_1,
CARD_CAP_CLASS_SDSC,
0,0,
STA_NOINIT,
0
//! Send Command to card
//! \param ulCmd is the command to be send
//! \paran ulArg is the command argument
//! This function sends command to attached card and check the response status
//! if any.
//! \return Returns 0 on success, 1 otherwise
static unsigned long
CardSendCmd(unsigned long ulCmd, unsigned long ulArg)
unsigned long ulStatus;
// Clear interrupt status
MAP_SDHostIntClear(SDHOST_BASE,0xFFFFFFFF);
// Send command
MAP_SDHostCmdSend(SDHOST_BASE,ulCmd,ulArg);
// Wait for command complete or error
do
ulStatus = MAP_SDHostIntStatus(SDHOST_BASE);
ulStatus = (ulStatus & (SDHOST_INT_CC|SDHOST_INT_ERRI));
while( !ulStatus );
// Check error status
if(ulStatus & SDHOST_INT_ERRI)
// Reset the command line
MAP_SDHostCmdReset(SDHOST_BASE);
return 1;
else
return 0;
//! Get the capacity of specified card
//! \param ulRCA is the Relative Card Address (RCA)
//! This function gets the capacity of card addressed by \e ulRCA paramaeter.
//! \return Returns 0 on success, 1 otherwise.
CardCapacityGet(DiskInfo_t *psDiskInfo)
unsigned long ulRet;
unsigned long ulResp[4];
unsigned long ulBlockCount;
unsigned long ulCSizeMult;
unsigned long ulCSize;
// Read the CSD register
ulRet = CardSendCmd(CMD_SEND_CSD,(psDiskInfo->usRCA << 16 ));
if(ulRet == 0)
// Read the response
MAP_SDHostRespGet(SDHOST_BASE,ulResp);
// 136 bit CSD register is read into an array of 4 words.
// ulResp[0] = CSD[31:0]
// ulResp[1] = CSD[63:32]
// ulResp[2] = CSD[95:64]
// ulResp[3] = CSD[127:96]
if(ulResp[3] >> 30)
ulBlockSize = 512 * 1024;
ulBlockCount = (ulResp[1] >> 16 | ((ulResp[2] & 0x3F) << 16)) + 1;
else
ulBlockSize = 1 << ((ulResp[2] >> 16) & 0xF);
ulCSizeMult = ((ulResp[1] >> 15) & 0x7);
ulCSize = ((ulResp[1] >> 30) | (ulResp[2] & 0x3FF) << 2);
ulBlockCount = (ulCSize + 1) * (1<<(ulCSizeMult + 2));
// Calculate the card capacity in bytes
psDiskInfo->ulBlockSize = ulBlockSize;
psDiskInfo->ulNofBlock = ulBlockCount;
// return
return ulRet;
//! Select a card for reading or writing
//! \param Card is the pointer to card attribute structure.
//! This function selects a card for reading or writing using its RCA from
//! \e Card parameter.
//! \return Returns 0 success, 1 otherwise.
CardSelect(DiskInfo_t *sDiskInfo)
unsigned long ulRCA;
ulRCA = sDiskInfo->usRCA;
// Send select command with card's RCA.
ulRet = CardSendCmd(CMD_SELECT_CARD, (ulRCA << 16));
if(ulRet == 0)
while( !(MAP_SDHostIntStatus(SDHOST_BASE) & SDHOST_INT_TC) )
// Delay for card to become ready
MAP_UtilsDelay(80000000/12);
return ulRet;
//! Initializes physical drive
//! This function initializes a physical drive. given by \e bDrive.
//! \return Returns 0 on succeeded.
DSTATUS disk_initialize ( BYTE bDrive )
// Check the drive No.
// Only 1 drive is supported
if (bDrive == 0)
if( g_sDisk.bStatus == 0)
return g_sDisk.bStatus;
// Send std GO IDLE command
if( CardSendCmd(CMD_GO_IDLE_STATE, 0) == 0)
// Get interface operating condition for the card
ulRet = CardSendCmd(CMD_SEND_IF_COND,0x000001A5);
// It's a SD ver 2.0 or higher card
if(ulRet == 0 && ((ulResp[0] & 0xFF) == 0xA5) )
// Version 1 card do not respond to this
// command
g_sDisk.ulVersion = CARD_VERSION_2;
g_sDisk.ucCardType = CARD_TYPE_SDCARD;
// Wait for card to become ready.
do
// Send ACMD41
CardSendCmd(CMD_APP_CMD,0);
ulRet = CardSendCmd(CMD_SD_SEND_OP_COND,0x40E00000);
// Response contains 32-bit OCR register
}while(((ulResp[0] >> 31) == 0));
if(ulResp[0] & (1UL<<30))
g_sDisk.ulCapClass = CARD_CAP_CLASS_SDHC;
g_sDisk.bStatus = 0;
else //It's a MMC or SD 1.x card
do
ulRet = CardSendCmd(CMD_SD_SEND_OP_COND,0x00E00000);
if(ulRet == 0)
}while(((ulRet == 0) && (ulResp[0] >> 31) == 0));
if(ulRet == 0)
else
if( CardSendCmd(CMD_SEND_OP_COND,0) == 0)
// MMC not supported by the controller
g_sDisk.ucCardType = CARD_TYPE_MMC;
// Get the RCA of the attached card
if(g_sDisk.bStatus == 0)
ulRet = CardSendCmd(CMD_ALL_SEND_CID,0);
if( ulRet == 0)
CardSendCmd(CMD_SEND_REL_ADDR,0);
// Fill in the RCA
g_sDisk.usRCA = (ulResp[0] >> 16);
// Get tha card capacity
CardCapacityGet(&g_sDisk);
// Select the card.
ulRet = CardSelect(&g_sDisk);
if(ulRet == 0)
// Set card rd/wr block len
MAP_SDHostBlockSizeSet(SDHOST_BASE,512);
//! Gets the disk status.
//! This function gets the current status of the drive.
//! \return Returns the current status of the specified drive
DSTATUS disk_status ( BYTE bDrive )
if(bDrive == 0)
else
return STA_NOINIT;
//! Reads sector(s) from the disk drive.
//! This function reads specified number of sectors from the drive
//! \return Returns RES_OK on success.
DRESULT disk_read ( BYTE bDrive, BYTE* pBuffer, DWORD ulSectorNumber,
UINT bSectorCount )
DRESULT Res;
Res = RES_ERROR;
// Return if disk not initialized
if((g_sDisk.bStatus & STA_NOINIT))
return RES_PARERR;
// SDSC uses linear address, SDHC uses block address
if(g_sDisk.ulCapClass == CARD_CAP_CLASS_SDSC)
ulSectorNumber = ulSectorNumber * DISKIO_SECTOR_SIZE;
// Set the block count
MAP_SDHostBlockCountSet(SDHOST_BASE,bSectorCount);
// Compute the number of words
ulSize = (512*bSectorCount)/4;
#if SDHOSTDISKIODMA
UDMASetupTransfer(UDMA_CH23_SDHOST_RX,UDMA_MODE_BASIC,ulSize,UDMA_SIZE_32,UDMA_ARB_1024,
(void *)(SDHOST_BASE + MMCHS_O_DATA),UDMA_SRC_INC_NONE,(void *)
pBuffer,UDMA_DST_INC_32);
#endif
// Check if 1 block or multi block transfer
if (bSectorCount == 1)
// Send single block read command
if( CardSendCmd(CMD_READ_SINGLE_BLK|SDHOST_DMA_EN, ulSectorNumber) == 0 )
#if !SDHOSTDISKIODMA
// Read the block of data
while(ulSize--)
MAP_SDHostDataRead(SDHOST_BASE,(unsigned long *)pBuffer);
pBuffer+=4;
#else
g_ulDMADone = 0;
while( g_ulDMADone != 1 )
#endif
Res = RES_OK;
else
// Send multi block read command
if( CardSendCmd(CMD_READ_MULTI_BLK|SDHOST_DMA_EN, ulSectorNumber) == 0 )
// Read the data
while(ulSize--)
pBuffer+=4;
#else
g_ulDMADone = 0;
#endif
CardSendCmd(CMD_STOP_TRANS,0);
// Wait for command to complete
Res = RES_OK;
// return status
return Res;
//! Wrties sector(s) to the disk drive.
//! This function writes specified number of sectors to the drive
DRESULT disk_write ( BYTE bDrive,const BYTE* pBuffer, DWORD ulSectorNumber,
UINT bSectorCount)
DRESULT Res;
Res = RES_ERROR;
if (bDrive || !bSectorCount)
return RES_PARERR;
return RES_NOTRDY;
#if SDHOSTDISKIODMA
UDMASetupTransfer(UDMA_CH24_SDHOST_TX, UDMA_MODE_BASIC,
ulSize, UDMA_SIZE_32, UDMA_ARB_1024,
(void *)pBuffer, UDMA_SRC_INC_32,
(void *)(SDHOST_BASE + MMCHS_O_DATA), UDMA_DST_INC_NONE);
#endif
// Send single block write command
if( CardSendCmd(CMD_WRITE_SINGLE_BLK|SDHOST_DMA_EN, ulSectorNumber) == 0 )
// Write the data
while(ulSize--)
MAP_SDHostDataWrite(SDHOST_BASE,(*(unsigned long *)pBuffer));
pBuffer+=4;
#else
g_ulDMADone = 0;
#endif
// Wait for data transfer complete
Res = RES_OK;
else
// Set the card write block count
if(g_sDisk.ucCardType == CARD_TYPE_SDCARD)
CardSendCmd(CMD_APP_CMD,g_sDisk.usRCA << 16);
CardSendCmd(CMD_SET_BLK_CNT, bSectorCount);
if( CardSendCmd(CMD_WRITE_MULTI_BLK|SDHOST_DMA_EN, ulSectorNumber) == 0 )
// Write the data buffer
while(ulSize--)
pBuffer+=4;
#else
g_ulDMADone = 0;
#endif
// Wait for transfer complete
Res = RES_OK;
// return status
return Res;
//! Miscellaneous function
//! This function controls device specified features nd miscellaneous functions
//! other than disk read/write.
//! \returns RES_OK on success.
DRESULT disk_ioctl (BYTE bDrive,BYTE bCommand,void* Buffer )
if( bDrive != 0)
return RES_PARERR;
switch(bCommand)
case GET_SECTOR_COUNT:
*(WORD*)Buffer = g_sDisk.ulNofBlock;
break;
case GET_SECTOR_SIZE :
*(WORD*)Buffer = 512;
break;
case CTRL_SYNC:
break;
default:
while(1);
return RES_OK;
//! The get_fattime function gets current time.
DWORD get_fattime()
return 0;
