zigbee 是怎样注册,产生,处理 按键事件的?(转)
当硬件有按键按下时调用
uint8 OnBoard_SendKeys( uint8 keys, uint8 state )
  keyChange_t *msgPtr;
  if ( registeredKeysTaskID != NO_TASK_ID )
    // Send the address to the task
    msgPtr = (keyChange_t *)osal_msg_allocate( sizeof(keyChange_t) );
    if ( msgPtr )
      msgPtr->hdr.event = KEY_CHANGE;
      msgPtr->state = state;
      msgPtr->keys = keys;
      osal_msg_send( registeredKeysTaskID, (uint8 *)msgPtr );
    return ( ZSuccess );
  else
    return ( ZFailure );
调用osal_msg_send( registeredKeysTaskID, (uint8 *)msgPtr );  将消息发送个任务registeredKeysTaskID;
按键事件能且只能在一个任务中注册;我们看看registeredKeysTaskID他是在被注册到哪个任务中去了;
uint8 RegisterForKeys( uint8 task_id )
  // Allow only the first task
  if ( registeredKeysTaskID == NO_TASK_ID )
    registeredKeysTaskID = task_id;
    return ( true );
  else
    return ( false );
GenericApp.c中我们看到 按键事件被注册到APP任务中;
RegisterForKeys( GenericApp_TaskID );
总结下按键事件:
在应用程序中,用户将按键事件注册到应用层任务中, 当硬件检测到有按键事件发生时,将消息发送个应用层的任务ID交由应用程序处理;
UINT16 GenericApp_ProcessEvent( byte task_id, UINT16 events )
{if ( events & SYS_EVENT_MSG )
    MSGpkt = (afIncomingMSGPacket_t *)osal_msg_receive( GenericApp_TaskID );
    while ( MSGpkt )
      switch ( MSGpkt->hdr.event )
case KEY_CHANGE:
          GenericApp_HandleKeys( ((keyChange_t *)MSGpkt)->state, ((keyChange_t *)MSGpkt)->keys );
          break;
  osal_msg_deallocate( (uint8 *)MSGpkt );
      // Next
    // return unprocessed events
    return (events ^ SYS_EVENT_MSG);
