ZCL库标准在ZigBee联盟网站为什么找不到呢?
ZigBee Cluster Library Specification
TI人员能否提供一个链接。
The newest spec is for ZigBee Alliance member only, actually the newest ZCL spec is 06 published in January 2016.
Date of release 14 January 2016
Abstract This document defines the ZigBee Cluster Library revision 6 (ZCL6).
我在网上找到的这个是revision 5的版本,附件是我在百度上搜到的,在ZigBee联盟网站下的是这个版本的前一版本,revision 4。为什么联盟网站上没有最新的呢,这个又是怎么出来的。
I just compare your attached doc with mine, it is the same. So maybe someone member release it to public site, but as I know, the newest spec is offered to members only including ZCL spec (r06) and ZigBee spec (r21).
You may update to the newest ZCL 6, and it is released to the public now including the ZigBee spec R21.
http://www.zigbee.org/wp-content/uploads/2014/10/07-5123-06-zigbee-cluster-library-specification.pdf
