Other Parts Discussed in Thread: CC3200
CC3200 的SL_NETAPP_IP_RELEASED_EVENT事件怎么被触发
在AP模式中,触发的是SL_NETAPP_IP_LEASED_EVENT事件,程序顺序执行,所以没有触发
void SimpleLinkNetAppEventHandler(SlNetAppEvent_t *pNetAppEvent)
switch(pNetAppEvent->Event)
case SL_NETAPP_IPV4_IPACQUIRED_EVENT:
case SL_NETAPP_IPV6_IPACQUIRED_EVENT:
SET_STATUS_BIT(g_ulStatus, STATUS_BIT_IP_AQUIRED);
break;
case SL_NETAPP_IP_LEASED_EVENT:
SET_STATUS_BIT(g_ulStatus, STATUS_BIT_IP_LEASED);
g_ulStaIp = (pNetAppEvent)->EventData.ipLeased.ip_address;
UART_PRINT("[NETAPP EVENT] IP Leased to Client: IP=%d.%d.%d.%d , ",
SL_IPV4_BYTE(g_ulStaIp,3), SL_IPV4_BYTE(g_ulStaIp,2),
SL_IPV4_BYTE(g_ulStaIp,1), SL_IPV4_BYTE(g_ulStaIp,0));
break;
case SL_NETAPP_IP_RELEASED_EVENT:
CLR_STATUS_BIT(g_ulStatus, STATUS_BIT_IP_LEASED);
UART_PRINT("[NETAPP EVENT] IP Released for Client: IP=%d.%d.%d.%d , ",
break;
default:
UART_PRINT("[NETAPP EVENT] Unexpected event [0x%x] \n\r",
pNetAppEvent->Event);
break;
