Other Parts Discussed in Thread: Z-STACK
请问zstack中,有请查看绑定表、路由表、邻居表、等信息的接口函数吗??
基于协议栈开发, NWK层的路由表,邻居表一般不会直接调用接口,因此也没有很具体的说明.
邻居表:- Components\stack\nwk\nwk_util.h
Filename: nwk_util.h
Revised: $Date: 2015-02-16 12:23:39 -0800 (Mon, 16 Feb 2015) $
Revision: $Revision: 42629 $
Description: Network layer utility functions.
Copyright 2004-2015 Texas Instruments Incorporated. All rights reserved.
IMPORTANT: Your use of this Software is limited to those specific rights
granted under the terms of a software license agreement between the user
who downloaded the software, his/her employer (which must be your employer)
and Texas Instruments Incorporated (the "License"). You may not use this
Software unless you agree to abide by the terms of the License. The License
limits your use, and you acknowledge, that the Software may not be modified,
copied or distributed unless embedded on a Texas Instruments microcontroller
or used solely and exclusively in conjunction with a Texas Instruments radio
frequency transceiver, which is integrated into your product. Other than for
the foregoing purpose, you may not use, reproduce, copy, prepare derivative
works of, modify, distribute, perform, display or sell this Software and/or
its documentation for any purpose.
YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
(INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
Should you have any questions regarding your right to use this Software,
contact Texas Instruments Incorporated at www.TI.com.
* Neighbor Table Functions
#define NWKNEIGHBOR_NOT_FOUND 0x00 // device not found
#define NWKNEIGHBOR_FOUND_SHORT 0x0A // found matching short, but
// extended address doesn't match
#define NWKNEIGHBOR_FOUND_IEEE 0xA0 // found matching extended, but
// short address doesn't match
#define NWKNEIGHBOR_FOUND 0xAA // found matching extended and short
// Neighbor table entry
typedef struct
uint16 neighborAddress;
uint8 neighborExtAddr[Z_EXTADDR_LEN];
uint16 panId;
uint8 age; // number of nwkLinkStatusPeriod since last link status
linkInfo_t linkInfo;
} neighborEntry_t;
extern neighborEntry_t neighborTable[];
extern neighborEntry_t *nwkNeighborFind( uint16 nwkAddr, uint16 panID );
extern neighborEntry_t *nwkNeighborFindEmptySlot( void );
extern uint16 nwkNeighborCount( void );
extern void nwkNeighborRemove( uint16 NeighborAddress, uint16 PanId );
extern neighborEntry_t *nwkNeighborGetWithIndex( uint16 Index );
extern void nwkNeighborInitTable( void );
extern void nwkNeighborClearEntry( neighborEntry_t *entry );
extern void nwkNeighborKeepPANID( uint16 PanID );
extern linkInfo_t *nwkNeighborGetLinkInfo( uint16 NeighborAddress, uint16 panId );
extern byte nwkNeighborCheckAddr( uint16 nwkAddr, uint8 *extAddr );
extern void nwkNeighborUpdateAge( void );
extern uint16 nwkNeighborFindRandom( uint16 skipAddr, uint16 skipAddr2, uint16 skipAddr3 );
extern void nwkNeighborUpdateNwkAddr( uint16 nwkAddr, uint8 *ieeeAddr );
extern void nwkNeighborAdd( uint16 nwkAddr, uint16 panId, uint8 linkQuality );
extern uint8 nlmeConflictedAddr( uint16 addr );
路由表-C:\Texas Instruments\Z-Stack 3.0.0\Components\stack\nwk\rtg.h
* TYPEDEFS
typedef enum{
RTG_SUCCESS,
RTG_FAIL,
RTG_TBL_FULL,
RTG_HIGHER_COST,
RTG_NO_ENTRY,
RTG_INVALID_PATH,
RTG_INVALID_PARAM,
RTG_SRC_TBL_FULL
} RTG_Status_t;
// status values for routing entries
#define RT_INIT 0
#define RT_ACTIVE 1
#define RT_DISC 2
#define RT_LINK_FAIL 3
#define RT_REPAIR 4
// Routing table entry
// Notice, if you change this structure, you must also change
// rtgItem_t in ZDProfile.h
typedef struct
uint16 dstAddress;
uint16 nextHopAddress;
byte expiryTime;
byte status;
uint8 options;
} rtgEntry_t;
// Routing table
rtgEntry_t rtgTable[MAX_RTG_ENTRIES];
绑定表 -
C:\Texas Instruments\Z-Stack 3.0.0\Components\stack\nwk\BindingTable.h
Filename: BindingTable.h
Revised: $Date: 2007-10-28 18:41:49 -0700 (Sun, 28 Oct 2007) $
Revision: $Revision: 15799 $
Description: Device binding table.
Copyright 2004-2007 Texas Instruments Incorporated. All rights reserved.
PROVIDED 揂S IS?WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
#ifndef BINDINGTABLE_H
#define BINDINGTABLE_H
#ifdef __cplusplus
extern "C" {
#endif
* INCLUDES
#include "ZComdef.h"
#include "osal.h"
#include "nwk.h"
#include "AssocList.h"
* MACROS
* CONSTANTS
#define MAX_DEVICE_PAIRS 255 // temp value
#define DSTGROUPMODE_ADDR 0
#define DSTGROUPMODE_GROUP 1
* TYPEDEFS
typedef struct
uint16 numRecs;
} nvBindingHdr_t;
// Don't use sizeof( BindingEntry_t ) use gBIND_REC_SIZE when calculating
// the size of each binding table entry. gBIND_REC_SIZE is defined in nwk_global.c.
typedef struct
// No src address since the src is always the local device
uint8 srcEP;
uint8 dstGroupMode; // Destination address type; 0 - Normal address index, 1 - Group address
uint16 dstIdx; // This field is used in both modes (group and non-group) to save NV and RAM space
// dstGroupMode = 0 - Address Manager index
// dstGroupMode = 1 - Group Address
uint8 dstEP;
uint8 numClusterIds;
uint16 clusterIdList[MAX_BINDING_CLUSTER_IDS];
// Don't use MAX_BINDING_CLUSTERS_ID when
// using the clusterIdList field. Use
// gMAX_BINDING_CLUSTER_IDS
} BindingEntry_t;
* GLOBAL VARIABLES
// BindingTable is defined in nwk_globals.c and NWK_MAX_BINDING_ENTRIES
// is defined in f8wConfig.cfg. Don't use NWK_MAX_BINDING_ENTRIES as the
// number of records - use gNWK_MAX_BINDING_ENTRIES.
extern BindingEntry_t BindingTable[];
* FUNCTIONS
* This function is used to initialise the binding table
extern void InitBindingTable( void );
* Removes a binding table entry.
extern byte bindRemoveEntry( BindingEntry_t *pBind );
* Is the clusterID in the clusterID list?
extern byte bindIsClusterIDinList( BindingEntry_t *entry, uint16 clusterId );
* Removes a ClusterID from a list of ClusterIDs.
extern byte bindRemoveClusterIdFromList( BindingEntry_t *entry, uint16 clusterId );
* Adds a ClusterID to a list of ClusterIDs.
extern byte bindAddClusterIdToList( BindingEntry_t *entry, uint16 clusterId );
* Finds an existing src/epint to dst/epint bind record
extern BindingEntry_t *bindFindExisting( byte srcEpInt,
zAddrType_t *dstShortAddr, byte dstEpInt );
* Remove binds(s) associated to Source address, endpoint and cluster.
extern void nwk_remove_bindSrc( zAddrType_t *srcAddr, byte epInt,
byte numClusterIds, uint16 *clusterIds );
* Remove bind(s) associated to a address (source or destination)
extern void bindRemoveDev( zAddrType_t *shortAddr);
* Remove bind(s) associated to a address (source)
extern void bindRemoveSrcDev( uint8 ep );
* Calculate the number items this device is bound to.
extern byte bindNumBoundTo( zAddrType_t *devAddr, byte devEpInt, byte srcMode );
* Count the number of reflections.
extern uint16 bindNumReflections( uint8 ep, uint16 clusterID );
* Finds the binding entry for the source address,
* endpoint and clusterID passed in as a parameter.
extern BindingEntry_t *bindFind( uint8 ep, uint16 clusterID, uint8 skipping );
* Processes the Hand Binding Timeout.
extern void nwk_HandBindingTimeout( void );
* Initialize Binding Table NV Item
extern byte BindInitNV( void );
extern void BindSetDefaultNV( void );
* Restore Binding Table from NV
extern uint16 BindRestoreFromNV( void );
* Write Binding Table out to NV
extern void BindWriteNV( void );
* Update network address in binding table
extern void bindUpdateAddr( uint16 oldAddr, uint16 newAddr );
* This function is used to Add an entry to the binding table
extern BindingEntry_t *bindAddEntry( byte srcEpInt,
zAddrType_t *dstAddr, byte dstEpInt,
* This function returns the number of binding table entries
extern uint16 bindNumOfEntries( void );
* This function returns the number of binding entries
* possible and used.
extern void bindCapacity( uint16 *maxEntries, uint16 *usedEntries );
* FUNCTION POINTERS
extern BindingEntry_t *(*pbindAddEntry)( byte srcEpInt,
extern uint16 (*pbindNumOfEntries)( void );
extern void (*pbindRemoveDev)( zAddrType_t *Addr );
extern byte (*pBindInitNV)( void );
extern void (*pBindSetDefaultNV)( void );
* Restore binding table from NV
extern uint16 (*pBindRestoreFromNV)( void );
* Write binding table to NV
extern void (*pBindWriteNV)( void );
* Convert address manager index to zAddrType_t for an extended address
extern uint8 bindingAddrMgsHelperConvert( uint16 idx, zAddrType_t *addr );
* Convert address manager index to short address
extern uint16 bindingAddrMgsHelperConvertShort( uint16 idx );
* Get a pointer to the Nth valid binding table entry.
extern BindingEntry_t *GetBindingTableEntry( uint16 Nth );
#ifdef __cplusplus
#endif
#endif /* BINDINGTABLE_H */
