Other Parts Discussed in Thread: Z-STACK
问题描述:
这边修改了最大节点数目,NWK_MAX_DEVICE_LIST 为30.
现象1 组网的时候发现设备低于30个的时候可以组网成功
现象2 但是设备大于30个的时候,只能组网7个。查看AssociatedDevList,发现数据满了,但是节点根本就没有组网。
不知道修改节点数量,有哪些需要注意的?为什么这样修改会导致无法组网。
协调器的配置如下:
* f8wConfig.cfg
* Compiler command-line options used to define a TI Z-Stack ZigBee device.
* To move an option from here to the project file, comment out or delete the
* option from this file and enter it into the "Define Symbols" box under the
* Preprocessor tab of the C/C++ Compiler Project Options. New user defined
* options may be added to this file, as necessary.
* Each macro is prefixed with '-D'. The entries are to be constructed as if
* they are to be on the compiler command line invocation (which they are).
* NOTE: The RHS (Right-Hand-Side) must be quoted if there are embedded blanks.
* See the DEFAULT_KEY definition for an example.
-DZIGBEEPRO
-DSECURE=1
-DZG_SECURE_DYNAMIC=0
-DREFLECTOR
// Channels are defined in the following:
// 0 : 868 MHz 0x00000001
// 1 - 10 : 915 MHz 0x000007FE
// 11 - 26 : 2.4 GHz 0x07FFF800
//-DMAX_CHANNELS_868MHZ 0x00000001
//-DMAX_CHANNELS_915MHZ 0x000007FE
//-DMAX_CHANNELS_24GHZ 0x07FFF800
//-DDEFAULT_CHANLIST=0x04000000 // 26 - 0x1A
//-DDEFAULT_CHANLIST=0x02000000 // 25 - 0x19
//-DDEFAULT_CHANLIST=0x01000000 // 24 - 0x18
//-DDEFAULT_CHANLIST=0x00800000 // 23 - 0x17
//-DDEFAULT_CHANLIST=0x00400000 // 22 - 0x16
//-DDEFAULT_CHANLIST=0x00200000 // 21 - 0x15
//-DDEFAULT_CHANLIST=0x00100000 // 20 - 0x14
//-DDEFAULT_CHANLIST=0x00080000 // 19 - 0x13
//-DDEFAULT_CHANLIST=0x00040000 // 18 - 0x12
//-DDEFAULT_CHANLIST=0x00020000 // 17 - 0x11
//-DDEFAULT_CHANLIST=0x00010000 // 16 - 0x10
//-DDEFAULT_CHANLIST=0x00008000 // 15 - 0x0F
//-DDEFAULT_CHANLIST=0x00004000 // 14 - 0x0E
//-DDEFAULT_CHANLIST=0x00002000 // 13 - 0x0D
//-DDEFAULT_CHANLIST=0x00001000 // 12 - 0x0C
-DDEFAULT_CHANLIST=0x00000800 // 11 - 0x0B
* Setting this to a value other than 0xFFFF causes
* ZDO_COORD to use this value as its PAN ID and
* Routers and end devices to join PAN with this ID
-DZDAPP_CONFIG_PAN_ID=0xFFFF
* in the network and the minimum delay between joining cycles.
-DNWK_START_DELAY=100
* the return from osal_rand() to get a random delay time for
* each joining cycle. This random value is added to NWK_START_DELAY.
* For example, a value of 0x007F will be a joining delay of 0 to 127
* milliseconds.
-DEXTENDED_JOINING_RANDOM_MASK=0x007F
* in a joining cycle.
-DBEACON_REQUEST_DELAY=100
* return from osal_rand() to get a random delay time for each joining cycle.
* This random value is added to DBEACON_REQUEST_DELAY. For example, a value
* of 0x00FF will be a beacon request delay of 0 to 255 milliseconds.
-DBEACON_REQ_DELAY_MASK=0x00FF
* return from osal_rand() to add a random delay to _NIB.nwkLinkStatusPeriod.
* For example, a value of 0x007F allows a jitter between 0-127 milliseconds.
-DLINK_STATUS_JITTER_MASK=0x007F
-DROUTE_EXPIRY_TIME=30
* doesn't work for sleeping end devices. For non-polled devices,
* a formula is used. Value is in 2 milliseconds periods
-DAPSC_ACK_WAIT_DURATION_POLLED=3000
* 1-65535 (0 -> 65536) X CNT_RTG_TIMER X RTG_TIMER_INTERVAL
-DNWK_INDIRECT_MSG_TIMEOUT=7
-DMAX_RREQ_ENTRIES=8
-DAPSC_MAX_FRAME_RETRIES=3
-DNWK_MAX_DATA_RETRIES=2
* with parent. Note that larger value will cause longer delay for the child to
* rejoin the network.
-DMAX_POLL_FAILURE_RETRIES=2
-DMAX_BCAST=9
-DAPS_MAX_GROUPS=16
* entries for route repair
-DMAX_RTG_ENTRIES=40
-DNWK_MAX_BINDING_ENTRIES=4
* Note that any value other than the default value may cause a
* compilation warning but Device Binding will function correctly.
-DMAX_BINDING_CLUSTER_IDS=4
-DDEFAULT_KEY="{0x01, 0x01, 0x01, 0x01, 0x02, 0x02, 0x02, 0x02, 0x03, 0x03, 0x03, 0x03, 0x04, 0x04, 0x04, 0x04}"
//-DDEFAULT_KEY="{0x01, 0x03, 0x05, 0x07, 0x09, 0x0B, 0x0D, 0x0F, 0x00, 0x02, 0x04, 0x06, 0x08, 0x0A, 0x0C, 0x0D}"
/* Reset when ASSERT occurs, otherwise flash LEDs */
//-DASSERT_RESET
-DMAC_MAX_FRAME_SIZE=116
* Frequency Agility can be disabled by setting this parameter to zero.
-DZDNWKMGR_MIN_TRANSMISSIONS=20
-DCONST="const __code"
-DGENERIC=__generic
* The following are for End Devices only
-DPOLL_RATE=1000
* for queued messages...in milliseconds.
-DQUEUED_POLL_RATE=100
* for response messages...in milliseconds
-DRESPONSE_POLL_RATE=100
* This rate is determined by the response time of the parent that the device
* is trying to join.
-DREJOIN_POLL_RATE=440
-DCPU32MHZ // CC2530s Run at 32MHz
-DROOT=__near_func // MAC/ZMAC code in NEAR
-DMAC_CFG_APP_PENDING_QUEUE=TRUE
-DMAC_CFG_TX_DATA_MAX=5
-DMAC_CFG_TX_MAX=8
-DMAC_CFG_RX_MAX=5
-DZDO_COORDINATOR // Coordinator Functions
-DRTR_NWK // Router Functions
