CC3200 LPDS时 Camera外设问题
idle_profile例程中,
// structure conatining general information of the all the modules associated
// with power mgmt. framework
struct soc_module modules[ ] = {
        /* ----------- Mandatory for Link SPI for networking ----------*/
                PRCM_LSPI,                    /* Module ID */
                LSPI_BASE,                    /* Base Addr */
                INT_LSPI,                     /* Interrupt */
                e_freq_mhz80,                 /* Frequency */
                (volatile unsigned long*)(ARCM_BASE +
                    APPS_RCM_O_MCSPI_A2_CLK_GATING), /* Clock Reg */
                e_pm_S1,                      /* Lowest PM */
                &link_spi_settings,           /* Specifics */
                NULL,                         /* SW Driver */
                NULL,                         /* Next item */
                clk_enbl_op,              /* Clk en op */
                clk_dsbl_op,              /* Clk ds op */
                spi_driver_load               /* Driver LD */
        /* ----------- Add any application specific modules here ----------*/
                PRCM_UARTA1,                /* Module ID */
                UARTA1_BASE,                /* Base Addr */
                INT_UARTA1,                 /* Interrupt */
                        APPS_RCM_O_UART_A1_CLK_GATING), /* Clock Reg */
                &uart_settings,             /* Specifics */
                uart_driver_load            /* Driver LD */
这里保存了2个外设的数据,现在我需要再额外保存Camera外设中的配置数据,但是没有找到类似的结构,如何解决这个问题?
