CC1310 的collector中在哪修改发射速率和发射功率呢?
Other Parts Discussed in Thread: CC1310
  • 您可以看一下  config.h内的定义CONFIG_TRANSMIT_POWER
  • user5272388 说:
    在rf_setting里面
    // CMD_PROP_RADIO_DIV_SETUP
    rfc_CMD_PROP_RADIO_DIV_SETUP_t RF_cmdPropRadioDivSetup =
    .commandNo = 0x3807,
    .status = 0x0000,
    .pNextOp = 0, // INSERT APPLICABLE POINTER: (uint8_t*)&xxx
    .startTime = 0x00000000,
    .startTrigger.triggerType = 0x0,
    .startTrigger.bEnaCmd = 0x0,
    .startTrigger.triggerNo = 0x0,
    .startTrigger.pastTrig = 0x0,
    .condition.rule = 0x1,
    .condition.nSkip = 0x0,
    .modulation.modType = 0x1,
    .modulation.deviation = 0x64,
    .symbolRate.preScale = 0xf,
    .symbolRate.rateWord = 0x8000,
    .rxBw = 0x24,
    .preamConf.nPreamBytes = 0x4,
    .preamConf.preamMode = 0x0,
    .formatConf.nSwBits = 0x20,
    .formatConf.bBitReversal = 0x0,
    .formatConf.bMsbFirst = 0x1,
    .formatConf.fecMode = 0x0,
    .formatConf.whitenMode = 0x0,
    .config.frontEndMode = 0x0,
    .config.biasMode = 0x1,
    .config.bNoFsPowerUp = 0x0,
    .txPower = 0xa73f,
    .pRegOverride = pOverrides,
    .centerFreq = 0x0364,
    .intFreq = 0x8000,
    .loDivider = 0x05,
  • 您好,CC1310使用802协议,发射速率只能采用5k或50k吗,是否可以设置为其他速率
  • TI 15.4 协议棧可用的发射速率及頻段可以參考 dev.ti.com/.../ti154stack-overview.html
