在 wlan_smart_config_start 函数的注释中看到如下一段话
@brief Start to acquire device profile. The device acquire its own
//! profile, if profile message is found. The acquired AP information
//! is stored in CC3000 EEPROM only in case AES128 encryption is used.
//! In case AES128 encryption is not used, a profile is created by
//! CC3000 internally.
是不是理解为只有在手机与cc3000通信使用AES128加密的情况下,cc3000才会将ssid密码存储到eeprom中?如果比加密传输cc3000不会存储ssid?
那么如果我需要读取ssid 密码的话,手机端必须使用加密方式通信?
望解答!!
