为了对CC3200做文件操作,我将file_operation工程用IAR下载到CC3200中,并在Read函数添加了将文件内容输出到串口的函数。
一开始串口不能收到任何信息,经我检查,少了对串口初始化操作。
添加之后,一切工作正常。
然后我用uniflash将file_operation.bin烧写在sys/mcuimg.bin中,在烧写之前,我对cc3200进行了Format。
然后我把SOP跳帽拿下。结果是不能收到任何串口信息。
为了更进一步测试。
我在file_operation工程中的main()添加了代码,具体代码如下
void main()
long lRetVal;
unsigned char policyVal;
long lFileHandle;
unsigned long ulToken;
// Initialize Board configurations
BoardInit();
// Configure the pinmux settings for the peripherals exercised
PinMuxConfig();
InitTerm();
// Configure LEDs
GPIO_IF_LedConfigure(LED1|LED3);
GPIO_IF_LedOff(MCU_RED_LED_GPIO);
GPIO_IF_LedOff(MCU_GREEN_LED_GPIO);
// Initializing the CC3200 networking layers
UART_PRINT("test begins 1 \n\r");
lRetVal = sl_Start(NULL, NULL, NULL);
if(lRetVal < 0)
GPIO_IF_LedOn(MCU_RED_LED_GPIO);
LOOP_FOREVER();
//GPIO_IF_LedOn(MCU_RED_LED_GPIO);
UART_PRINT("test begins \n\r");
// reset all network policies
lRetVal = sl_WlanPolicySet( SL_POLICY_CONNECTION,
SL_CONNECTION_POLICY(0,0,0,0,0),
&policyVal,
1 /*PolicyValLen*/);
if(lRetVal < 0)
UART_PRINT("test fail1 \n\r");
LOOP_FOREVER();
if(WriteFileToDevice(&ulToken, &lFileHandle) < 0)
UART_PRINT("test fail2 \n\r");
LOOP_FOREVER();
if(ReadFileFromDevice(ulToken, lFileHandle) < 0)
UART_PRINT("test fail3 \n\r");
LOOP_FOREVER();
// turn ON the green LED indicating success
GPIO_IF_LedOn(MCU_GREEN_LED_GPIO);
UART_PRINT("test ends \n\r");
lRetVal = sl_Stop(SL_STOP_TIMEOUT);
LOOP_FOREVER();
然后拨下跳帽,按reset键。结果是串口扔接收不到任何信息,黄LED,绿LED亮,红LED灯不亮
uniflash日志文件如下
[13:37:32] Begin Format operation.
[13:37:32] INFO: > Executing Operation: Connect
[13:37:35] INFO: setting break signal
[13:37:35] INFO: connection succeeded
[13:37:35] INFO: getting storage list
[13:37:35] INFO: > Executing Operation: Init
[13:37:35] INFO: reading version info
[13:37:35] INFO: DEVICE CC3200 ES1.33
[13:37:36] INFO: reading version info
[13:37:38] INFO: > Executing Operation: Format
[13:37:38] INFO: Erase storage SFLASH
[13:37:39] INFO: erase storage succeeded
[13:37:39] INFO: erase storage completed
[13:37:39] INFO: > Executing Operation: Disconnect
[13:37:39] Operation Format returned.
[13:37:49] Begin Program operation.
[13:37:49] INFO: > Executing Operation: Connect
[13:37:51] INFO: setting break signal
[13:37:52] INFO: detecting FTDI for device reset
[13:37:54] INFO: connection succeeded
[13:37:54] INFO: getting storage list
[13:37:54] INFO: > Executing Operation: Init
[13:37:54] INFO: reading version info
[13:37:54] INFO: DEVICE CC3200 ES1.33
[13:37:55] INFO: reading version info
[13:37:57] INFO: > Executing Operation: Program
[13:37:57] INFO: > File name: /sys/mcuimg.bin, Update: false, Erase: false
[13:37:57] INFO: > File name: /cert/ca.pem, Update: false, Erase: false
[13:37:57] INFO: > File name: /cert/client.pem, Update: false, Erase: false
[13:37:57] INFO: > File name: /cert/private.key, Update: false, Erase: false
[13:37:57] INFO: > File name: /sys/macadd.bin, Update: false, Erase: true
[13:37:57] INFO: > Erase File: /sys/macadd.bin
[13:37:57] INFO: erasing file "/sys/macadd.bin"
[13:37:57] INFO: deleting file "/sys/macadd.bin"
[13:37:57] INFO: erase file completed
[13:37:57] INFO: > File name: /sys/mode.cfg, Update: false, Erase: false
[13:37:57] INFO: > File name: /sys/ipcfg.ini, Update: false, Erase: false
[13:37:57] INFO: > File name: /sys/ap.cfg, Update: false, Erase: false
[13:37:57] INFO: > File name: /sys/devname.cfg, Update: false, Erase: false
[13:37:57] INFO: > File name: /sys/mdns.cfg, Update: false, Erase: false
[13:37:57] INFO: > File name: /sys/dhcpsrv.cfg, Update: false, Erase: false
[13:37:57] INFO: > File name: /sys/httpsrv.cfg, Update: false, Erase: false
[13:37:57] INFO: > File name: /sys/pref.net, Update: false, Erase: false
[13:37:57] INFO: > File name: /sys/smartconfigkeys.cfg, Update: false, Erase: false
[13:37:57] INFO: > File name: /sys/stacfg.ini, Update: false, Erase: false
[13:37:57] INFO: > File name: /sys/p2p.cfg, Update: false, Erase: false
[13:37:57] INFO: > File name: /sys/pmcfg.ini, Update: false, Erase: false
[13:37:57] INFO: > Executing Operation: Disconnect
[13:37:57] Operation Program returned.
请问如何解决这个问题
