ti工程师们好!
我修改了wifi_audio_app程序,把编解码芯片改成wm8960,取消了里面的按键程序和网络传输。由于手头上只有一个板子,想修改程序实现一个板子上将输入的音频输出。在main函数中把跟网络和按键有关的函数都注释了,加了 g_ucMicStartFlag = 1;g_ucSpkrStartFlag = 1;g_loopback = 1。现在遇到的问题是播放没声音,调试的时候发现没进DMA中断函数。main函数如下:
long lRetVal = -1;
unsigned char RecordPlay;
BoardInit();
// Pinmux Configuration
PinMuxConfig();
g_loopback = 1;
pRecordBuffer = CreateCircularBuffer(RECORD_BUFFER_SIZE);
if(pRecordBuffer == NULL)
//UART_PRINT("Unable to Allocate Memory for Tx Buffer\n\r");
LOOP_FOREVER();
if(RecordPlay & I2S_MODE_TX)
pPlayBuffer = CreateCircularBuffer(PLAY_BUFFER_SIZE);
if(pPlayBuffer == NULL)
//UART_PRINT("Unable to Allocate Memory for Rx Buffer\n\r");
LOOP_FOREVER();
// Configure Audio Codec
WM8960_Init();
// Initialize the Audio(I2S) Module
// Initialize the DMA Module
UDMAInit();
//if(RecordPlay == I2S_MODE_RX_TX)
UDMAChannelSelect(UDMA_CH5_I2S_TX, NULL);
SetupPingPongDMATransferRx(pPlayBuffer);
//if(RecordPlay & I2S_MODE_TX)
UDMAChannelSelect(UDMA_CH4_I2S_RX, NULL);
SetupPingPongDMATransferTx(pRecordBuffer);
// Setup the Audio In/Out
lRetVal = AudioSetupDMAMode(DMAPingPongCompleteAppCB_opt, \
CB_EVENT_CONFIG_SZ, RecordPlay);
if(lRetVal < 0)
//ERR_PRINT(lRetVal);
LOOP_FOREVER();
AudioCaptureRendererConfigure(AUDIO_CODEC_16_BIT, 16000, AUDIO_CODEC_STEREO, RecordPlay, 1);
// Start Audio Tx/Rx
Audio_Start(RecordPlay);
// Start the simplelink thread
//lRetVal = VStartSimpleLinkSpawnTask(9);
//if(lRetVal < 0)
// ERR_PRINT(lRetVal);
// LOOP_FOREVER();
// Start the Network Task
//lRetVal = osi_TaskCreate( Network, (signed char*)"NetworkTask",\
OSI_STACK_SIZE, NULL,
// 1, &g_NetworkTask );
//if(lRetVal < 0)
// LOOP_FOREVER();
// Start the Control Task
//lRetVal = ControlTaskCreate();
// if(lRetVal < 0)
// LOOP_FOREVER();
// Start the Microphone Task
lRetVal = osi_TaskCreate( Microphone,(signed char*)"MicroPhone", \
1, &g_MicTask );
if(lRetVal < 0)
LOOP_FOREVER();
// Start the Speaker Task
lRetVal = osi_TaskCreate( Speaker, (signed char*)"Speaker",OSI_STACK_SIZE, \
NULL, 1, &g_SpeakerTask );
if(lRetVal < 0)
LOOP_FOREVER();
// Start the task scheduler
osi_start();
