-DRFD_RCVC_ALWAYS_ON=FALSE,POLLRATE默认设置,终端发送data request ,Zigbee终端接收不到协调器消息.
困扰很久了,参照了很多帖子,一直没有解决,求帮帮忙。
协调器能接收终端节点的数据,但是终端节点接收不到协调器的数据,最后在f8wConfig.cfg文件里修改了-DRFD_RCVC_ALWAYS_ON=TRUE,现在终端可以接收到协调器的数据了,但是又产生了另外一个问题,但是终端节点电流达30mA。请问有没有-DRFD_RCVC_ALWAYS_ON=FALSE,且能终端能接收协调器的数据的办法?
终端设置-DRFD_RCVC_ALWAYS_ON=TRUE能正常接收协调器消息,说明端点,组号设置均正确。
终端设置-DRFD_RCVC_ALWAYS_ON=FALSE。以下是终端的设置,协调器通过串口接收数据并发送给终端,POLLRATE默认设置,终端发送data request ,但是Zigbee终端接收不到协调器消息。
* The following are for End Devices only
/* The number of milliseconds to wait between data request polls to the coordinator. */
-DPOLL_RATE=1000
/* This is used after receiving a data indication to poll immediately
* for queued messages...in milliseconds.
-DQUEUED_POLL_RATE=100
/* This is used after receiving a data confirmation to poll immediately
* for response messages...in milliseconds
-DRESPONSE_POLL_RATE=100
/* This is used as an alternate response poll rate only for rejoin request.
* This rate is determined by the response time of the parent that the device
* is trying to join.
-DREJOIN_POLL_RATE=440
123.psd
