CCS8.0编译问题,在编译时出现警告。
当在CCS8.0开发环境编译工程" wifi_audio_app"时,出现如下警告:
Warnings (1 item)
This project was created using a version of compiler that is not currently installed - 5.2.6 [ARM]. Another version of the compiler will be used during build - 18.1.1.LTS. See 'Help > Install New Software' and select 'Code Generation Tools Updates' to check if this compiler is available through a CCS update. Visit <a href="liveaction:OpenAppCenter">CCS App Center</a> to get the latest compiler support. Or <a href="software-dl.ti.com/.../a> and install the compiler, then register it with CCS through 'Preferences > CCS > Build > Compilers'. wifi_audio_app properties Problem
