CC3200的wifi_audio_app工程加入AIC3254的dsp初始化寄存器数组,编译不通过?
Other Parts Discussed in Thread: CC3200
TI工程师你们好!
      我在CC3200的wifi_audio_app工程加入AIC3254的minidsp初始化寄存器数组,数组是GDE配置生成的,工程编译不通过,提示信息如下:
Error[Lp011]: section placement failed
unable to allocate space for sections/blocks with a total estimated minimum size of 0x2dcb4 bytes (max align 0x400) in <[0x20004000-0x20030000]> (total uncommitted space 0x2bc01).
42 074 bytes of readonly  code memory
24 266 bytes of readonly  data memory
122 217 bytes of readwrite data memory
Errors: 1 Warnings: none Link time:   0.11 (CPU)   0.17 (elapsed)
Error while running Linker
数组前已经加了const修饰,但是还是提示空间不足,我尝试修改工程的ICF连接文件,将sram的定义大一点,编译可以通过,烧录后不能正常运行。
按道理CC3200空间是足够的,为什么会提示空间不足呢?请大家帮忙解答一下!多谢。
