CC3000能否读取信号强度,如何读取?
请教大神们,我用的模块是WG1300-B0.数据可以收发,由于项目需要读取WIFI信号强度。知道的大神们,请告知。
  • 是通过这个API来做的wlan_ioctl_get_scan_results,你看它返回的结果里面有一项是rssi。
    加一个下面的结构体:
    typedef struct {
    unsigned long networksFound;
    unsigned long scanStatus;
    unsigned long isValid : 1;
    signed long rssi : 7;
    unsigned long securityMode : 2;
    unsigned long ulSsidLen : 6;
    unsigned long frameTime : 16;
    char ssid[32];
    unsigned char ucBssid[6];
    } wifi_scan_result_t;
    然后代码片段如下:
    static unsigned char buffer[50];
    wifi_scan_result_t *result = (wifi_scan_result_t *) buffer;
    memset(buffer, 0, sizeof(buffer));
    if (wlan_ioctl_get_scan_results(0, buffer) != 0)
    return -2;
