Other Parts Discussed in Thread: Z-STACK
采用\Texas Instruments\Z-Stack Home 1.2.2a.44539\Projects\zstack\ZNP\CC253x
设定znpCfg1=0; \\使用串口
uartConfig.flowControl = FALSE; \\禁用流控
编译下载后,运行,检测到串口输出
FE 06 41 80 01 02 00 02 06 03 C3
然后一直重复发送下面的信息
FE 5D 4B 80 64 00 00 00 00 08 00 00 FF FF 00 00 FE FF FE FF FE FF 00 00 00 00 00 00 00 00 00 00 39 95 E9 0A 00 4B 12 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01 01 00 00 00 00 01 01 01 EC FE 5D 4B 80 64 00 00 00 00 08 00 00 FF FF 00 00 FE FF FE FF FE FF 00 00 00 00 00 00 00 00 00 00 39 95 E9 0A 00 4B 12 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01 01 00 00 00 00 01 01 01 EC FE 5D 4B 80 64 00 00 00 00 08 00 00 FF FF 00 00 FE FF FE FF FE FF 00 00 00 00 00 00 00 00 00 00 39 95 E9 0A 00 4B 12 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01 01 00 00 00 00 01 01 01 EC
查询了ZNP接口定义:未找打4B 80这个命令定义
请问这里的朋友,是否有人知道这个是什么命令?这是什么问题导致的?
