CC3200 LaunchPad 剛開始使用時在 "Code Composer Studio 6.0.1" 與 "CCS UniFlash" 燒錄程序與flash都正常,但是使用幾次之後,目前都出現下載程序與燒錄Flash 時都是失敗的狀況,請問是哪出了問題?
以下是下載Flash錯誤現象;
[11:54:38] INFO: setting break signal
[11:54:38] INFO: --- please restart the device ---
[11:54:53] ERROR: ---reading ACK signal failed---
[11:54:55] INFO: setting break signal
[11:54:55] INFO: --- please restart the device ---
[11:55:10] ERROR: ---reading ACK signal failed---
[11:55:10] FATAL: --- Can't connect to device !! ---
[11:55:15] FATAL: Error connecting to the device. Please check your COM port settings. Error code: -3
[11:55:15] INFO: > Executing Operation: Disconnect
[11:55:15] Operation Canceled: Process<GetVersion> canceled.
