Other Parts Discussed in Thread: CC3220SF, UNIFLASH
CC3220SF 程序bulid问题和烧录没问题,但点击Start 按钮就报错如下错误?该如何解决? 我在MQTT_CLIENT_SREVER范例上添加I2C驱动就这样.
Cortex_M4_0: JTAG Communication Error: (Error -242 @ 0x0) A router subpath could not be accessed. The board configuration file is probably incorrect. (Emulation package 9.2.0.00002)
Cortex_M4_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
