zigbee开发套件资料中,项目实践中的无线IC卡例程文件,协调器程序下载不进协调器
Filename: SampleApp.c
Revised: $Date: 2009-03-18 15:56:27 -0700 (Wed, 18 Mar 2009) $
Revision: $Revision: 19453 $
Description: Sample Application (no Profile).
Copyright 2007 Texas Instruments Incorporated. All rights reserved.
IMPORTANT: Your use of this Software is limited to those specific rights
granted under the terms of a software license agreement between the user
who downloaded the software, his/her employer (which must be your employer)
and Texas Instruments Incorporated (the "License"). You may not use this
Software unless you agree to abide by the terms of the License. The License
limits your use, and you acknowledge, that the Software may not be modified,
copied or distributed unless embedded on a Texas Instruments microcontroller
or used solely and exclusively in conjunction with a Texas Instruments radio
frequency transceiver, which is integrated into your product. Other than for
the foregoing purpose, you may not use, reproduce, copy, prepare derivative
works of, modify, distribute, perform, display or sell this Software and/or
its documentation for any purpose.
YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
PROVIDED 揂S IS?WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
(INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
Should you have any questions regarding your right to use this Software,
contact Texas Instruments Incorporated at www.TI.com.
This application isn't intended to do anything useful, it is
intended to be a simple example of an application's structure.
This application sends it's messages either as broadcast or
broadcast filtered group messages. The other (more normal)
message addressing is unicast. Most of the other sample
applications are written to support the unicast message model.
Key control:
SW1: Sends a flash command to all devices in Group 1.
SW2: Adds/Removes (toggles) this device in and out
of Group 1. This will enable and disable the
reception of the flash command.
* INCLUDES
#include "OSAL.h"
#include "ZGlobals.h"
#include "AF.h"
#include "aps_groups.h"
#include "ZDApp.h"
#include "SampleApp.h"
#include "SampleAppHw.h"
#include "OnBoard.h"
/* HAL */
#include "hal_lcd.h"
#include "hal_led.h"
#include "hal_key.h"
#include "MT_UART.h" //此处用于串口
#include "MT_APP.h"
#include "MT.h"
#include "IC.h" //IC相关函数定义
* MACROS
* CONSTANTS
* TYPEDEFS
* GLOBAL VARIABLES
// This list should be filled with Application specific Cluster IDs.
const cId_t SampleApp_ClusterList[SAMPLEAPP_MAX_CLUSTERS] =
SAMPLEAPP_PERIODIC_CLUSTERID,
SAMPLEAPP_FLASH_CLUSTERID
const SimpleDescriptionFormat_t SampleApp_SimpleDesc =
SAMPLEAPP_ENDPOINT, // int Endpoint;
SAMPLEAPP_PROFID, // uint16 AppProfId[2];
SAMPLEAPP_DEVICEID, // uint16 AppDeviceId[2];
SAMPLEAPP_DEVICE_VERSION, // int AppDevVer:4;
SAMPLEAPP_FLAGS, // int AppFlags:4;
SAMPLEAPP_MAX_CLUSTERS, // uint8 AppNumInClusters;
(cId_t *)SampleApp_ClusterList, // uint8 *pAppInClusterList;
(cId_t *)SampleApp_ClusterList // uint8 *pAppInClusterList;
// This is the Endpoint/Interface description. It is defined here, but
// filled-in in SampleApp_Init(). Another way to go would be to fill
// in the structure here and make it a "const" (in code space). The
// way it's defined in this sample app it is define in RAM.
endPointDesc_t SampleApp_epDesc;
* EXTERNAL VARIABLES
* EXTERNAL FUNCTIONS
* LOCAL VARIABLES
uint8 SampleApp_TaskID; // Task ID for internal task/event processing
// This variable will be received when
// SampleApp_Init() is called.
devStates_t SampleApp_NwkState;
uint8 SampleApp_TransID; // This is the unique message ID (counter)
afAddrType_t SampleApp_Periodic_DstAddr;
afAddrType_t SampleApp_Flash_DstAddr;
afAddrType_t Point_To_Point_DstAddr;//网蜂点对点通信定义
aps_Group_t SampleApp_Group;
uint8 SampleAppPeriodicCounter = 0;
uint8 SampleAppFlashCounter = 0;
* LOCAL FUNCTIONS
void SampleApp_HandleKeys( uint8 shift, uint8 keys );
void SampleApp_MessageMSGCB( afIncomingMSGPacket_t *pckt );
void SampleApp_SendPeriodicMessage( void );
void SampleApp_SendFlashMessage( uint16 flashTime );
void SampleApp_SendPointToPointMessage(void );
* NETWORK LAYER CALLBACKS
* PUBLIC FUNCTIONS
* @fn SampleApp_Init
* @brief Initialization function for the Generic App Task.
* This is called during initialization and should contain
* any application specific initialization (ie. hardware
* initialization/setup, table initialization, power up
* notificaiton ... ).
* @param task_id - the ID assigned by OSAL. This ID should be
* used to send messages and set timers.
* @return none
void SampleApp_Init( uint8 task_id )
SampleApp_TaskID = task_id;
SampleApp_NwkState = DEV_INIT;
SampleApp_TransID = 0;
MT_UartInit();//串口初始化
MT_UartRegisterTaskID(task_id);//登记任务号
HalUARTWrite(0,"Hello World\n",12); //(串口0,'字符',字符个数。)
IC_Init(); //初始化IC模块
// Device hardware initialization can be added here or in main() (Zmain.c).
// If the hardware is application specific - add it here.
// If the hardware is other parts of the device add it in main().
#if defined ( BUILD_ALL_DEVICES )
// The "Demo" target is setup to have BUILD_ALL_DEVICES and HOLD_AUTO_START
// We are looking at a jumper (defined in SampleAppHw.c) to be jumpered
// together - if they are - we will start up a coordinator. Otherwise,
// the device will start as a router.
if ( readCoordinatorJumper() )
zgDeviceLogicalType = ZG_DEVICETYPE_COORDINATOR;
else
zgDeviceLogicalType = ZG_DEVICETYPE_ROUTER;
#endif // BUILD_ALL_DEVICES
#if defined ( HOLD_AUTO_START )
// HOLD_AUTO_START is a compile option that will surpress ZDApp
// from starting the device and wait for the application to
// start the device.
ZDOInitDevice(0);
#endif
// Setup for the periodic message's destination address
// Broadcast to everyone
SampleApp_Periodic_DstAddr.addrMode = (afAddrMode_t)AddrBroadcast;
SampleApp_Periodic_DstAddr.endPoint = SAMPLEAPP_ENDPOINT;
SampleApp_Periodic_DstAddr.addr.shortAddr = 0xFFFF;
// Setup for the flash command's destination address - Group 1
SampleApp_Flash_DstAddr.addrMode = (afAddrMode_t)afAddrGroup;
SampleApp_Flash_DstAddr.endPoint = SAMPLEAPP_ENDPOINT;
SampleApp_Flash_DstAddr.addr.shortAddr = SAMPLEAPP_FLASH_GROUP;
// 网蜂点对点通讯定义
Point_To_Point_DstAddr.addrMode = (afAddrMode_t)Addr16Bit;//点播
Point_To_Point_DstAddr.endPoint = SAMPLEAPP_ENDPOINT;
Point_To_Point_DstAddr.addr.shortAddr = 0x0000; //发给协调器
// Fill out the endpoint description.
SampleApp_epDesc.endPoint = SAMPLEAPP_ENDPOINT;
SampleApp_epDesc.task_id = &SampleApp_TaskID;
SampleApp_epDesc.simpleDesc
= (SimpleDescriptionFormat_t *)&SampleApp_SimpleDesc;
SampleApp_epDesc.latencyReq = noLatencyReqs;
// Register the endpoint description with the AF
afRegister( &SampleApp_epDesc );
// Register for all key events - This app will handle all key events
RegisterForKeys( SampleApp_TaskID );
// By default, all devices start out in Group 1
SampleApp_Group.ID = 0x0001;
osal_memcpy( SampleApp_Group.name, "Group 1", 7 );
aps_AddGroup( SAMPLEAPP_ENDPOINT, &SampleApp_Group );
#if defined ( LCD_SUPPORTED )
HalLcdWriteString( "SampleApp", HAL_LCD_LINE_1 );
#endif
* @fn SampleApp_ProcessEvent
* @brief Generic Application Task event processor. This function
* is called to process all events for the task. Events
* include timers, messages and any other user defined events.
* @param task_id - The OSAL assigned task ID.
* @param events - events to process. This is a bit map and can
* contain more than one event.
* @return none
uint16 SampleApp_ProcessEvent( uint8 task_id, uint16 events )
afIncomingMSGPacket_t *MSGpkt;
(void)task_id; // Intentionally unreferenced parameter
if ( events & SYS_EVENT_MSG )
MSGpkt = (afIncomingMSGPacket_t *)osal_msg_receive( SampleApp_TaskID );
while ( MSGpkt )
switch ( MSGpkt->hdr.event )
// Received when a key is pressed
case KEY_CHANGE:
SampleApp_HandleKeys( ((keyChange_t *)MSGpkt)->state, ((keyChange_t *)MSGpkt)->keys );
break;
// Received when a messages is received (OTA) for this endpoint
case AF_INCOMING_MSG_CMD:
SampleApp_MessageMSGCB( MSGpkt );
break;
// Received whenever the device changes state in the network
case ZDO_STATE_CHANGE:
SampleApp_NwkState = (devStates_t)(MSGpkt->hdr.status);
if ( //(SampleApp_NwkState == DEV_ZB_COORD)|| //协调器不给自己点播
(SampleApp_NwkState == DEV_ROUTER)
|| (SampleApp_NwkState == DEV_END_DEVICE) )
// Start sending the periodic message in a regular interval.
osal_start_timerEx( SampleApp_TaskID,
SAMPLEAPP_SEND_PERIODIC_MSG_EVT,
SAMPLEAPP_SEND_PERIODIC_MSG_TIMEOUT );
else
// Device is no longer in the network
break;
default:
break;
// Release the memory
osal_msg_deallocate( (uint8 *)MSGpkt );
// Next - if one is available
// return unprocessed events
return (events ^ SYS_EVENT_MSG);
// Send a message out - This event is generated by a timer
// (setup in SampleApp_Init()).
if ( events & SAMPLEAPP_SEND_PERIODIC_MSG_EVT )
// Send the periodic message
//检查IC状态 400ms次
SampleApp_SendPointToPointMessage();//此处替换成点播函数
// Setup to send message again in normal period (+ a little jitter)
osal_start_timerEx( SampleApp_TaskID, SAMPLEAPP_SEND_PERIODIC_MSG_EVT,
(SAMPLEAPP_SEND_PERIODIC_MSG_TIMEOUT + (osal_rand() & 0x00FF)) );
return (events ^ SAMPLEAPP_SEND_PERIODIC_MSG_EVT);
// Discard unknown events
return 0;
* Event Generation Functions
* @fn SampleApp_HandleKeys
* @brief Handles all key events for this device.
* @param shift - true if in shift/alt.
* @param keys - bit field for key events. Valid entries:
* HAL_KEY_SW_2
* HAL_KEY_SW_1
* @return none
(void)shift; // Intentionally unreferenced parameter
if ( keys & HAL_KEY_SW_1 )
/* This key sends the Flash Command is sent to Group 1.
* This device will not receive the Flash Command from this
* device (even if it belongs to group 1).
SampleApp_SendFlashMessage( SAMPLEAPP_FLASH_DURATION );
if ( keys & HAL_KEY_SW_2 )
/* The Flashr Command is sent to Group 1.
* This key toggles this device in and out of group 1.
* If this device doesn't belong to group 1, this application
* will not receive the Flash command sent to group 1.
aps_Group_t *grp;
grp = aps_FindGroup( SAMPLEAPP_ENDPOINT, SAMPLEAPP_FLASH_GROUP );
if ( grp )
// Remove from the group
aps_RemoveGroup( SAMPLEAPP_ENDPOINT, SAMPLEAPP_FLASH_GROUP );
else
// Add to the flash group
* LOCAL FUNCTIONS
* @fn SampleApp_MessageMSGCB
* @brief Data message processor callback. This function processes
* any incoming data - probably from other devices. So, based
* on cluster ID, perform the intended action.
* @param none
* @return none
void SampleApp_MessageMSGCB( afIncomingMSGPacket_t *pkt )
uint16 flashTime;
/*16进制转ASCII码表-网蜂*/
uint8 asc_16[16]={'0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'},i;
uint8 CARD_ID[8];
switch ( pkt->clusterId )
case SAMPLEAPP_POINT_TO_POINT_CLUSTERID:
/****16进制转ASC码********/
for(i=0;i<4;i++)
CARD_ID[i*2]=asc_16[(pkt->cmd.Data[i])/16];
CARD_ID[i*2+1]=asc_16[(pkt->cmd.Data[i])%16];
/*串口打印*/
HalUARTWrite(0,"The Card ID is: ",16);
HalUARTWrite(0,CARD_ID,8);
HalUARTWrite(0,"\n",1); // 回车换行
break;
case SAMPLEAPP_FLASH_CLUSTERID:
flashTime = BUILD_UINT16(pkt->cmd.Data[1], pkt->cmd.Data[2] );
HalLedBlink( HAL_LED_4, 4, 50, (flashTime / 4) );
break;
* @fn SampleApp_SendPeriodicMessage
* @brief Send the periodic message.
* @param none
* @return none
/*16进制转ASCII码表-网蜂*/
uint8 Card_Id[8]; //存放32位卡号
if(IC_Test()==1)
if ( AF_DataRequest( &SampleApp_Periodic_DstAddr, &SampleApp_epDesc,
4,//字节数
qq,//指针头
&SampleApp_TransID,
AF_DISCV_ROUTE,
AF_DEFAULT_RADIUS ) == afStatus_SUCCESS )
else
// Error occurred in request to send.
* @fn SampleApp_SendFlashMessage
* @brief Send the flash message to group 1.
* @param flashTime - in milliseconds
* @return none
uint8 buffer[3];
buffer[0] = (uint8)(SampleAppFlashCounter++);
buffer[1] = LO_UINT16( flashTime );
buffer[2] = HI_UINT16( flashTime );
if ( AF_DataRequest( &SampleApp_Flash_DstAddr, &SampleApp_epDesc,
SAMPLEAPP_FLASH_CLUSTERID,
3,
buffer,
&SampleApp_TransID,
AF_DISCV_ROUTE,
else
void SampleApp_SendPointToPointMessage( void )
/*16进制转ASCII码表-网蜂*/
if(IC_Test()==1)
/****16进制转ASC码 串口打印IC卡号码********/
for(i=0;i<4;i++)
Card_Id[i*2]=asc_16[qq[i]/16];
Card_Id[i*2+1]=asc_16[qq[i]%16];
HalUARTWrite(0,Card_Id,8);
HalLcdWriteString( "I GOT IC CARD !", HAL_LCD_LINE_4 ); //液晶显示
if ( AF_DataRequest( &Point_To_Point_DstAddr,
&SampleApp_epDesc,
SAMPLEAPP_POINT_TO_POINT_CLUSTERID,
4,
qq,
&SampleApp_TransID,
AF_DISCV_ROUTE,
else
