跑官方例程wifi_audio_app 陷入死循环,急需求助!!!!
跑官方例程得时候陷入死循环while((!IS_CONNECTED(g_ulStatus)) || (!IS_IP_ACQUIRED(g_ulStatus))),这个在连不上AP后程序就陷入了死循环,不知道怎么修改,其他帖子也没有解决方案,急求解决。
//waiting for the device to Auto Connect
while(uiConnectTimeoutCnt<AUTO_CONNECTION_TIMEOUT_COUNT &&
((!IS_CONNECTED(g_ulStatus)) || (!IS_IP_ACQUIRED(g_ulStatus))))
//Turn Green LED On
GPIO_IF_LedOn(MCU_GREEN_LED_GPIO);
osi_Sleep(50);
//Turn Green LED Off
GPIO_IF_LedOff(MCU_GREEN_LED_GPIO);
osi_Sleep(50);
uiConnectTimeoutCnt++;
//Couldn't connect Using Auto Profile
if(uiConnectTimeoutCnt==AUTO_CONNECTION_TIMEOUT_COUNT)
CLR_STATUS_BIT_ALL(g_ulStatus);
//Turn Green LED On
//Connect Using Smart Config
lRetVal = SmartConfigConnect();
ASSERT_ON_ERROR(lRetVal);
//Waiting for the device to Auto Connect
MAP_UtilsDelay(500);
