TI:
我是按照 TCP socket demo
iSockID = sl_Socket(SL_AF_INET,SL_SOCK_STREAM, 0);
if( iSockID < 0 )
// error
ASSERT_ON_ERROR(SOCKET_CREATE_ERROR);
iAddrSize = sizeof(SlSockAddrIn_t);
// binding the TCP socket to the TCP server address
iStatus = sl_Bind(iSockID, (SlSockAddr_t *)&sLocalAddr, iAddrSize);
if( iStatus < 0 )
// error
sl_Close(iSockID);
ASSERT_ON_ERROR(BIND_ERROR);
// putting the socket for listening to the incoming TCP connection
iStatus = sl_Listen(iSockID, 0);
if( iStatus < 0 )
sl_Close(iSockID);
ASSERT_ON_ERROR(LISTEN_ERROR);
// setting socket option to make the socket as non blocking
iStatus = sl_SetSockOpt(iSockID, SL_SOL_SOCKET, SL_SO_NONBLOCKING,
&lNonBlocking, sizeof(lNonBlocking));
if( iStatus < 0 )
sl_Close(iSockID);
ASSERT_ON_ERROR(SOCKET_OPT_ERROR);
iNewSockID = SL_EAGAIN;
// waiting for an incoming TCP connection
while( iNewSockID < 0 )
// accepts a connection form a TCP client, if there is any
// otherwise returns SL_EAGAIN
iNewSockID = sl_Accept(iSockID, ( struct SlSockAddr_t *)&sAddr,
(SlSocklen_t*)&iAddrSize);
if( iNewSockID == SL_EAGAIN )
MAP_UtilsDelay(10000);
else if( iNewSockID < 0 )
// error
sl_Close(iNewSockID);
sl_Close(iSockID);
ASSERT_ON_ERROR(ACCEPT_ERROR);
// waits for 1000 packets from the connected TCP client
while (lLoopCount < g_ulPacketCount)
iStatus = sl_Recv(iNewSockID, g_cBsdBuf, iTestBufLen, 0);
if( iStatus <= 0 )
// error
sl_Close(iSockID);
ASSERT_ON_ERROR(RECV_ERROR);
lLoopCount++;
Report("Recieved %u packets successfully\n\r",g_ulPacketCount);
// close the connected socket after receiving from connected TCP client
iStatus = sl_Close(iNewSockID);
这个 sl_SetSockOpt(); 试过任何位置, 从socket() 后面到 Recv() 前面都试过, 也试过多次设置, 非阻塞都是无效。
请问, 作为 TCP Server 应该怎么设置这个非阻塞呢?
