当终端不能连接到zigbee网络,就会重启。请问能不能不重启,只是重新配置下zigbee网络。
if ( events & ZDO_DEVICE_RESET )
#ifdef ZBA_FALLBACK_NWKKEY
if ( devState == DEV_END_DEVICE_UNAUTH )
ZDSecMgrFallbackNwkKey();
else
#endif
// Set the NV startup option to force a "new" join.
zgWriteStartupOptions( ZG_STARTUP_SET, ZCD_STARTOPT_DEFAULT_NETWORK_STATE );
// The device has been in the UNAUTH state, so reset
// Note: there will be no return from this call
SystemResetSoft();
