只有一个协调器,一个路由器,但抓包显示有20多个设备
查看mac地址,除了0000 外,其他设备的mac地址都一样。 可以确认是同一个设备。
 看起来是TI的一个Bug? 起因似乎是以前是永久打开组网的;然后组网突然被关闭了(不知什么原因);然后设备连接不上;然后我通过串口命令打开组网;然后就变成了现在这样。
估计是反复多次请求造成? 是否应该在协调器或路由器那边判断是否重复?
抓包https://e2echina.ti.com/cfs-file/__key/communityserver-discussions-components-files/104/many-devices.7z文件也附在后面。
  • 如何添加附件呢?
  • 可以使用”使用高级编辑器编辑文本”添加附件
  • 你的抓包檔裡面有兩個設備一直試著要入網不成功,你測試用的協議棧跟例程是什麼?有沒有做過任何修改?
      Filename:       zcl_samplesw.c
      Revised:        $Date: 2015-08-19 17:11:00 -0700 (Wed, 19 Aug 2015) $
      Revision:       $Revision: 44460 $
      Description:    Zigbee Cluster Library - sample switch application.
      Copyright 2006-2013 Texas Instruments Incorporated. All rights reserved.
      IMPORTANT: Your use of this Software is limited to those specific rights
      granted under the terms of a software license agreement between the user
      who downloaded the software, his/her employer (which must be your employer)
      and Texas Instruments Incorporated (the "License").  You may not use this
      Software unless you agree to abide by the terms of the License. The License
      limits your use, and you acknowledge, that the Software may not be modified,
      copied or distributed unless embedded on a Texas Instruments microcontroller
      or used solely and exclusively in conjunction with a Texas Instruments radio
      frequency transceiver, which is integrated into your product.  Other than for
      the foregoing purpose, you may not use, reproduce, copy, prepare derivative
      works of, modify, distribute, perform, display or sell this Software and/or
      its documentation for any purpose.
      YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
      PROVIDED �AS IS� WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
      INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
      NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
      TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
      NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
      LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
      INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
      OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
      OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
      (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
      Should you have any questions regarding your right to use this Software,
      contact Texas Instruments Incorporated at www.TI.com.
      This application implements a ZigBee On/Off Switch, based on Z-Stack 3.0.
      This application is based on the common sample-application user interface. Please see the main
      comment in zcl_sampleapp_ui.c. The rest of this comment describes only the content specific for
      this sample applicetion.
      Application-specific UI peripherals being used:
      - none (LED1 is currently unused by this application).
      Application-specific menu system:
        <TOGGLE LIGHT> Send an On, Off or Toggle command targeting appropriate devices from the binding table.
          Pressing / releasing [OK] will have the following functionality, depending on the value of the
          zclSampleSw_OnOffSwitchActions attribute:
          - OnOffSwitchActions == 0: pressing [OK] will send ON command, releasing it will send OFF command;
          - OnOffSwitchActions == 1: pressing [OK] will send OFF command, releasing it will send ON command;
          - OnOffSwitchActions == 2: pressing [OK] will send TOGGLE command, releasing it will not send any command.
    #if ! defined ZCL_ON_OFF
    #error ZCL_ON_OFF must be defined for this project.
    #endif
     * INCLUDES
    #include "ZComDef.h"
    #include "OSAL.h"
    #include "AF.h"
    #include "ZDApp.h"
    #include "ZDObject.h"
    #include "ZDProfile.h"
    #include "MT_SYS.h"
    #include "zcl.h"
    #include "zcl_general.h"
    #include "zcl_ha.h"
    #include "zcl_samplesw.h"
    #include "zcl_diagnostic.h"
    #include "onboard.h"
    /* HAL */
    #include "hal_lcd.h"
    #include "hal_led.h"
    #include "hal_key.h"
    #include "hal_adc.h"
    #if defined (OTA_CLIENT) && (OTA_CLIENT == TRUE)
    #include "zcl_ota.h"
    #include "hal_ota.h"
    #endif
    #include "bdb.h"
    #include "bdb_interface.h"
    #include <stdio.h>
     * MACROS
    #define APP_TITLE "TI Sample Switch"
    /** @brief Debug mode
     *      open debug mode by defining  "DEBUG",
     *      close debug mode by defining "xDEBUG"
    #define HDEBUG
    #ifdef  HDEBUG
      #define LOG(...) printf(__VA_ARGS__)
    #else
      #define LOG(...)
    #endif
     * TYPEDEFS
     * GLOBAL VARIABLES
    byte zclSampleSw_TaskID;
    uint8 zclSampleSwSeqNum;
    uint8 zclSampleSw_OnOffSwitchType = ON_OFF_SWITCH_TYPE_MOMENTARY;
    uint8 zclSampleSw_OnOffSwitchActions;
     * GLOBAL FUNCTIONS
     * LOCAL VARIABLES
    afAddrType_t zclSampleSw_DstAddr;
    // Endpoint to allow SYS_APP_MSGs
    static endPointDesc_t sampleSw_TestEp =
      SAMPLESW_ENDPOINT,                  // endpoint
      0,
      &zclSampleSw_TaskID,
      (SimpleDescriptionFormat_t *)&zclSampleSw_SimpleDesc,  // No Simple description for this test endpoint
      (afNetworkLatencyReq_t)0            // No Network Latency req
    //static uint8 aProcessCmd[] = { 1, 0, 0, 0 }; // used for reset command, { length + cmd0 + cmd1 + data }
    devStates_t zclSampleSw_NwkState = DEV_INIT;
    #define DEVICE_POLL_RATE                 8000   // Poll rate for end device
    #endif
    #define SAMPLESW_TOGGLE_TEST_EVT   0x1000
     * LOCAL FUNCTIONS
    // P2P, hhh, 2018.10.6
    static void zclSampleSw_AF_P2P(uint16 destNwkAddr, uint16 cid, uint8 len, uint8 *data);
    // Broadcast
    static void zclSampleSw_AF_Broadcast(uint16 destNwkAddr, uint16 cid, uint8 len, uint8 *data);
    // Groupcast
    static void zclSampleSw_AF_Groupcast(uint16 groupId, uint16 cid, uint8 len, uint8 *data);
    // Process incoming message
    static void zclSampleSw_AF_RxProc(afIncomingMSGPacket_t *MSGpkt);
    static void zclSampleSw_HandleKeys( byte shift, byte keys );
    static void zclSampleSw_BasicResetCB( void );
    static void zclSampleSw_ProcessCommissioningStatus(bdbCommissioningModeMsg_t *bdbCommissioningModeMsg);
    // Functions to process ZCL Foundation incoming Command/Response messages
    static void zclSampleSw_ProcessIncomingMsg( zclIncomingMsg_t *msg );
    #ifdef ZCL_READ
    static uint8 zclSampleSw_ProcessInReadRspCmd( zclIncomingMsg_t *pInMsg );
    #endif
    #ifdef ZCL_WRITE
    static uint8 zclSampleSw_ProcessInWriteRspCmd( zclIncomingMsg_t *pInMsg );
    #endif
    static uint8 zclSampleSw_ProcessInDefaultRspCmd( zclIncomingMsg_t *pInMsg );
    #ifdef ZCL_DISCOVER
    static uint8 zclSampleSw_ProcessInDiscCmdsRspCmd( zclIncomingMsg_t *pInMsg );
    static uint8 zclSampleSw_ProcessInDiscAttrsRspCmd( zclIncomingMsg_t *pInMsg );
    static uint8 zclSampleSw_ProcessInDiscAttrsExtRspCmd( zclIncomingMsg_t *pInMsg );
    #endif
    static void zclSampleSw_ProcessOTAMsgs( zclOTA_CallbackMsg_t* pMsg );
    #endif
    // Uart
    #define ZCLSAMPLESW_UART_BUF_LEN        128
    static uint8 uartBuf[ZCLSAMPLESW_UART_BUF_LEN];
    static void zclSampleSw_InitUart(void);
    static void zclSampleSw_UartCB(uint8 port, uint8 event);
    #ifdef ZDO_COORDINATOR
      // On/Off test
      static uint16 zclSampleSw_OnOffTestAddr;
      static void zclSampleSw_processZDOMgs(zdoIncomingMsg_t *pMsg);
      static void zclSampleSw_OnOffTest(void);
    #else
      static void zclSampleSw_DeviceAnnce( void );
      static void zclSampleSw_OnOffCB( uint8 cmd );
    #endif
     * CONSTANTS
     * REFERENCED EXTERNALS
    extern int16 zdpExternalStateTaskID;
     * ZCL General Profile Callback table
    static zclGeneral_AppCallbacks_t zclSampleSw_CmdCallbacks =
      zclSampleSw_BasicResetCB,               // Basic Cluster Reset command
      NULL,                                   // Identify Trigger Effect command
      NULL,
    #else
      zclSampleSw_OnOffCB,    // On/Off cluster commands
    #endif
      NULL,                                   // On/Off cluster enhanced command Off with Effect
      NULL,                                   // On/Off cluster enhanced command On with Recall Global Scene
      NULL,                                   // On/Off cluster enhanced command On with Timed Off
    #ifdef ZCL_LEVEL_CTRL
      NULL,                                   // Level Control Move to Level command
      NULL,                                   // Level Control Move command
      NULL,                                   // Level Control Step command
      NULL,                                   // Level Control Stop command
    #endif
    #ifdef ZCL_GROUPS
      NULL,                                   // Group Response commands
    #endif
    #ifdef ZCL_SCENES
      NULL,                                   // Scene Store Request command
      NULL,                                   // Scene Recall Request command
      NULL,                                   // Scene Response command
    #endif
    #ifdef ZCL_ALARMS
      NULL,                                   // Alarm (Response) commands
    #endif
    #ifdef SE_UK_EXT
      NULL,                                   // Get Event Log command
      NULL,                                   // Publish Event Log command
    #endif
      NULL,                                   // RSSI Location command
      NULL                                    // RSSI Location Response command
     * @fn          zclSampleSw_Init
     * @brief       Initialization function for the zclGeneral layer.
     * @param       none
     * @return      none
    void zclSampleSw_Init( byte task_id )
      zclSampleSw_TaskID = task_id;
      // Set destination address to indirect
      zclSampleSw_DstAddr.addrMode = (afAddrMode_t)AddrNotPresent;
      zclSampleSw_DstAddr.endPoint = 0;
      zclSampleSw_DstAddr.addr.shortAddr = 0;
      // Register the Simple Descriptor for this application
      bdb_RegisterSimpleDescriptor( &zclSampleSw_SimpleDesc );
      // Register the ZCL General Cluster Library callback functions
      zclGeneral_RegisterCmdCallbacks( SAMPLESW_ENDPOINT, &zclSampleSw_CmdCallbacks );
      zclSampleSw_ResetAttributesToDefaultValues();
      // Register the application's attribute list
      zcl_registerAttrList( SAMPLESW_ENDPOINT, zclSampleSw_NumAttributes, zclSampleSw_Attrs );
      // Register the Application to receive the unprocessed Foundation command/response messages
      zcl_registerForMsg( zclSampleSw_TaskID );
      // Register for all key events - This app will handle all key events
      RegisterForKeys( zclSampleSw_TaskID );
      bdb_RegisterCommissioningStatusCB( zclSampleSw_ProcessCommissioningStatus );
      // Register for a test endpoint
      afRegister( &sampleSw_TestEp );
    #ifdef ZCL_DIAGNOSTIC
      // Register the application's callback function to read/write attribute data.
      // This is only required when the attribute data format is unknown to ZCL.
      zcl_registerReadWriteCB( SAMPLESW_ENDPOINT, zclDiagnostic_ReadWriteAttrCB, NULL );
      if ( zclDiagnostic_InitStats() == ZSuccess )
        // Here the user could start the timer to save Diagnostics to NV
    #endif
      // Register for callback events from the ZCL OTA
      zclOTA_Register(zclSampleSw_TaskID);
    #endif
      zdpExternalStateTaskID = zclSampleSw_TaskID;
      ZDO_RegisterForZDOMsg ( zclSampleSw_TaskID, Device_annce );
      bdb_StartCommissioning( BDB_COMMISSIONING_MODE_NWK_FORMATION |
                              BDB_COMMISSIONING_MODE_FINDING_BINDING );
      NLME_PermitJoiningRequest(255);
    #else
      bdb_StartCommissioning( BDB_COMMISSIONING_MODE_NWK_STEERING |
      zclSampleSw_DeviceAnnce();
    #endif
      // Init Uart
      zclSampleSw_InitUart();
      // hhh, 2018.10.6
      uartBuf[0] = 0xFC;
      uartBuf[1] = 6;
      uartBuf[2] = 0xFF;
      uartBuf[3] = 0xFF;
      uartBuf[4] = 9;
      uartBuf[5] = 1;
      HalUARTWrite(HAL_UART_PORT_0 ,  uartBuf , uartBuf[1]);
     * @fn          zclSample_event_loop
     * @brief       Event Loop Processor for zclGeneral.
     * @param       none
     * @return      none
    uint16 zclSampleSw_event_loop( uint8 task_id, uint16 events )
      afIncomingMSGPacket_t *MSGpkt;
      (void)task_id;  // Intentionally unreferenced parameter
      //Send toggle every 500ms
      if( events & SAMPLESW_TOGGLE_TEST_EVT )
        osal_start_timerEx(zclSampleSw_TaskID,SAMPLESW_TOGGLE_TEST_EVT,500);
        zclGeneral_SendOnOff_CmdToggle( SAMPLESW_ENDPOINT, &zclSampleSw_DstAddr, FALSE, 0 );
        // return unprocessed events
        return (events ^ SAMPLESW_TOGGLE_TEST_EVT);
      if ( events & SYS_EVENT_MSG )
        while ( (MSGpkt = (afIncomingMSGPacket_t *)osal_msg_receive( zclSampleSw_TaskID )) )
          LOG("osal_msg_receive: %d\n", MSGpkt->hdr.event);
          switch ( MSGpkt->hdr.event )
            case AF_INCOMING_MSG_CMD:
              LOG("AF_INCOMING_MSG_CMD\n");
              zclSampleSw_AF_RxProc( MSGpkt );
              break;
            case ZCL_INCOMING_MSG:
              LOG("ZCL_INCOMING_MSG\n");
              // Incoming ZCL Foundation command/response messages
              zclSampleSw_ProcessIncomingMsg( (zclIncomingMsg_t *)MSGpkt );
              break;
            case KEY_CHANGE:
              zclSampleSw_HandleKeys( ((keyChange_t *)MSGpkt)->state, ((keyChange_t *)MSGpkt)->keys );
              break;
            case ZDO_STATE_CHANGE:
              break;
            case ZCL_OTA_CALLBACK_IND:
              zclSampleSw_ProcessOTAMsgs( (zclOTA_CallbackMsg_t*)MSGpkt  );
              break;
    #endif
           case ZDO_CB_MSG:
              LOG("ZDO_CB_MSG\n");
              zclSampleSw_processZDOMgs( (zdoIncomingMsg_t *)MSGpkt );
              break;
        #endif
            default:
              LOG("default msg\n");
              break;
          // Release the memory
          osal_msg_deallocate( (uint8 *)MSGpkt );
        return (events ^ SYS_EVENT_MSG);
    #if ZG_BUILD_ENDDEVICE_TYPE
      if ( events & SAMPLEAPP_END_DEVICE_REJOIN_EVT )
        bdb_ZedAttemptRecoverNwk();
        return ( events ^ SAMPLEAPP_END_DEVICE_REJOIN_EVT );
    #endif
      if ( events & SAMPLEAPP_ONOFF_TEST_EVT )
        // hhh modified, 2018.10.6
        //zclSampleSw_OnOffTest();
        //osal_start_timerEx(zclSampleSw_TaskID, SAMPLEAPP_ONOFF_TEST_EVT, SAMPLEAPP_ONOFF_TEST_PERIOD);
        return ( events ^ SAMPLEAPP_ONOFF_TEST_EVT );
    #else
      // Rejoin
      if ( events & SAMPLEAPP_REJOIN_EVT )
       bdb_StartCommissioning(BDB_COMMISSIONING_MODE_NWK_STEERING |
        return ( events ^ SAMPLEAPP_REJOIN_EVT );
    #endif
      // Discard unknown events
      return 0;
     * @fn      zclSampleSw_HandleKeys
     * @brief   Handles all key events for this device.
     * @param   shift - true if in shift/alt.
     * @param   keys - bit field for key events. Valid entries:
     *                 HAL_KEY_SW_5
     *                 HAL_KEY_SW_4
     *                 HAL_KEY_SW_2
     *                 HAL_KEY_SW_1
     * @return  none
      if(keys & HAL_KEY_SW_6)
     * @fn      zclSampleSw_ProcessCommissioningStatus
     * @brief   Callback in which the status of the commissioning process are reported
     * @param   bdbCommissioningModeMsg - Context message of the status of a commissioning process
     * @return  none
      switch(bdbCommissioningModeMsg->bdbCommissioningMode)
        case BDB_COMMISSIONING_FORMATION:
          if(bdbCommissioningModeMsg->bdbCommissioningStatus == BDB_COMMISSIONING_SUCCESS)
            //After formation, perform nwk steering again plus the remaining commissioning modes that has not been processed yet
            bdb_StartCommissioning(BDB_COMMISSIONING_MODE_NWK_STEERING | bdbCommissioningModeMsg->bdbRemainingCommissioningModes);
          else
            //Want to try other channels?
            //try with bdb_setChannelAttribute
        break;
        case BDB_COMMISSIONING_NWK_STEERING:
            //YOUR JOB:
            //We are on the nwk, what now?
          else
            #else
                               SAMPLEAPP_REJOIN_EVT,
                               SAMPLEAPP_REJOIN_PERIOD);
            #endif
        break;
        case BDB_COMMISSIONING_FINDING_BINDING:
            //YOUR JOB:
          else
            //YOUR JOB:
            //retry?, wait for user interaction?
        break;
        case BDB_COMMISSIONING_INITIALIZATION:
          //Initialization notification can only be successful. Failure on initialization
          //only happens for ZED and is notified as BDB_COMMISSIONING_PARENT_LOST notification
          //YOUR JOB:
          //We are on a network, what now?
        break;
        case BDB_COMMISSIONING_PARENT_LOST:
          if(bdbCommissioningModeMsg->bdbCommissioningStatus == BDB_COMMISSIONING_NETWORK_RESTORED)
            //We did recover from losing parent
          else
            //Parent not found, attempt to rejoin again after a fixed delay
            osal_start_timerEx(zclSampleSw_TaskID, SAMPLEAPP_END_DEVICE_REJOIN_EVT, SAMPLEAPP_END_DEVICE_REJOIN_DELAY);
        break;
    #endif
     * @fn      zclSampleSw_BasicResetCB
     * @brief   Callback from the ZCL General Cluster Library
     *          to set all the Basic Cluster attributes to  default values.
     * @param   none
     * @return  none
     *  Functions for processing ZCL Foundation incoming Command/Response messages
     * @fn      zclSampleSw_ProcessIncomingMsg
     * @brief   Process ZCL Foundation incoming message
     * @param   pInMsg - pointer to the received message
     * @return  none
    static void zclSampleSw_ProcessIncomingMsg( zclIncomingMsg_t *pInMsg )
      switch ( pInMsg->zclHdr.commandID )
    #ifdef ZCL_READ
        case ZCL_CMD_READ_RSP:
          zclSampleSw_ProcessInReadRspCmd( pInMsg );
          break;
    #endif
    #ifdef ZCL_WRITE
        case ZCL_CMD_WRITE_RSP:
          zclSampleSw_ProcessInWriteRspCmd( pInMsg );
          break;
    #endif
    #ifdef ZCL_REPORT
        // See ZCL Test Applicaiton (zcl_testapp.c) for sample code on Attribute Reporting
        case ZCL_CMD_CONFIG_REPORT:
          //zclSampleSw_ProcessInConfigReportCmd( pInMsg );
          break;
        case ZCL_CMD_CONFIG_REPORT_RSP:
          //zclSampleSw_ProcessInConfigReportRspCmd( pInMsg );
          break;
        case ZCL_CMD_READ_REPORT_CFG:
          //zclSampleSw_ProcessInReadReportCfgCmd( pInMsg );
          break;
        case ZCL_CMD_READ_REPORT_CFG_RSP:
          //zclSampleSw_ProcessInReadReportCfgRspCmd( pInMsg );
          break;
        case ZCL_CMD_REPORT:
          //zclSampleSw_ProcessInReportCmd( pInMsg );
          break;
    #endif
        case ZCL_CMD_DEFAULT_RSP:
          zclSampleSw_ProcessInDefaultRspCmd( pInMsg );
          break;
    #ifdef ZCL_DISCOVER
        case ZCL_CMD_DISCOVER_CMDS_RECEIVED_RSP:
          zclSampleSw_ProcessInDiscCmdsRspCmd( pInMsg );
          break;
        case ZCL_CMD_DISCOVER_CMDS_GEN_RSP:
          break;
        case ZCL_CMD_DISCOVER_ATTRS_RSP:
          zclSampleSw_ProcessInDiscAttrsRspCmd( pInMsg );
          break;
        case ZCL_CMD_DISCOVER_ATTRS_EXT_RSP:
          zclSampleSw_ProcessInDiscAttrsExtRspCmd( pInMsg );
          break;
    #endif
        default:
          break;
      if ( pInMsg->attrCmd )
        osal_mem_free( pInMsg->attrCmd );
    #ifdef ZCL_READ
     * @fn      zclSampleSw_ProcessInReadRspCmd
     * @brief   Process the "Profile" Read Response Command
     * @param   pInMsg - incoming message to process
     * @return  none
      zclReadRspCmd_t *readRspCmd;
      uint8 i;
      readRspCmd = (zclReadRspCmd_t *)pInMsg->attrCmd;
      for (i = 0; i < readRspCmd->numAttr; i++)
        // Notify the originator of the results of the original read attributes
        // attempt and, for each successfull request, the value of the requested
        // attribute
      return TRUE;
    #endif // ZCL_READ
    #ifdef ZCL_WRITE
     * @fn      zclSampleSw_ProcessInWriteRspCmd
     * @brief   Process the "Profile" Write Response Command
     * @return  none
      zclWriteRspCmd_t *writeRspCmd;
      uint8 i;
      writeRspCmd = (zclWriteRspCmd_t *)pInMsg->attrCmd;
      for (i = 0; i < writeRspCmd->numAttr; i++)
        // Notify the device of the results of the its original write attributes
        // command.
      return TRUE;
    #endif // ZCL_WRITE
     * @fn      zclSampleSw_ProcessInDefaultRspCmd
     * @brief   Process the "Profile" Default Response Command
     * @return  none
      // zclDefaultRspCmd_t *defaultRspCmd = (zclDefaultRspCmd_t *)pInMsg->attrCmd;
      // Device is notified of the Default Response command.
      (void)pInMsg;
      return TRUE;
    #ifdef ZCL_DISCOVER
     * @fn      zclSampleSw_ProcessInDiscCmdsRspCmd
     * @brief   Process the Discover Commands Response Command
     * @return  none
      zclDiscoverCmdsCmdRsp_t *discoverRspCmd;
      uint8 i;
      discoverRspCmd = (zclDiscoverCmdsCmdRsp_t *)pInMsg->attrCmd;
      for ( i = 0; i < discoverRspCmd->numCmd; i++ )
        // Device is notified of the result of its attribute discovery command.
      return TRUE;
     * @fn      zclSampleSw_ProcessInDiscAttrsRspCmd
     * @brief   Process the "Profile" Discover Attributes Response Command
     * @return  none
      zclDiscoverAttrsRspCmd_t *discoverRspCmd;
      uint8 i;
      discoverRspCmd = (zclDiscoverAttrsRspCmd_t *)pInMsg->attrCmd;
      for ( i = 0; i < discoverRspCmd->numAttr; i++ )
      return TRUE;
     * @fn      zclSampleSw_ProcessInDiscAttrsExtRspCmd
     * @brief   Process the "Profile" Discover Attributes Extended Response Command
     * @return  none
      zclDiscoverAttrsExtRsp_t *discoverRspCmd;
      uint8 i;
      discoverRspCmd = (zclDiscoverAttrsExtRsp_t *)pInMsg->attrCmd;
      return TRUE;
    #endif // ZCL_DISCOVER
     * @fn      zclSampleSw_ProcessOTAMsgs
     * @brief   Called to process callbacks from the ZCL OTA.
     * @param   none
     * @return  none
      uint8 RxOnIdle;
      switch(pMsg->ota_event)
      case ZCL_OTA_START_CALLBACK:
        if (pMsg->hdr.status == ZSuccess)
          // Speed up the poll rate
          RxOnIdle = TRUE;
          ZMacSetReq( ZMacRxOnIdle, &RxOnIdle );
          NLME_SetPollRate( 2000 );
        break;
      case ZCL_OTA_DL_COMPLETE_CALLBACK:
          // Reset the CRC Shadow and reboot.  The bootloader will see the
          // CRC shadow has been cleared and switch to the new image
          HalOTAInvRC();
          SystemReset();
        else
          // slow the poll rate back down.
          RxOnIdle = FALSE;
          NLME_SetPollRate(DEVICE_POLL_RATE);
        break;
      default:
        break;
    #endif // defined (OTA_CLIENT) && (OTA_CLIENT == TRUE)
    // ----------------------- ZDO_COORDINATOR or Device -------------------
    #ifdef ZDO_COORDINATOR  // Coordinator!
     * @fn      zclSampleSw_processZDOMgs
     * @brief   Process ZDO Message
      switch ( pMsg->clusterID )
        case Device_annce:
          zclSampleSw_OnOffTestAddr = pMsg->srcAddr.addr.shortAddr;
          HalLcdWriteStringValue("Node:", pMsg->srcAddr.addr.shortAddr, 16, 3);
          HalLcdWriteString("On/Off Test...", 4);
        break;
        default:
        break;
     * @fn      zclSampleSw_OnOffTest
     * @brief   Send On/Off Command to device
        afAddrType_t destAddr;
        static uint8 txID = 0;
        static bool  on   = true;
        destAddr.endPoint = SAMPLESW_ENDPOINT;
        destAddr.addrMode = afAddr16Bit;
        destAddr.addr.shortAddr = zclSampleSw_OnOffTestAddr;
        if(on)
          HalLcdWriteString("Command: ON", 4);
          zclGeneral_SendOnOff_CmdOn(SAMPLESW_ENDPOINT,
                                     &destAddr,
                                     TRUE,
                                     txID++);
        else
          HalLcdWriteString("Command: OFF", 4);
          zclGeneral_SendOnOff_CmdOff(SAMPLESW_ENDPOINT,
                                      &destAddr,
                                      TRUE,
                                      txID++);
        on = !on;
    #else  // Device!
     * @fn      zclSampleSw_DeviceAnnce
     * @brief   Broadcast "Annce"
        ZDP_DeviceAnnce( NLME_GetShortAddr(), NLME_GetExtAddr(),
                         ZDO_Config_Node_Descriptor.CapabilityFlags, 0 );
     * @fn      zclSampleSw_OnOffCB
     * @brief   ZCL Command - On/Off
        if(cmd == COMMAND_ON)
          HalLcdWriteString("Set ON", 4);
          HalLedSet(HAL_LED_ALL, HAL_LED_MODE_ON);
        else if(cmd == COMMAND_OFF)
          HalLcdWriteString("Set OFF", 4);
          HalLedSet(HAL_LED_ALL, HAL_LED_MODE_OFF);
    #endif
     * @fn      zclSampleSw_InitUart
     * @brief   init. and open Uart
      halUARTCfg_t uartConfig;
      /* UART Configuration */
      uartConfig.configured           = TRUE;
      uartConfig.baudRate             = HAL_UART_BR_115200;
      uartConfig.flowControl          = FALSE;
      uartConfig.flowControlThreshold = 0;
      uartConfig.rx.maxBufSize        = ZCLSAMPLESW_UART_BUF_LEN;
      uartConfig.tx.maxBufSize        = 0;
      uartConfig.idleTimeout          = 6;
      uartConfig.intEnable            = TRUE;
      uartConfig.callBackFunc         = zclSampleSw_UartCB;
      /* Start UART */
      HalUARTOpen(HAL_UART_PORT_0, &uartConfig);
     * @fn      zclSampleSw_UartCB
     * @brief   Uart Callback
      uint16 destNwkAddr = 0;
      uint8 rxLen = Hal_UART_RxBufLen(HAL_UART_PORT_0);
      if(rxLen < 6) return;
      HalUARTRead(HAL_UART_PORT_0  ,  uartBuf , rxLen);
      uartBuf[1] = rxLen;  // �����Ϣ��֧��, ԭ�ⲻ������.
      switch(uartBuf[0]) {
      case 0xFC:
        uartBuf[2] = 0xFF;
        uartBuf[3] = 0xFF;
        // ��ѯ�豸����: FC 06 0000 01 00
        if (1==uartBuf[4] && 0==uartBuf[5]) {
          uartBuf[6] = DEVICE_LOGICAL_TYPE;
          uartBuf[1] = 7;
        // ��ѯ PanId:   FC 06 0000 02 00
        else if (2==uartBuf[4] && 0==uartBuf[5]) {
          osal_memcpy(uartBuf+6, &_NIB.nwkPanId, sizeof(uint16));
          uartBuf[1] = 8;
        // ��ѯ�ŵ�:     FC 06 0000 03 00
        else if (3==uartBuf[4] && 0==uartBuf[5]) {
          uartBuf[6] = _NIB.nwkLogicalChannel;
          uartBuf[1] = 7;
        // ��ѯ�̵�ַ:   FC 06 0000 04 00
        else if (4==uartBuf[4] && 0==uartBuf[5]) {
          osal_memcpy(uartBuf+6, &_NIB.nwkDevAddress, sizeof(uint16));
          uartBuf[1] = 8;
        // ��ѯmac:      FC 06 0000 05 00
        else if (5==uartBuf[4] && 0==uartBuf[5]) {
          osal_memcpy(uartBuf+6, aExtendedAddress, Z_EXTADDR_LEN);
          uartBuf[1] = 6 + Z_EXTADDR_LEN;
        // ��ѯ���豸�̵�ַ: FC 06 0000 06 00
        else if (6==uartBuf[4] && 0==uartBuf[5]) {
          osal_memcpy(uartBuf+6, &_NIB.nwkCoordAddress, sizeof(uint16));
          uartBuf[1] = 8;
        // ��ѯ���豸mac:      FC 06 0000 07 00
        else if (7==uartBuf[4] && 0==uartBuf[5]) {
          osal_memcpy(uartBuf+6, &_NIB.nwkCoordExtAddress, Z_EXTADDR_LEN);
        // �ָ���������:  FC 07 0000 08 01 03
        else if (7==uartBuf[1] && 8==uartBuf[4] && 1==uartBuf[5] && 3==uartBuf[6]) {
          // �μ�: https://e2echina.ti.com/question_answer/wireless_connectivity/zigbee/f/104/p/131709/368670
          // �����Ҫ�úò�����
          bdb_resetLocalAction();
        // ��ѯ�豸״̬:       FC 06 0000 08 00
        else if (8==uartBuf[4] && 0==uartBuf[5]) {
          uartBuf[6] = devState;
          uartBuf[1] = 7;
        // reboot:        FC 06 0000 09 01
        else if (9==uartBuf[4] && 1==uartBuf[5]) {
          SystemReset();
        // ��ѯ��չpanId:      FC 06 0000 0A 00
        else if (0x0A==uartBuf[4] && 0==uartBuf[5]) {
          osal_memcpy(uartBuf+6, &_NIB.extendedPANID, Z_EXTADDR_LEN);
        break;
      case 0xFE:
        if (1==uartBuf[4]) {
          uartBuf[4] = 0x81;
          destNwkAddr = (uartBuf[3] << 8) | uartBuf[2];
          if ( 0xFF==uartBuf[3] && (0xFF==uartBuf[2] || 0xFD==uartBuf[2] || 0xFC==uartBuf[2]))
            zclSampleSw_AF_Broadcast(destNwkAddr, CLUSTER_BROADCAST, rxLen, uartBuf);
          else zclSampleSw_AF_P2P(destNwkAddr, CLUSTER_P2P, rxLen, uartBuf);
        // todo: ��Щ������Э�������е�, ��Ҫ����
        // ������: FE 07 00 00 02 03 %02X
        else if (7==uartBuf[1] && 2==uartBuf[4] ) {
          uartBuf[4] = 0x82;
          NLME_PermitJoiningRequest(uartBuf[6]);
        // ���������Щ���. ���02 ��ʲô��˼��������2�� ������0��?
        // ��ѯЭ����mac:  FE 07 00 00   00 00 02. ����֮��. �Ժ��������
        else if (7==uartBuf[1] && 0==uartBuf[4] && 2==uartBuf[6]) {
          // ��Ҫ֪�����з���ʲô. Ȼ����Ӧ����.
          // ���Է��� devState, Ҳ���Է��� ���豸mac��ַ
        break;
     * @fn      zclSampleSw_AF_P2P
     * @brief   P2P
     * @param   destNwkAddr - destination address
     *          cid - cluster id
     *          len - data length
     *          data - data
     * @return  none
                                   uint16 cid,
      afAddrType_t dstAddr;
      static uint8 transferId = 0;
      /* Destination */
      dstAddr.addrMode = afAddr16Bit;
      dstAddr.addr.shortAddr = destNwkAddr;
      dstAddr.endPoint = SAMPLESW_ENDPOINT;
      /* Transfer id */
      transferId++;
      /* Send */
      AF_DataRequest( &dstAddr, &sampleSw_TestEp,
                      cid,
                      len, data,
                      &transferId,
                      AF_DISCV_ROUTE, AF_DEFAULT_RADIUS );
     * @fn      zclSampleSw_AF_Broadcast
     * @brief   Broadcase
     * @param   cid - cluster id
     *          len - data length
     *          data - data
     * @return  none
      /* Destination */
      dstAddr.addrMode = afAddrBroadcast;
      /* Transfer id */
      transferId++;
      /* Send */
                      cid,
                      len, data,
                      &transferId,
                      AF_TX_OPTIONS_NONE, AF_DEFAULT_RADIUS );
     * @fn      zclSampleSw_AF_Groupcast
     * @brief   Groupcast
     * @param   groupId - group id
     *          cid - cluster id
     *          len - data length
     *          data - data
     * @return  none
                                         uint16 cid,
      /* Destination */
      dstAddr.addrMode = afAddrGroup;
      dstAddr.addr.shortAddr = groupId;
      /* Transfer id */
      transferId++;
      /* Send */
                      cid,
                      len, data,
                      &transferId,
     * @fn      zclSampleSw_AF_RxProc
     * @brief   Process incoming message
     * @param   MSGpkt - incoming message
     * @return  none
      uint8 last = MSGpkt->cmd.Data[MSGpkt->cmd.DataLength-1];
      switch( MSGpkt->clusterId )
      case CLUSTER_P2P:
        HalLcdWriteStringValue( "P2P", last, 16, 3);
        HalLedSet(HAL_LED_1, HAL_LED_MODE_TOGGLE);
      break;
      case CLUSTER_BROADCAST:
        HalLcdWriteStringValue( "BROADCAST", last, 16, 4);
        HalLedSet(HAL_LED_2, HAL_LED_MODE_TOGGLE);
      break;
      case CLUSTER_GROUPCAST:
        HalLcdWriteStringValue( "GROUPCAST", last, 16, 4);
        HalLedSet(HAL_LED_3, HAL_LED_MODE_TOGGLE);
      break;
      default:
      break;
    应该没有两个设备要入网。 一个是协调器,一个是路由。
    刚开始路由想要入网,但入网没打开; 所以没有设备加入进来。
    后来打开了入网,就变成了有很多设备加入进来了。
    改了一些:
    大的改动是这一句,
     0,
    这个:
    以前设的是null。
    主文件放在附件中。 (主要是想在例程上加上透传功能)。
  • 你測試源程序不做任何修改會有同樣的問題嗎?
  • 建议你使用例程测试一下。
  • 使用例程不会用同样问题。所以很奇怪怎么会这样
  • 有點被你搞混了,能不能請你再描述一下你的問題
  • 问题是: 组网没打开,设备连接不上;组网打开后,设备可以连上,但明明只有一个设备,显示出连接上了20多个设备。查看mac,其mac地址都一样。 抓包文件如上,主要代码如上。如需要,可附上整个代码。
  • 你的抓包檔看來每次设备加入就是發出一個Device Announcement,你是再哪裡看到显示出连接上了20多个设备?
  • 可以看到随着程序运行,左下设备数量在不停猛增。 而实际上我只有2个设备。 也可以看到不停有BeaconRequest发出
  • 你那些节点的ieee address都是一樣的所以是同一個
