自己做CC3200的底板,识别不了串口!
Other Parts Discussed in Thread: CC3200, CC3100
我公司现在想自己做IOT模块用在家电上面,使用CC3200。按TI CC3200 lanch pad 的图纸,我分离出了底板和模块,重新画了底板,然后将wifi模块独立出来。打板出来贴片完毕,插上USB口,只能识别到USB-com口,也能装上驱动,但无法识别为CC3200LP,也就无法完成程序烧写。再看看图纸,发现FTDI芯片上连了一块93LC46B的memory。我估计这里要烧写识别串口的某些固件。
请教各位TI工程师,要怎么样搞FTDI的固件?
  • 试一下wiki链接 http://processors.wiki.ti.com/index.php/CC31xx_%26_CC32xx_FTDI_Flashing 的步骤
    If your CC3100/CC3200 is not recognized, install the FTDI D2XX driver.
    1. Install the the FT_PROG
    2. Connect the USB cable between the PC and your target board.
    3. Install either CC3200_SDK and/or CC3100_SDK package, depending on what platform you are using.
    4. Open FT_PROG and press F5 (or refresh) to refresh the list of connected FTDI devices.
    5. Right click the device and select erase.
    6. Right click the device choose Apply Template -> From file and choose the corresponding .xml template file from the download section above.
    7. Press Ctrl+P
    8. Reset board by unplugging and plugging USB cable.
  • 谢谢,Susan! 我试试先!
