1.第一static void zclSampleLight_MoveBasedOnRate( uint8 newLevel, uint32 rate ) { uint32 diff; // determine how much time (in 10ths of seconds) based on the difference and rate 根据差值和速率来确定时间 zclSampleLight_Rate32 = rate; diff = zclSampleLight_TimeRateHelper( newLevel ); zclSampleLight_LevelRemainingTime = diff / rate; if ( !zclSampleLight_LevelRemainingTime ) { zclSampleLight_LevelRemainingTime = 1; } osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_LEVEL_CTRL_EVT, 100 );
请问一下这个函数的作用是什么,还有什么是平滑过渡呢,他在zigbee中有什么作用?
2.第二// Toggle the light
else if ( cmd == COMMAND_TOGGLE )
#ifdef ZCL_LEVEL_CTRL
if (zclSampleLight_LevelRemainingTime > 0)
if (zclSampleLight_NewLevelUp)
OnOff = LIGHT_OFF;
else
OnOff = LIGHT_ON;
else
if (zclSampleLight_OnOff == LIGHT_ON)
OnOff = LIGHT_OFF;
else
OnOff = LIGHT_ON;
}在这个灯转换中
zclSampleLight_LevelRemainingTime 他的作用又是什么呢。。请ti的大神们指导一下,谢谢
