Other Parts Discussed in Thread: Z-STACK
大家好,我用Z-STACK 3.0.1里的SampleLight工程做灯泡开关和调光的实验。开关功能用ZCL_ONOFF的cluster,调节亮度使用ZCL_LEVEL_CTRL的cluster, 这两个都已经实现了。但是在用ZCL_SCENES作为调节颜色的cluster的时候发现灯泡对ZCL_SCENES的指令没有任何反应。为了测试我把处理ZCL_SCENES的代码做了如下修改:
static ZStatus_t zclGeneral_HdlInSpecificCommands( zclIncoming_t *pInMsg )
ZStatus_t stat;
zclGeneral_AppCallbacks_t *pCBs;
// make sure endpoint exists
pCBs = zclGeneral_FindCallbacks( pInMsg->msg->endPoint );
if ( pCBs == NULL )
return ( ZFailure );
switch ( pInMsg->msg->clusterId )
#ifdef ZCL_BASIC
case ZCL_CLUSTER_ID_GEN_BASIC:
stat = zclGeneral_ProcessInBasic( pInMsg, pCBs );
break;
#endif // ZCL_BASIC
#ifdef ZCL_IDENTIFY
case ZCL_CLUSTER_ID_GEN_IDENTIFY:
stat = zclGeneral_ProcessInIdentity( pInMsg, pCBs );
break;
#endif // ZCL_IDENTIFY
#ifdef ZCL_GROUPS
case ZCL_CLUSTER_ID_GEN_GROUPS:
if ( zcl_ServerCmd( pInMsg->hdr.fc.direction ) )
stat = zclGeneral_ProcessInGroupsServer( pInMsg );
else
stat = zclGeneral_ProcessInGroupsClient( pInMsg, pCBs );
break;
#endif // ZCL_GROUPS
#ifdef ZCL_SCENES
case ZCL_CLUSTER_ID_GEN_SCENES:
/*if ( zcl_ServerCmd( pInMsg->hdr.fc.direction ) )
stat = zclGeneral_ProcessInScenesServer( pInMsg, pCBs );
else
stat = zclGeneral_ProcessInScenesClient( pInMsg, pCBs );*/
//stat=zclGeneral_ProcessInScenesSimple(pInMsg, pCBs); //仅为实现功能的超级简化版处理方式
//zclSampleLight_SceneSimpleCB();
LedTurnOn(HAL_LED_2);
break;
#endif // ZCL_SCENES
#ifdef ZCL_ON_OFF
case ZCL_CLUSTER_ID_GEN_ON_OFF:
stat = zclGeneral_ProcessInOnOff( pInMsg, pCBs );
break;
#endif // ZCL_ON_OFF
#ifdef ZCL_LEVEL_CTRL
case ZCL_CLUSTER_ID_GEN_LEVEL_CONTROL:
stat = zclGeneral_ProcessInLevelControl( pInMsg, pCBs );
break;
#endif // ZCL_LEVEL_CTRL
#ifdef ZCL_ALARMS
case ZCL_CLUSTER_ID_GEN_ALARMS:
stat = zclGeneral_ProcessInAlarmsServer( pInMsg, pCBs );
else
stat = zclGeneral_ProcessInAlarmsClient( pInMsg, pCBs );
break;
#endif // ZCL_ALARMS
#ifdef ZCL_LOCATION
case ZCL_CLUSTER_ID_GEN_LOCATION:
stat = zclGeneral_ProcessInLocationServer( pInMsg, pCBs );
else
stat = zclGeneral_ProcessInLocationClient( pInMsg, pCBs );
break;
#endif // ZCL_LOCATION
case ZCL_CLUSTER_ID_GEN_POWER_CFG:
case ZCL_CLUSTER_ID_GEN_DEVICE_TEMP_CONFIG:
case ZCL_CLUSTER_ID_GEN_ON_OFF_SWITCH_CONFIG:
case ZCL_CLUSTER_ID_GEN_TIME:
default:
stat = ZFailure;
break;
return ( stat );
灯泡打开代码LedTurnOn(HAL_LED_2)直接写到这里了,结果还是没有反应。
要接受ZCL_SCENES还要做什么设置呢?
