发起路由请求没有得到路由响应
Other Parts Discussed in Thread: Z-STACK
 使用Z-Stack Home 1.2.2a.44539协议栈开发,设备入网后,协调器收到Device Announce后会向设备发起端点请求,此时如果设备是通过其他路由入网的,协调器会发起路由请求,但是没有route reply,导致端点请求无法发送,请问这个问题怎么解决呢?
Z-TOOL 打印信息
Start Time: 2018-02-24 17:22:52
<TX>05:28:22.89 COM6 ZDO_MGMT_PERMIT_JOIN_REQUEST (0x2536)
    AddrMode: 0x0F (BROADCAST) (0xF)
    DstAddr: 0xFFFC
    Duration: 0x6F
    TCSignificance: 0x01
<RX>05:28:22.9 COM6 ZDO_MGMT_PERMIT_JOIN_REQ_SRSP (0x6536)
    Status: SUCCESS (0x0)
*** WARNING ***
    Unsupported or unformatted message received.  Raw data:
    01 45 CB 6F
<RX>05:28:22.9 COM6 ZDO_MGMT_PERMIT_JOIN_RSP (0x45B6)
    SrcAddr: 0x0000
    Status: ZDP_SUCCESS (0x0)
*** WARNING ***
    0C 45 CA A8 0A 43 03 CD 14 00 4B 12 00 35 7C
*** WARNING ***
<RX>05:28:26.22 COM6 ZDO_END_DEVICE_ANNCE_IND (0x45C1)
    SrcAddr: 0x0AA8
    NwkAddr: 0x0AA8
    IEEEAddr: 0x00124B0014CD0343
    Capabilities: 0x8E
*** WARNING ***
    01 45 CB 00
<RX>05:28:26.97 COM6 AF_DATA_CONFIRM (0x4480)
    Status: afStatus_NO_ROUTE (0xCD)
    Endpoint: 0x00
    TransID: 0x51
<RX>05:28:28.83 COM6 AF_DATA_CONFIRM (0x4480)
    Endpoint: 0x00
    TransID: 0x52
<RX>05:28:30.85 COM6 AF_DATA_CONFIRM (0x4480)
    Endpoint: 0x00
    TransID: 0x53
<RX>05:28:32.95 COM6 AF_DATA_CONFIRM (0x4480)
    Endpoint: 0x00
    TransID: 0x54
<RX>05:28:34.77 COM6 AF_DATA_CONFIRM (0x4480)
    Endpoint: 0x00
    TransID: 0x55
<RX>05:28:36.56 COM6 ZDO_ACTIVE_EP_RSP (0x4585)
    SrcAddr: 0x0AA8
    NwkAddr: 0x0AA8
    ActiveEPCount: 0x03
    ActiveEPList: ... (0x03, 0x02, 0x01)
