Other Parts Discussed in Thread: Z-STACK
Hi,大神们,请教一下情景遥控器的实现。
我现在有一个2键的遥控器想做成情景控制,一个键控制灯全开,另一个键控制灯全关。灯已经是HA的灯,用Z-stack Linux gateway测试过,可以实现全开全关。
我应该在SampleSwicth例程中添加什么代码??
If you want to control device that are already commissioned by the gateway device, you must:
1.a.- Know the GroupID of these lights. If you do not know it, you can send a zclGeneral_SendGroupGetMembershipRequest with GroupCount=0 (ZCL 3.6.2.3.4) to get the groups that these lights have.
1.b.- Switch device must have in each button a zclGeneral_SendSceneRecall with the 2 different scenes (SCENE1 and SCENE2), you need to set the message as indirect and the short address set to the Group ID from 'a'.
