Other Parts Discussed in Thread: Z-STACK
我下载了z-stack linux gateway 然后尝试编译到PC机去执行,按照流程,我下载了 protobuf2.6.1版本。protobuf-c1.2.1版本,并且在ubuntu上也安装成功了,使用protoc-c编译了 nwkmgr.proto 文件
开始编译代码,遇到
nwkmgr.pb-c.h:12:3: error: #error This file was generated by a newer version of protoc-c which is incompatible with your libprotobuf-c headers. Please update your headers.
# error This file was generated by a newer version of protoc-c which is incompatible with your libprotobuf-c headers. Please update your headers.
然后按照指示,更新了 代码目录中的google/protobuc-c/下面的protobuf-c.h头文件。可以又遇到以下问题
/zstackpb/zstack.pb-c.h:11:1: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘typedef’
typedef struct _AFAddr AFAddr;
zstackpb/zstack.pb-c.h:498:3: error: unknown type name ‘AFAddr’
AFAddr *dstaddr;
还有一个问题,就是为什么源代码目录中没有zstack.pb-c.c的 zstack.proto和server.pb-c.c的server.proto文件??
