Z-Stack Linux Gateway在Mips平台下运行问题
Other Parts Discussed in Thread: CC2530, Z-STACK
运行环境:MCU使用MT7628,ZigBee协调器使用CC2530,两者通过Uart通信。
协调器CC2530使用的程序时ZigBee 3.0提供的ZNP工程Demo。
把Z-Stack Linux Gateway移植到MT7628 Mips平台上,得到Z-Stack Gateway的Server程序如下:
NPI_lnx_mips_server、ZLSZNP_mips、NWKMGR_SRVR_mips、GATEWAY_SRVR_mips、OTA_SRVR_mips
按照顺序执行了NPI_lnx_mips_server、ZLSZNP_mips,当执行NWKMGR_SRVR_mips程序时发生初始化错误,执行Log如下所示:
# ./NWKMGR_SRVR_mips 127.0.0.1:2536
[NWK_MGR/MAIN] :  there are 2 args
[NWK_MGR/MAIN] :  argv[0] = ./NWKMGR_SRVR_mips
[NWK_MGR/MAIN] :  argv[1] = 127.0.0.1:2536
[ZSTACKZNP_SRVR/LSTN] INFO: zstackpb zspbHandlePbCb - connected: 7
[NWK_MGR/MAIN] :  ************************************************
[NWK_MGR/MAIN] :  *         Network Manager Server v1.0.1        *
[NWK_MGR/MAIN] :  * The following are the avaible key commands:  *
[NWK_MGR/MAIN] :  * Exit Program.                         -  q   *
Sending AF Register Request.
[NWK_MGR/MAIN] INFO: preparing to send 21 bytes, subSys 0x11, cmdId 0x20, pData:
[NWK_MGR/MAIN] INFO:  0x08
[NWK_MGR/MAIN] INFO:  0x20
[NWK_MGR/MAIN] INFO:  0x10
[NWK_MGR/MAIN] INFO:  0x01
[NWK_MGR/MAIN] INFO:  0x1A
[NWK_MGR/MAIN] INFO:  0x0D
[NWK_MGR/MAIN] INFO:  0x84
[NWK_MGR/MAIN] INFO:  0x02
[NWK_MGR/MAIN] INFO:  0x18
[NWK_MGR/MAIN] INFO:  0x07
[NWK_MGR/MAIN] INFO:  0x00
[NWK_MGR/MAIN] INFO:  0x28
[NWK_MGR/MAIN] INFO:  0x30
[NWK_MGR/MAIN] INFO:  0x06
[NWK_MGR/MAIN] INFO: [MUTEX] Lock SRSP Mutex[NWK_MGR/MAIN] INFO:
[MUTEX] SRSP Lock status: 0
[ZSTACKZNP_SRVR/LSTN] INFO: Receive message...
[ZSTACKZNP_SRVR/LSTN] INFO: zstackpb zspbHandlePbCb: subsystemID:31, cmdId:20
[ZSTACKZNP_SRVR/LSTN] INFO: zstackpb afRegister: profileID:104
[ZSTACKZNP_SRVR/LSTN] INFO: znp_misc sendNPIExpectDefaultStatusZNP: subSys:4, cmdID:0, len:13
[ZSTACKZNP_SRVR/LSTN] INFO: preparing to send 13 bytes, subSys 0x04, cmdId 0x00, pData:
[ZSTACKZNP_SRVR/LSTN] INFO:  0x01
[ZSTACKZNP_SRVR/LSTN] INFO:  0x04
[ZSTACKZNP_SRVR/LSTN] INFO:  0x07
[ZSTACKZNP_SRVR/LSTN] INFO:  0x00
[ZSTACKZNP_SRVR/LSTN] INFO:  0x06
[ZSTACKZNP_SRVR/LSTN] INFO: [MUTEX] Lock SRSP Mutex[ZSTACKZNP_SRVR/LSTN] INFO:
[ZSTACKZNP_SRVR/LSTN] INFO: Waiting for synchronous response...
[ZSTACKZNP_SRVR/LSTN] INFO: [MUTEX] Wait for SRSP Cond signal...
[NWK_MGR/MAIN] INFO: Waiting for synchronous response...
[NWK_MGR/MAIN] INFO: [MUTEX] Wait for SRSP Cond signal...
[NWK_MGR/HNDL] INFO: [MUTEX] Wait for AREQ semaphore
[ZSTACKZNP_SRVR/LSTN] INFO: [MUTEX] SRSP Cond Wait timed out!
[ZSTACKZNP_SRVR/LSTN] INFO: [MUTEX] Unlock SRSP Mutex
[ZSTACKZNP_SRVR/LSTN] INFO: ...sent 8 bytes to Client
[ZSTACKZNP_SRVR/LSTN] INFO: !Done
[NWK_MGR/READ] INFO: Received 4 bytes,   subSys 0x71, cmdId 0x20, pData:
[NWK_MGR/READ] INFO:  0x8
[NWK_MGR/READ] INFO:  0x20
[NWK_MGR/READ] INFO:  0x10
[NWK_MGR/READ] INFO:  0x0
[NWK_MGR/READ] INFO: [MUTEX] SRSP Cond signal set
[NWK_MGR/READ] INFO: Client Read: (len 0): [NWK_MGR/MAIN] INFO: 0x08
[NWK_MGR/MAIN] INFO: [MUTEX] Unlock SRSP Mutex
AF Register Request Successful
[NWK_MGR/MAIN] INFO: preparing to send 90 bytes, subSys 0x11, cmdId 0x14, pData:
[NWK_MGR/MAIN] INFO:  0x14
[NWK_MGR/MAIN] INFO:  0x38
[NWK_MGR/MAIN] INFO:  0x40
[NWK_MGR/MAIN] INFO:  0x48
[NWK_MGR/MAIN] INFO:  0x50
[NWK_MGR/MAIN] INFO:  0x58
[NWK_MGR/MAIN] INFO:  0x60
[NWK_MGR/MAIN] INFO:  0x68
[NWK_MGR/MAIN] INFO:  0x70
[NWK_MGR/MAIN] INFO:  0x78
[NWK_MGR/MAIN] INFO:  0x80
[NWK_MGR/MAIN] INFO:  0x88
[NWK_MGR/MAIN] INFO:  0x90
[NWK_MGR/MAIN] INFO:  0x98
[NWK_MGR/MAIN] INFO:  0xA0
[NWK_MGR/MAIN] INFO:  0xA8
[NWK_MGR/MAIN] INFO:  0xB0
[NWK_MGR/MAIN] INFO:  0xB8
[NWK_MGR/MAIN] INFO:  0xC0
[NWK_MGR/MAIN] INFO:  0xC8
[NWK_MGR/MAIN] INFO:  0xD0
[NWK_MGR/MAIN] INFO:  0xD8
[NWK_MGR/MAIN] INFO:  0xE0
[NWK_MGR/MAIN] INFO:  0xE8
[NWK_MGR/MAIN] INFO:  0xF0
[NWK_MGR/MAIN] INFO:  0xF8
[ZSTACKZNP_SRVR/LSTN] INFO: zstackpb zspbHandlePbCb: subsystemID:31, cmdId:14
[NWK_MGR/READ] INFO: Received 4 bytes,   subSys 0x71, cmdId 0x14, pData:
[NWK_MGR/READ] INFO:  0x14
[NWK_MGR/READ] INFO: Client Read: (len 0): [NWK_MGR/MAIN] INFO: Waiting for synchronous response...
ZDO Callback Register Response Successful
NwkMgr sendSysNwkInfoReadReq:
[NWK_MGR/MAIN] INFO: preparing to send 2 bytes, subSys 0x11, cmdId 0x08, pData:
[ZSTACKZNP_SRVR/LSTN] INFO: zstackpb zspbHandlePbCb: subsystemID:31, cmdId:8
[ZSTACKZNP_SRVR/LSTN] INFO: preparing to send 0 bytes, subSys 0x05, cmdId 0x50, pData:
[ZSTACKZNP_SRVR/LSTN] INFO: zstackpb Sending Network Info Response
[ZSTACKZNP_SRVR/LSTN] INFO: znp_misc osal_nv_read: id:1, len:8
[ZSTACKZNP_SRVR/LSTN] INFO: preparing to send 3 bytes, subSys 0x01, cmdId 0x08, pData:
[NWK_MGR/MAIN] INFO: [MUTEX] SRSP Cond Wait timed out!
[NWK_MGR/MAIN] ERROR: Reading Local Network Information Failed
[NWK_MGR/MAIN] : Initialization failed. Quitting now. mhoyt
网关和协调器的串口通信是没有问题的。请问这可能是由什么问题导致的?
  • 目前的linux Gateway 的参考代码还不能直接和Z-Stack 3.0 ZNP使用,后续发布的版本才可以。
    建议先使用Z-Stack Home 1.2.2a的ZNP
  • 前段时间我也尝试调试过Linux gateway 配合Z-Stack 3.0 ZNP,结果总是莫名其表各种问题,基本上就是Gateway发过去的命令总是执行超时,用的也是UART口;
    后来gateway代码过于复杂,又转向尝试znp-host-framework,发现同样也是很多问题,比如3.0 zigbee协议部分实现了bdb接口,3.0协议也推荐使用bdb实现设备的建网、配对等等,但是znp-host-framework仍然用的是ZDO部分的接口包括消息回调,仍然都是ZDO的接口。
    至今也没有完全搞定ZNP和znp-host-framework之间的完全组网。
  • @hold li
    请教一下,我的linux gateway移植到其他平台的时候,总是编译不过。
    除了修改编译交叉环境变量和UART驱动部分代码后,还有哪些地方需要修改的?
  • 我的实践已经证明,只要是ARM LINUX都可以编译过去的,Android下面也是linux,我在台湾一家公司的SOC上跑Linux已经成功编译了,不是AM335x的armv7,是armv5ejs,把编译错误贴上来看看
  • @xiaohui bu 参考我的帖子http://blog.csdn.net/code_style/article/details/54375494#comments
  • 谢谢!目前gateway和znp通信正常了。
  • 您好,
           我正在mips平台上移植TI CC2530, 目前有遇到在執行NWK Mgr 時,  NPI deamon收到unknown request 而發生error
           請問您有遇到過嗎?
           謝謝!
    # ./zigbeeHAgw mips
    running zigbeegw.scr on an mips
    done processing arguments, board type mips, target mips
    NPI                 is 'NPI_lnx_mips_server'
    Zstack linux server is 'ZLSZNP_mips'
    gateway server      is 'GATEWAY_SRVR_mips'
    network manager     is 'NWKMGR_SRVR_mips'
    OTA server        is 'OTA_SRVR_mips'
    making sure there are no lingering servers...
    there are 0 NIP servers
    there are 0 ZLS servers
    there are 0 GATEWAY servers
    there are 0 NWKMGR servers
    there are 0 OTA servers
    (total 0)
    done
    (total 0)
    done
    skipping zigbee reset
    Starting the ZigBee gateway subsystem
    starting NPI, cmd ' ./NPI_lnx_mips_server NPI_Gateway.cfg ' atThu Jan  1 08:01:10 GMT 1970
    will delay 4 secs before starting Zstack
    deviceKey = 0  (0 )
    devPath = '/dev/ttyS1'
    logPath = '/tmp/NpiLnxLog.txt'
    ... freeing memory (ret 0)
    waiting for first connection on #4...
    NPI started (pid 1339) at Thu Jan  1 08:01:14 GMT 1970
    starting ZLSZNP, cmd ' ' atThu Jan  1 08:01:14 GMT 1970
    will delay 4 secs before starting GW
    Trying to connect...
    Connected to #6.
    Connected.
    Port: 166201832
    Following IP addresses are available:
     IPv4: interface: lo     IP Address 127.0.0.1
     IPv4: interface: br0    IP Address 192.168.1.12
     IPv6: interface: lo     IP Address ::1
     IPv6: interface: eth0   IP Address fe80::2e0:4cff:fe81:adc3
     IPv6: interface: eth0.3         IP Address fe80::2e0:4cff:fe81:adc3
     IPv6: interface: eth0.5         IP Address fe80::2e0:4cff:fe81:adc3
     IPv6: interface: nas0   IP Address fe80::200:ff:fe01:2
     IPv6: interface: br0    IP Address fe80::1
     IPv6: interface: nas0_0         IP Address fe80::2e0:4cff:fe81:adc8
    The socket will listen on the following IP addresses:
      IPv4: 0.0.0.0
      IPv6: ::
    0.0.0.0 means it will listen to all available IP address
    waiting for first connection on #6...
    ZLSZNP started (pid 1345) at Thu Jan  1 08:01:19 GMT 1970
    starting NETWORK_MGR, cmd './NWKMGR_SRVR_mips 127.0.0.1:2536 ' at Thu Jan  1 08:01:19 GMT 1970
    will delay 1 secs after starting netmgr
    Connected to #7.
    Connected.
    Port: 2540
      IPv4: 0.0.0.0
      IPv6: ::
    [nmRegEndpoint][4493] len 21
    Can only accept AREQ or SREQ for now...
    Unknown: (len 24) 0x15 0x00 0x31 0x20 0x08 0x20 0x10 0x01 0x1A 0x0D 0x08 0x01 0x10 0x84 0x02 0x18 0x07 0x20 0x00 0x28 0x00 0x30 0x06 0x20
    [ERR] npi_ipc_errno 0x01030400
    Exit socket while loop
    connect: No such file or directory
    ... freeing memory (ret 1)
    recv: Connection reset by peer
    NETWORK MANAGER started (pid 1352) at Thu Jan  1 08:01:20 GMT 1970
  • 我也遇到了运行./zigbeeHAgw bbb出错,请问你知道是什么问题吗,求指教,谢谢
    root@debian:/zigbee/servers# ./zigbeeHAgw bbb
    running zigbeegw.scr on an ARM
    gpioCfg 0x1df04
    gpioCfg[0] 0x16871a0
    gpioCfg[0].gpio 0x16871b0
    gpioCfg[0].levelshifter 0x1687331
    gpioCfg[1] 0x16871a4
    gpioCfg[1].gpio 0x16874b8
    gpioCfg[1].levelshifter 0x1687639
    gpioCfg[2] 0x16871a8
    gpioCfg[2].gpio 0x16877c0
    gpioCfg[2].levelshifter 0x1687941
    Serial Config Parsing:
    - Section: DEVICE
    - Key: deviceKey
    Found section [PORT]es
    Found section [DEVICE]
    Found wanted section!
    Line to process deviceKey=0 ; UART (strlen=18)
    Found key 'deviceKey' in 'deviceKey=0 ; UART'
    Found value '0 '
    Found value2 '0 '
    deviceKey = 0 (0 )
    - Section: DEVICE
    - Key: devPath
    Line to process #deviceKey=1 ; SPI (strlen=18)
    Line to process (strlen=0)
    Line to process devPath="/dev/ttymxc1" ; UART/CDC (strlen=33)
    Found key 'devPath' in 'devPath="/dev/ttymxc1" ; UART/CDC'
    Found value '/dev/ttymxc1'
    Found value2 '/dev/ttymxc1'
    devPath = '/dev/ttymxc1'
    - Section: LOG
    - Key: log
    Found section [UART]es
    Found section [SPI]tes
    Found section [LOG]tes
    Line to process log="./NpiLnxLog.txt" ; file to log all event/error (strlen=51)
    Found key 'log' in 'log="./NpiLnxLog.txt" ; file to log all event/error'
    Found value './NpiLnxLog.txt'
    Found value2 './NpiLnxLog.txt'
    logPath = './NpiLnxLog.txt'
    - Section: UART
    - Key: speed
    Line to process speed=115200 ; speed (strlen=20)
    Found key 'speed' in 'speed=115200 ; speed'
    Found value '115200 '
    Found value2 '115200 '
    - Section: UART
    - Key: flowcontrol
    Line to process flowcontrol=0 ; 1=enabled 0=disable (strlen=35)
    Found key 'flowcontrol' in 'flowcontrol=0 ; 1=enabled 0=disable'
    Found value '0 '
    Found value2 '0 '
    [UART] Opening device /dev/ttymxc1
    [UART] Install IO signal handler
    [UART] Baud rate set to 115200 (0x001002)
    [UART] c_cflag set to 0x0018B2
    - Section: PORT
    - Key: port
    Line to process port=2533 (strlen=9)
    Found key 'port' in 'port=2533'
    Found value '2533'
    Found value2 '2533'
    Port: 2533
    IPv4: interface: eth0 IP Address 192.168.1.217
    IPv6: interface: eth0 IP Address fe80::2aa:eeff:febb:eecc
    IPv4: 0.0.0.0
    IPv6: ::
    waiting for first connection on #3...
    [UART] Wait for mutex in rx entry:
    NPI started (pid 21284) at Wed Jan 24 11:03:50 UTC 2018
    Connected to #5.(127.0.0.1 / ::0.240.254.118)
    Receive message...
    NPI SREQ: (len 5) 0x02 0x25 0x3E 0xFF 0xFF
    ZLSZNP started (pid 21303) at Wed Jan 24 11:03:54 UTC 2018
    [NWK_MGR/MAIN] : argv[0] = ./NWKMGR_SRVR_arm
    NETWORK MANAGER started (pid 21323) at Wed Jan 24 11:03:55 UTC 2018
    [GATEWAY/MAIN] :
    [GATEWAY/MAIN] : ************************************************
    [GATEWAY/MAIN] : * Gateway Server v1.0.1 *
    [GATEWAY/MAIN] : * The following are the avaible key commands: *
    [GATEWAY/MAIN] : * Exit Program. - q *
    [GATEWAY/MAIN] DEBUG: parsing Poll Control fields
    [GATEWAY/MAIN] DEBUG: parsing defines
    [GATEWAY/MAIN] DEBUG: parsing attributes
    [GATEWAY/MAIN] DEBUG: parsing attrlists
    [GATEWAY/MAIN] DEBUG: parsing clusterlists
    [GATEWAY/MAIN] DEBUG: parsing endpointdefs
    [GATEWAY/MAIN] DEBUG: parsing endpoints
    [UART] Send synch data timed out
    [ERR] SRSP: npi_ipc_errno 0x02040100
    !Done
    Synchronous Request Timeout...Receive message...
    NPI SREQ: (len 11) 0x08 0x21 0x09 0x84 0x00 0x00 0x04 0x00 0x08 0x00 0x00
    GATEWAY SERVER started (pid 21333) at Wed Jan 24 11:03:57 UTC 2018
    [OTASRVR/MAIN] :
    [OTASRVR/MAIN] : ************************************************
    [OTASRVR/MAIN] : * OTA Upgrade Server 1.0.1 *
    [OTASRVR/MAIN] : * The following are the avaible key commands: *
    [OTASRVR/MAIN] : * Exit Program. - q *
    [OTASRVR/MAIN] DEBUG: Registering OTA end point 0xe, profile id 0x104 device id 0x0
    [OTASRVR/MAIN] DEBUG: Sending AF Register Request.
    OTA SERVER started (pid 21348) at Wed Jan 24 11:03:59 UTC 2018
    [OTASRVR/MAIN] DEBUG: apicSendSynchData_pRsp < 0
    [OTASRVR/MAIN] DEBUG: AF Register Request status 0x3
    [OTASRVR/MAIN] DEBUG: *** Error doing AF Register , return status 0x3
    [OTASRVR/MAIN] :
    Error - Could not register OTA endpoint with zstackserver.Exiting...
    starting tracker with our pid ./zigbeeHAgw and pid list 21284 21303 21333 21348
    tracking 4 pids, 21284 21303 21333 21348
    when we see something missing we will send a SIGUSR2 to pid 21216
    NETWORK MANAGER exited with code 255 at Wed Jan 24 11:04:00 UTC 2018
    !Done
    NPI SREQ: (len 9) 0x06 0x21 0x09 0x83 0x00 0x00 0x02 0xFF 0xFF
    killall: OTA_SRVR_arm: no process killed
    ^Ccaught SIGTERM, killing all the servers and cleaning up
    terminating zigbeeHAGW (pid 21216)
    Killed
    这是运行的结果,每次都是报这个错误
    [OTASRVR/MAIN] :
    是OAT服务器的错误吗?请问怎么解决这个问题呢,谢谢
