大家好,请教一个问题
z-stack2.5.1a协议栈中,在协调器中,删除已经加入网络的节点,协调器会发送一个删除命令给待删除的节点,节点收到后,会回应一个状态信息,这时候才能成功删除节点,如果相应的节点没有收到的话,就会删除不成功。
那么,问题来了,在协调器中通过什么判断是否收到节点的回应信息呢?
希望大神帮忙解答,万分感谢
大家好,请教一个问题
希望大神帮忙解答,万分感谢
感谢您的回答,但是还有个问题, 这个函数ZDO_ParseMgmtLeaveRsp( pMsg )是自己定义,然后自己定义如何解析这个回应消息的对吧,那这个pMsg是如何获取呢,麻烦您能告诉我一下么,谢谢
Filename: GenericApp.c
Revised: $Date: 2014-09-07 13:36:30 -0700 (Sun, 07 Sep 2014) $
Revision: $Revision: 40046 $
Description: Generic Application (no Profile).
Copyright 2004-2014 Texas Instruments Incorporated. All rights reserved.
IMPORTANT: Your use of this Software is limited to those specific rights
granted under the terms of a software license agreement between the user
who downloaded the software, his/her employer (which must be your employer)
and Texas Instruments Incorporated (the "License"). You may not use this
Software unless you agree to abide by the terms of the License. The License
limits your use, and you acknowledge, that the Software may not be modified,
copied or distributed unless embedded on a Texas Instruments microcontroller
or used solely and exclusively in conjunction with a Texas Instruments radio
frequency transceiver, which is integrated into your product. Other than for
the foregoing purpose, you may not use, reproduce, copy, prepare derivative
works of, modify, distribute, perform, display or sell this Software and/or
its documentation for any purpose.
YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
PROVIDED �AS IS� WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
(INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
Should you have any questions regarding your right to use this Software,
contact Texas Instruments Incorporated at www.TI.com.
This application isn't intended to do anything useful - it is
intended to be a simple example of an application's structure.
This application periodically sends a "Hello World" message to
another "Generic" application (see 'txMsgDelay'). The application
will also receive "Hello World" packets.
This application doesn't have a profile, so it handles everything
directly - by itself.
Key control:
SW1: changes the delay between TX packets
SW2: initiates end device binding
SW3:
SW4: initiates a match description request
* INCLUDES
#include "OSAL.h"
#include "AF.h"
#include "ZDApp.h"
#include "ZDObject.h"
#include "ZDProfile.h"
#include "GenericApp.h"
#include "DebugTrace.h"
#if !defined( WIN32 ) || defined( ZBIT )
#include "OnBoard.h"
#endif
/* HAL */
#include "hal_lcd.h"
#include "hal_led.h"
#include "hal_key.h"
#include "hal_uart.h"
/* RTOS */
#if defined( IAR_ARMCM3_LM )
#include "RTOS_App.h"
#endif
* MACROS
* CONSTANTS
* TYPEDEFS
* GLOBAL VARIABLES
// This list should be filled with Application specific Cluster IDs.
const cId_t GenericApp_ClusterList[GENERICAPP_MAX_CLUSTERS] =
GENERICAPP_CLUSTERID
const SimpleDescriptionFormat_t GenericApp_SimpleDesc =
GENERICAPP_ENDPOINT, // int Endpoint;
GENERICAPP_PROFID, // uint16 AppProfId[2];
GENERICAPP_DEVICEID, // uint16 AppDeviceId[2];
GENERICAPP_DEVICE_VERSION, // int AppDevVer:4;
GENERICAPP_FLAGS, // int AppFlags:4;
GENERICAPP_MAX_CLUSTERS, // byte AppNumInClusters;
(cId_t *)GenericApp_ClusterList, // byte *pAppInClusterList;
(cId_t *)GenericApp_ClusterList // byte *pAppInClusterList;
// This is the Endpoint/Interface description. It is defined here, but
// filled-in in GenericApp_Init(). Another way to go would be to fill
// in the structure here and make it a "const" (in code space). The
// way it's defined in this sample app it is define in RAM.
endPointDesc_t GenericApp_epDesc;
* EXTERNAL VARIABLES
* EXTERNAL FUNCTIONS
* LOCAL VARIABLES
byte GenericApp_TaskID; // Task ID for internal task/event processing
// This variable will be received when
// GenericApp_Init() is called.
devStates_t GenericApp_NwkState;
byte GenericApp_TransID; // This is the unique message ID (counter)
afAddrType_t GenericApp_DstAddr;
// Number of recieved messages
static uint16 rxMsgCount;
// Time interval between sending messages
static uint32 txMsgDelay = GENERICAPP_SEND_MSG_TIMEOUT;
* LOCAL FUNCTIONS
static void GenericApp_ProcessZDOMsgs( zdoIncomingMsg_t *inMsg );
static void GenericApp_HandleKeys( byte shift, byte keys );
static void GenericApp_MessageMSGCB( afIncomingMSGPacket_t *pckt );
static void GenericApp_SendTheMessage( void );
static void GenericApp_ProcessRtosMessage( void );
#endif
* NETWORK LAYER CALLBACKS
* PUBLIC FUNCTIONS
* @fn GenericApp_Init
* @brief Initialization function for the Generic App Task.
* This is called during initialization and should contain
* any application specific initialization (ie. hardware
* initialization/setup, table initialization, power up
* notificaiton ... ).
* @param task_id - the ID assigned by OSAL. This ID should be
* used to send messages and set timers.
* @return none
void GenericApp_Init( uint8 task_id )
GenericApp_TaskID = task_id;
GenericApp_NwkState = DEV_INIT;
GenericApp_TransID = 0;
// Device hardware initialization can be added here or in main() (Zmain.c).
// If the hardware is application specific - add it here.
// If the hardware is other parts of the device add it in main().
GenericApp_DstAddr.addrMode = (afAddrMode_t)AddrNotPresent;
GenericApp_DstAddr.endPoint = 0;
GenericApp_DstAddr.addr.shortAddr = 0;
// Fill out the endpoint description.
GenericApp_epDesc.endPoint = GENERICAPP_ENDPOINT;
GenericApp_epDesc.task_id = &GenericApp_TaskID;
GenericApp_epDesc.simpleDesc
= (SimpleDescriptionFormat_t *)&GenericApp_SimpleDesc;
GenericApp_epDesc.latencyReq = noLatencyReqs;
// Register the endpoint description with the AF
afRegister( &GenericApp_epDesc );
// Register for all key events - This app will handle all key events
RegisterForKeys( GenericApp_TaskID );
// Update the display
#if defined ( LCD_SUPPORTED )
HalLcdWriteString( "GenericApp", HAL_LCD_LINE_1 );
#endif
ZDO_RegisterForZDOMsg( GenericApp_TaskID, End_Device_Bind_rsp );
ZDO_RegisterForZDOMsg( GenericApp_TaskID, Match_Desc_rsp );
// Register this task with RTOS task initiator
RTOS_RegisterApp( task_id, GENERICAPP_RTOS_MSG_EVT );
#endif
* @fn GenericApp_ProcessEvent
* @brief Generic Application Task event processor. This function
* is called to process all events for the task. Events
* include timers, messages and any other user defined events.
* @param task_id - The OSAL assigned task ID.
* @param events - events to process. This is a bit map and can
* contain more than one event.
* @return none
uint16 GenericApp_ProcessEvent( uint8 task_id, uint16 events )
afIncomingMSGPacket_t *MSGpkt;
afDataConfirm_t *afDataConfirm;
// Data Confirmation message fields
byte sentEP;
ZStatus_t sentStatus;
byte sentTransID; // This should match the value sent
(void)task_id; // Intentionally unreferenced parameter
if ( events & SYS_EVENT_MSG )
MSGpkt = (afIncomingMSGPacket_t *)osal_msg_receive( GenericApp_TaskID );
while ( MSGpkt )
switch ( MSGpkt->hdr.event )
case ZDO_CB_MSG:
GenericApp_ProcessZDOMsgs( (zdoIncomingMsg_t *)MSGpkt );
break;
case KEY_CHANGE:
GenericApp_HandleKeys( ((keyChange_t *)MSGpkt)->state, ((keyChange_t *)MSGpkt)->keys );
break;
case AF_DATA_CONFIRM_CMD:
// This message is received as a confirmation of a data packet sent.
// The status is of ZStatus_t type [defined in ZComDef.h]
// The message fields are defined in AF.h
afDataConfirm = (afDataConfirm_t *)MSGpkt;
sentEP = afDataConfirm->endpoint;
(void)sentEP; // This info not used now
sentTransID = afDataConfirm->transID;
(void)sentTransID; // This info not used now
sentStatus = afDataConfirm->hdr.status;
// Action taken when confirmation is received.
if ( sentStatus != ZSuccess )
// The data wasn't delivered -- Do something
break;
case AF_INCOMING_MSG_CMD:
GenericApp_MessageMSGCB( MSGpkt );
break;
case ZDO_STATE_CHANGE:
GenericApp_NwkState = (devStates_t)(MSGpkt->hdr.status);
if ( (GenericApp_NwkState == DEV_ZB_COORD) ||
(GenericApp_NwkState == DEV_ROUTER) ||
(GenericApp_NwkState == DEV_END_DEVICE) )
// Start sending "the" message in a regular interval.
osal_start_timerEx( GenericApp_TaskID,
GENERICAPP_SEND_MSG_EVT,
txMsgDelay );
break;
default:
break;
// Release the memory
osal_msg_deallocate( (uint8 *)MSGpkt );
// Next
// return unprocessed events
return (events ^ SYS_EVENT_MSG);
// Send a message out - This event is generated by a timer
// (setup in GenericApp_Init()).
if ( events & GENERICAPP_SEND_MSG_EVT )
// Send "the" message
GenericApp_SendTheMessage();
// Setup to send message again
txMsgDelay );
return (events ^ GENERICAPP_SEND_MSG_EVT);
// Receive a message from the RTOS queue
if ( events & GENERICAPP_RTOS_MSG_EVT )
// Process message from RTOS queue
GenericApp_ProcessRtosMessage();
return (events ^ GENERICAPP_RTOS_MSG_EVT);
#endif
// Discard unknown events
return 0;
* Event Generation Functions
* @fn GenericApp_ProcessZDOMsgs()
* @brief Process response messages
* @param none
* @return none
switch ( inMsg->clusterID )
case End_Device_Bind_rsp:
if ( ZDO_ParseBindRsp( inMsg ) == ZSuccess )
// Light LED
HalLedSet( HAL_LED_4, HAL_LED_MODE_ON );
#if defined( BLINK_LEDS )
else
// Flash LED to show failure
HalLedSet ( HAL_LED_4, HAL_LED_MODE_FLASH );
#endif
break;
case Match_Desc_rsp:
ZDO_ActiveEndpointRsp_t *pRsp = ZDO_ParseEPListRsp( inMsg );
if ( pRsp )
if ( pRsp->status == ZSuccess && pRsp->cnt )
GenericApp_DstAddr.addrMode = (afAddrMode_t)Addr16Bit;
GenericApp_DstAddr.addr.shortAddr = pRsp->nwkAddr;
// Take the first endpoint, Can be changed to search through endpoints
GenericApp_DstAddr.endPoint = pRsp->epList[0];
// Light LED
osal_mem_free( pRsp );
break;
* @fn GenericApp_HandleKeys
* @brief Handles all key events for this device.
* @param shift - true if in shift/alt.
* @param keys - bit field for key events. Valid entries:
* HAL_KEY_SW_4
* HAL_KEY_SW_3
* HAL_KEY_SW_2
* HAL_KEY_SW_1
* @return none
static void GenericApp_HandleKeys( uint8 shift, uint8 keys )
zAddrType_t dstAddr;
// Shift is used to make each button/switch dual purpose.
if ( shift )
if ( keys & HAL_KEY_SW_1 )
if ( keys & HAL_KEY_SW_2 )
if ( keys & HAL_KEY_SW_3 )
if ( keys & HAL_KEY_SW_4 )
else
#if defined( SWITCH1_BIND )
// We can use SW1 to simulate SW2 for devices that only have one switch,
keys |= HAL_KEY_SW_2;
#elif defined( SWITCH1_MATCH )
// or use SW1 to simulate SW4 for devices that only have one switch
keys |= HAL_KEY_SW_4;
#else
// Normally, SW1 changes the rate that messages are sent
if ( txMsgDelay > 100 )
// Cut the message TX delay in half
txMsgDelay /= 2;
else
// Reset to the default
#endif
HalLedSet ( HAL_LED_4, HAL_LED_MODE_OFF );
// Initiate an End Device Bind Request for the mandatory endpoint
dstAddr.addrMode = Addr16Bit;
dstAddr.addr.shortAddr = 0x0000; // Coordinator
ZDP_EndDeviceBindReq( &dstAddr, NLME_GetShortAddr(),
GenericApp_epDesc.endPoint,
GENERICAPP_PROFID,
GENERICAPP_MAX_CLUSTERS, (cId_t *)GenericApp_ClusterList,
FALSE );
// Initiate a Match Description Request (Service Discovery)
dstAddr.addrMode = AddrBroadcast;
dstAddr.addr.shortAddr = NWK_BROADCAST_SHORTADDR;
ZDP_MatchDescReq( &dstAddr, NWK_BROADCAST_SHORTADDR,
GENERICAPP_PROFID,
FALSE );
* LOCAL FUNCTIONS
* @fn GenericApp_MessageMSGCB
* @brief Data message processor callback. This function processes
* any incoming data - probably from other devices. So, based
* on cluster ID, perform the intended action.
* @param none
* @return none
static void GenericApp_MessageMSGCB( afIncomingMSGPacket_t *pkt )
switch ( pkt->clusterId )
case GENERICAPP_CLUSTERID:
rxMsgCount += 1; // Count this message
HalLedSet ( HAL_LED_4, HAL_LED_MODE_BLINK ); // Blink an LED
#if defined( LCD_SUPPORTED )
HalLcdWriteString( (char*)pkt->cmd.Data, HAL_LCD_LINE_1 );
HalLcdWriteStringValue( "Rcvd:", rxMsgCount, 10, HAL_LCD_LINE_2 );
#elif defined( WIN32 )
WPRINTSTR( pkt->cmd.Data );
#endif
break;
* @fn GenericApp_SendTheMessage
* @brief Send "the" message.
* @param none
* @return none
char theMessageData[] = "Hello World";
if ( AF_DataRequest( &GenericApp_DstAddr, &GenericApp_epDesc,
GENERICAPP_CLUSTERID,
(byte)osal_strlen( theMessageData ) + 1,
(byte *)&theMessageData,
&GenericApp_TransID,
AF_DISCV_ROUTE, AF_DEFAULT_RADIUS ) == afStatus_SUCCESS )
// Successfully requested to be sent.
else
// Error occurred in request to send.
* @fn GenericApp_ProcessRtosMessage
* @brief Receive message from RTOS queue, send response back.
* @param none
* @return none
osalQueue_t inMsg;
if ( osal_queue_receive( OsalQueue, &inMsg, 0 ) == pdPASS )
uint8 cmndId = inMsg.cmnd;
uint32 counter = osal_build_uint32( inMsg.cbuf, 4 );
switch ( cmndId )
case CMD_INCR:
counter += 1; /* Increment the incoming counter */
/* Intentionally fall through next case */
case CMD_ECHO:
userQueue_t outMsg;
outMsg.resp = RSP_CODE | cmndId; /* Response ID */
osal_buffer_uint32( outMsg.rbuf, counter ); /* Increment counter */
osal_queue_send( UserQueue1, &outMsg, 0 ); /* Send back to UserTask */
break;
default:
break; /* Ignore unknown command */
#endif
