Other Parts Discussed in Thread: CC2530, CC2538, CC2652R, Z-STACK
我想要使用cc2530的串口功能,所以在预编译的选项中将xZTOOL_P1改为了ZTOOL_P1,然后进行编译,结果发生了错误,然后我恢复了之前的操作,然后再预编译选项中加入了HAL_UART=TRUE,是同样的结果。(PS.为了排除是我程序的错误,我打开了一个新例程,重复了上述操作,还是发生了同样的错误),下边是IAR报出的错误:
Error[e16]: Segment XDATA_Z (size: 0x1ca4 align: 0) is too long for segment definition. At least 0xa5 more bytes needed. The problem occurred while processing the
