ZNP 能支持接入IAS设备吗
The ZigBeeNetworkProcessor only implements up to the APS/NWK layer and the ZDO - anything higher, like Application Profiles, and specifically, ZigBee Cluster Library Profiles like IAS, have to be implemented on the host which is using the ZNP.
需要从使用ZNP的host进行配置
