Other Parts Discussed in Thread: CC2530
HI
ZHA1.2.2a协议栈的路由节点报错:route error
command ID:Route error(0x03)
Error code:Source route failure(0x0B)
Error Destination Address:0xF716
这个报错如何处理呀?
这个是route error是路由节点转发网关命令给终端节点失败后报的错,
注:CC2530
HI
这个报错如何处理呀?
注:CC2530
Source route failure: Source routing has failed, probably indicating a link failure in one of the source route’s links.
Indirect transaction expiry: A frame that was buffered on behalf of a sleeping end device child has been dropped as a result of a time-out.
具体信息可以参考
你好!
拓扑结构我们没有修改,还是MESH。
我们在ZHA1.2.2的例程测试
