在跑SDK 实例时,烧camera_application 的camera_application.ucf 进去掉 去掉SOP2 就可以进网页,连上摄像头 可以看到 图像,就是好卡, 但是烧websock_camera 的websock_camera.ucf 进去后,去掉SOP2 连上WIFI ,但就是打不开网页 192.168.1.1 和192.168.1.1/camera_demo.html 都 打不开, 但是 能PING 通 。以下 是我烧写后的记录 帮我看下 问题在哪里, 三四天了 找了一个高手也没解决,他说没遇到过
[17:10:02] Begin Program operation.
[17:10:03] INFO: Checked for update config groups: []
[17:10:03] INFO: List of files to be generated: []
[17:10:03] INFO: > Executing Operation: Connect
[17:10:05] INFO: setting break signal
[17:10:05] INFO: --- please restart the device ---
[17:10:08] INFO: connection succeeded
[17:10:08] INFO: getting storage list
[17:10:08] INFO: > Executing Operation: Init
[17:10:08] INFO: reading version info
[17:10:08] INFO: DEVICE CC3200 ES1.33
[17:10:09] INFO: reading version info
[17:10:11] INFO: > Executing Operation: Program
[17:10:11] INFO: > File name: /sys/mcuimg.bin, Update: true, Erase: true
[17:10:11] INFO: > Erase File: /sys/mcuimg.bin
[17:10:11] INFO: erasing file "/sys/mcuimg.bin"
[17:10:11] INFO: deleting file "/sys/mcuimg.bin"
[17:10:11] INFO: erase file completed
[17:10:11] INFO: > Size of file = 30672
[17:10:11] INFO: > Update File: /sys/mcuimg.bin
[17:10:11] INFO: Downloading file "/sys/mcuimg.bin" with size 30672
[17:10:12] INFO:
New Token is 0x0
[17:10:12] INFO: Download complete
[17:10:12] INFO: Verifying Data...
[17:10:12] INFO: get file
[17:10:13] INFO: Done. Reading 30672 bytes
[17:10:13] INFO:
Verification OK
[17:10:14] INFO: > Updated Token value: 0x0
[17:10:14] INFO: > File name: /cert/ca.pem, Update: false, Erase: false
[17:10:14] INFO: > File name: /cert/client.pem, Update: false, Erase: false
[17:10:14] INFO: > File name: /cert/private.key, Update: false, Erase: false
[17:10:14] INFO: > File name: /sys/macadd.bin, Update: false, Erase: false
[17:10:14] INFO: > File name: /sys/mode.cfg, Update: false, Erase: false
[17:10:14] INFO: > File name: /sys/ipcfg.ini, Update: false, Erase: false
[17:10:14] INFO: > File name: /sys/ap.cfg, Update: false, Erase: false
[17:10:14] INFO: > File name: /sys/devname.cfg, Update: false, Erase: false
[17:10:14] INFO: > File name: /sys/mdns.cfg, Update: false, Erase: false
[17:10:14] INFO: > File name: /sys/dhcpsrv.cfg, Update: false, Erase: false
[17:10:14] INFO: > File name: /sys/httpsrv.cfg, Update: false, Erase: false
[17:10:14] INFO: > File name: /sys/pref.net, Update: false, Erase: false
[17:10:14] INFO: > File name: /sys/smartconfigkeys.cfg, Update: false, Erase: false
[17:10:14] INFO: > File name: /sys/stacfg.ini, Update: false, Erase: false
[17:10:14] INFO: > File name: /sys/p2p.cfg, Update: false, Erase: false
[17:10:14] INFO: > File name: /sys/pmcfg.ini, Update: false, Erase: false
[17:10:14] INFO: > File name: www/main.html, Update: true, Erase: true
[17:10:14] INFO: > Erase File: www/main.html
[17:10:14] INFO: erasing file "www/main.html"
[17:10:14] INFO: deleting file "www/main.html"
[17:10:14] INFO: erase file completed
[17:10:14] INFO: > Size of file = 2724
[17:10:14] INFO: > Update File: www/main.html
[17:10:14] INFO: Downloading file "www/main.html" with size 2724
[17:10:14] INFO:
New Token is 0x0
[17:10:14] INFO: Download complete
[17:10:14] INFO: Verifying Data...
[17:10:14] INFO: get file
[17:10:15] INFO: Done. Reading 2724 bytes
[17:10:15] INFO:
Verification OK
[17:10:16] INFO: > Updated Token value: 0x0
[17:10:16] INFO: > File name: www/camera_demo.html, Update: true, Erase: true
[17:10:16] INFO: > Erase File: www/camera_demo.html
[17:10:16] INFO: erasing file "www/camera_demo.html"
[17:10:16] INFO: deleting file "www/camera_demo.html"
[17:10:16] INFO: erase file completed
[17:10:16] INFO: > Size of file = 3411
[17:10:16] INFO: > Update File: www/camera_demo.html
[17:10:16] INFO: Downloading file "www/camera_demo.html" with size 3411
[17:10:16] INFO:
New Token is 0x0
[17:10:16] INFO: Download complete
[17:10:16] INFO: Verifying Data...
[17:10:16] INFO: get file
[17:10:16] INFO: Done. Reading 3411 bytes
[17:10:16] INFO:
Verification OK
[17:10:17] INFO: > Updated Token value: 0x0
[17:10:17] INFO: > File name: www/images/ti_simplelink.jpg, Update: true, Erase: true
[17:10:17] INFO: > Erase File: www/images/ti_simplelink.jpg
[17:10:17] INFO: erasing file "www/images/ti_simplelink.jpg"
[17:10:17] INFO: deleting file "www/images/ti_simplelink.jpg"
[17:10:17] INFO: erase file completed
[17:10:17] INFO: > Size of file = 69017
[17:10:17] INFO: > Update File: www/images/ti_simplelink.jpg
[17:10:17] INFO: Downloading file "www/images/ti_simplelink.jpg" with size 69017
[17:10:20] INFO:
New Token is 0x0
[17:10:20] INFO: Download complete
[17:10:20] INFO: Verifying Data...
[17:10:20] INFO: get file
[17:10:21] INFO: Done. Reading 69017 bytes
[17:10:21] INFO:
Verification OK
[17:10:22] INFO: > Updated Token value: 0x0
[17:10:22] INFO: > File name: www/js/jquery-1.8.3.min.js, Update: true, Erase: true
[17:10:22] INFO: > Erase File: www/js/jquery-1.8.3.min.js
[17:10:22] INFO: erasing file "www/js/jquery-1.8.3.min.js"
[17:10:22] INFO: deleting file "www/js/jquery-1.8.3.min.js"
[17:10:23] INFO: erase file completed
[17:10:23] INFO: > Size of file = 93637
[17:10:23] INFO: > Update File: www/js/jquery-1.8.3.min.js
[17:10:23] INFO: Downloading file "www/js/jquery-1.8.3.min.js" with size 93637
[17:10:26] INFO:
New Token is 0x0
[17:10:26] INFO: Download complete
[17:10:26] INFO: Verifying Data...
[17:10:26] INFO: get file
[17:10:28] INFO: Done. Reading 93637 bytes
[17:10:28] INFO:
Verification OK
[17:10:29] INFO: > Updated Token value: 0x0
[17:10:29] INFO: > Executing Operation: Disconnect
[17:10:29] Operation Program returned.
[17:13:02] Begin Program operation.
[17:13:03] INFO: Checked for update config groups: []
[17:13:03] INFO: List of files to be generated: []
[17:13:03] INFO: > Executing Operation: Connect
[17:13:05] INFO: setting break signal
[17:13:05] INFO: --- please restart the device ---
[17:13:20] ERROR: ---reading ACK signal failed---
[17:13:20] WARNING: ---seting break signal to false failed---
[17:13:22] INFO: setting break signal
[17:13:22] INFO: --- please restart the device ---
[17:13:24] INFO: connection succeeded
[17:13:24] INFO: getting storage list
[17:13:24] INFO: > Executing Operation: Init
[17:13:24] INFO: reading version info
[17:13:24] INFO: DEVICE CC3200 ES1.33
[17:13:25] INFO: reading version info
[17:13:27] INFO: > Executing Operation: Program
[17:13:27] INFO: > File name: /sys/mcuimg.bin, Update: true, Erase: true
[17:13:27] INFO: > Erase File: /sys/mcuimg.bin
[17:13:27] INFO: erasing file "/sys/mcuimg.bin"
[17:13:27] INFO: deleting file "/sys/mcuimg.bin"
[17:13:27] INFO: erase file completed
[17:13:27] INFO: > Size of file = 146772
[17:13:27] INFO: > Update File: /sys/mcuimg.bin
[17:13:27] INFO: Downloading file "/sys/mcuimg.bin" with size 146772
[17:13:32] INFO:
New Token is 0x0
[17:13:32] INFO: Download complete
[17:13:32] INFO: Verifying Data...
[17:13:32] INFO: get file
[17:13:35] INFO: Done. Reading 146772 bytes
[17:13:35] INFO:
Verification OK
[17:13:36] INFO: > Updated Token value: 0x0
[17:13:36] INFO: > File name: /cert/ca.pem, Update: false, Erase: false
[17:13:36] INFO: > File name: /cert/client.pem, Update: false, Erase: false
[17:13:36] INFO: > File name: /cert/private.key, Update: false, Erase: false
[17:13:36] INFO: > File name: /sys/macadd.bin, Update: false, Erase: false
[17:13:36] INFO: > File name: /sys/mode.cfg, Update: false, Erase: false
[17:13:36] INFO: > File name: /sys/ipcfg.ini, Update: false, Erase: false
[17:13:36] INFO: > File name: /sys/ap.cfg, Update: false, Erase: false
[17:13:36] INFO: > File name: /sys/devname.cfg, Update: false, Erase: false
[17:13:36] INFO: > File name: /sys/mdns.cfg, Update: false, Erase: false
[17:13:36] INFO: > File name: /sys/dhcpsrv.cfg, Update: false, Erase: false
[17:13:36] INFO: > File name: /sys/httpsrv.cfg, Update: false, Erase: false
[17:13:36] INFO: > File name: /sys/pref.net, Update: false, Erase: false
[17:13:36] INFO: > File name: /sys/smartconfigkeys.cfg, Update: false, Erase: false
[17:13:36] INFO: > File name: /sys/stacfg.ini, Update: false, Erase: false
[17:13:36] INFO: > File name: /sys/p2p.cfg, Update: false, Erase: false
[17:13:36] INFO: > File name: /sys/pmcfg.ini, Update: false, Erase: false
[17:13:36] INFO: > File name: www/main.html, Update: true, Erase: true
[17:13:36] INFO: > Erase File: www/main.html
[17:13:36] INFO: erasing file "www/main.html"
[17:13:36] INFO: deleting file "www/main.html"
[17:13:36] INFO: erase file completed
[17:13:36] INFO: > Size of file = 2721
[17:13:36] INFO: > Update File: www/main.html
[17:13:36] INFO: Downloading file "www/main.html" with size 2721
[17:13:37] INFO:
New Token is 0x0
[17:13:37] INFO: Download complete
[17:13:37] INFO: Verifying Data...
[17:13:37] INFO: get file
[17:13:37] INFO: Done. Reading 2721 bytes
[17:13:37] INFO:
Verification OK
[17:13:38] INFO: > Updated Token value: 0x0
[17:13:38] INFO: > File name: www/camera_demo.html, Update: true, Erase: true
[17:13:38] INFO: > Erase File: www/camera_demo.html
[17:13:38] INFO: erasing file "www/camera_demo.html"
[17:13:38] INFO: deleting file "www/camera_demo.html"
[17:13:38] INFO: erase file completed
[17:13:38] INFO: > Size of file = 3103
[17:13:38] INFO: > Update File: www/camera_demo.html
[17:13:38] INFO: Downloading file "www/camera_demo.html" with size 3103
[17:13:38] INFO:
New Token is 0x0
[17:13:38] INFO: Download complete
[17:13:38] INFO: Verifying Data...
[17:13:38] INFO: get file
[17:13:38] INFO: Done. Reading 3103 bytes
[17:13:38] INFO:
Verification OK
[17:13:39] INFO: > Updated Token value: 0x0
[17:13:39] INFO: > File name: www/images/ti_simplelink.jpg, Update: true, Erase: true
[17:13:39] INFO: > Erase File: www/images/ti_simplelink.jpg
[17:13:39] INFO: erasing file "www/images/ti_simplelink.jpg"
[17:13:39] INFO: deleting file "www/images/ti_simplelink.jpg"
[17:13:40] INFO: erase file completed
[17:13:40] INFO: > Size of file = 69017
[17:13:40] INFO: > Update File: www/images/ti_simplelink.jpg
[17:13:40] INFO: Downloading file "www/images/ti_simplelink.jpg" with size 69017
[17:13:42] INFO:
New Token is 0x0
[17:13:42] INFO: Download complete
[17:13:42] INFO: Verifying Data...
[17:13:42] INFO: get file
[17:13:44] INFO: Done. Reading 69017 bytes
[17:13:44] INFO:
Verification OK
[17:13:45] INFO: > Updated Token value: 0x0
[17:13:45] INFO: > File name: www/js/jquery-1.8.3.min.js, Update: true, Erase: true
[17:13:45] INFO: > Erase File: www/js/jquery-1.8.3.min.js
[17:13:45] INFO: erasing file "www/js/jquery-1.8.3.min.js"
[17:13:45] INFO: deleting file "www/js/jquery-1.8.3.min.js"
[17:13:45] INFO: erase file completed
[17:13:45] INFO: > Size of file = 93637
[17:13:45] INFO: > Update File: www/js/jquery-1.8.3.min.js
[17:13:45] INFO: Downloading file "www/js/jquery-1.8.3.min.js" with size 93637
[17:13:49] INFO:
New Token is 0x0
[17:13:49] INFO: Download complete
[17:13:49] INFO: Verifying Data...
[17:13:49] INFO: get file
[17:13:50] INFO: Done. Reading 93637 bytes
[17:13:50] INFO:
Verification OK
[17:13:51] INFO: > Updated Token value: 0x0
[17:13:51] INFO: > File name: www/simple_link.css, Update: true, Erase: true
[17:13:51] INFO: > Erase File: www/simple_link.css
[17:13:51] INFO: erasing file "www/simple_link.css"
[17:13:51] INFO: deleting file "www/simple_link.css"
[17:13:52] INFO: erase file completed
[17:13:52] INFO: > Size of file = 8349
[17:13:52] INFO: > Update File: www/simple_link.css
[17:13:52] INFO: Downloading file "www/simple_link.css" with size 8349
[17:13:52] INFO:
New Token is 0x0
[17:13:52] INFO: Download complete
[17:13:52] INFO: Verifying Data...
[17:13:52] INFO: get file
[17:13:52] INFO: Done. Reading 8349 bytes
[17:13:52] INFO:
Verification OK
[17:13:53] INFO: > Updated Token value: 0x0
[17:13:53] INFO: > Executing Operation: Disconnect
[17:13:54] Operation Program returned.
