zstack home 1.2.2a AF接收函数疑问(CC2530DB)
zcl.c文件中有一个zcl_event_loop()函数:
uint16 zcl_event_loop( uint8 task_id, uint16 events )
if ( *msgPtr == AF_INCOMING_MSG_CMD )
zcl_ProcessMessageMSG( (afIncomingMSGPacket_t *)msgPtr );  //AF数据接收处理函数
zcl_samplelight.c文件中有个 zclSampleLight_event_loop(  )函数:
两个event_loop(  )函数分别用来处理什么任务啊?有什么不同呀
  • // The order in this table must be identical to the task initialization calls below in osalInitTask.
    const pTaskEventHandlerFn tasksArr[] = {
    macEventLoop,
    nwk_event_loop,
    Hal_ProcessEvent,
    #if defined( MT_TASK )
    MT_ProcessEvent,
    #endif
    APS_event_loop,
    #if defined ( ZIGBEE_FRAGMENTATION )
    APSF_ProcessEvent,
    #endif
    ZDApp_event_loop,
    #if defined ( ZIGBEE_FREQ_AGILITY ) || defined ( ZIGBEE_PANID_CONFLICT )
    ZDNwkMgr_event_loop,
    #endif
    zcl_event_loop,
    你可以理解为是不同层次的消息,类似于TCP/IP的7层协议
