Other Parts Discussed in Thread: CC2538, Z-STACK
各位TI工程师:
大家好!最近在调试zigbee3.0的协调器(CC2538),直接使用TI例程修改为协调器,编译软件为:IAR Embedded Workbench for Arm 8.32.1,仿真器用的是XDS100V3.0。软件编译没问题,但是在下载仿真时出现如下警告:
Wed Feb 20, 2019 14:24:08: IAR Embedded Workbench 8.32.1 (C:\Program Files (x86)\IAR Systems\Embedded Workbench
8.2\arm\bin\armproc.dll)
Wed Feb 20, 2019 14:24:08: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm
\config\debugger\TexasInstruments\CC2538.dmac
\config\flashloader\TexasInstruments\FlashCC2538.mac
Wed Feb 20, 2019 14:24:09: No SWO port found, SWO disabled
Wed Feb 20, 2019 14:24:09: Connecting to TI XDS100v3 ( Probe no: 12345678 ) COM[--/--]
Wed Feb 20, 2019 14:24:10: TI XDS ARM, device revision: 0x00000001, big endian: false, cache: false, board
revision: 0x00000000, driver revision: 0x0B020200
Wed Feb 20, 2019 14:24:10: Initial reset was performed
Wed Feb 20, 2019 14:24:11: 416 bytes downloaded and verified (6.55 Kbytes/sec)
Wed Feb 20, 2019 14:24:11: Loaded debugee: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config
\flashloader\TexasInstruments\FlashCC2538RAM32K.out
Wed Feb 20, 2019 14:24:11: Target reset
Wed Feb 20, 2019 14:24:50: Unloaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm
Wed Feb 20, 2019 14:24:50: Downloaded E:\zigbee\Z-Stack30_cc2538_CoordinatorDemo\Projects\zstack\HomeAutomation
\SampleLight\CC2538\Coordinator\Exe\SampleLight.out to flash memory.
Wed Feb 20, 2019 14:24:50: 524256 bytes downloaded into FLASH (12.27 Kbytes/sec)
Wed Feb 20, 2019 14:25:06: 524256 bytes downloaded into FLASH and verified (9.17 Kbytes/sec)
Wed Feb 20, 2019 14:25:06: Warning:
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D000, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D001, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D008, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D009, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D00A, target byte: 0x08, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D00B, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D00C, target byte: 0xF8, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D00D, target byte: 0x07, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D010, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D011, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D014, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D015, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D020, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D021, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D022, target byte: 0x08, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D023, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D024, target byte: 0x55, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D025, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D030, target byte: 0xC4, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D031, target byte: 0x80, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D032, target byte: 0xAF, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D033, target byte: 0x05, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D034, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D035, target byte: 0x4B, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D036, target byte: 0x12, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D037, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D038, target byte: 0x03, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D039, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D03A, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D03B, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D03C, target byte: 0xFD, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D03D, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D048, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D04C, target byte: 0x55, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D04D, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D04E, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D04F, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D050, target byte: 0xFD, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D051, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D05C, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D060, target byte: 0x87, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D061, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D062, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D063, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D064, target byte: 0xFD, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D065, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D070, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D074, target byte: 0x35, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D075, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D076, target byte: 0x04, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D077, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D078, target byte: 0xEB, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D079, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D084, target byte: 0xE8, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D085, target byte: 0x03, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D086, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D087, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D088, target byte: 0x25, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D089, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D08A, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D08B, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D08C, target byte: 0x62, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D08D, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D098, target byte: 0x64, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D099, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D09C, target byte: 0x26, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D09D, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D09E, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D09F, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0A0, target byte: 0x62, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0A1, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0AC, target byte: 0x64, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0AD, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0B0, target byte: 0x27, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0B1, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0B2, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0B3, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0B4, target byte: 0xB7, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0B5, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0C0, target byte: 0xB8, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0C1, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0C4, target byte: 0x28, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0C5, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0C6, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0C7, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0C9, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0D4, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0D8, target byte: 0x29, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0D9, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0DA, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0DB, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0DD, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0E8, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0EC, target byte: 0x84, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0ED, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0EE, target byte: 0x04, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0EF, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0F0, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0F1, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0FC, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0FD, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0FE, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D0FF, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D100, target byte: 0x86, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D101, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D102, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D103, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D104, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D105, target byte: 0x03, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D110, target byte: 0x04, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D114, target byte: 0x2A, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D115, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D116, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D117, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D119, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D124, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D128, target byte: 0x2B, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D129, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D12A, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D12B, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D12C, target byte: 0x04, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D12D, target byte: 0x03, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D138, target byte: 0x07, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D13C, target byte: 0x2C, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D13D, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D13E, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D13F, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D140, target byte: 0x1B, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D141, target byte: 0x03, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D14C, target byte: 0x1E, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D150, target byte: 0x2D, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D151, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D152, target byte: 0x08, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D153, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D154, target byte: 0x55, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D155, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D160, target byte: 0xC4, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D161, target byte: 0x80, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D162, target byte: 0xAF, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D163, target byte: 0x05, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D164, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D165, target byte: 0x4B, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D166, target byte: 0x12, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D167, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D168, target byte: 0x2E, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D169, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D16A, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D16B, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D16D, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D178, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D17C, target byte: 0x2F, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D17D, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D17E, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D17F, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D180, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D181, target byte: 0x03, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D18C, target byte: 0x05, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D190, target byte: 0x30, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D191, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D192, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D193, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D194, target byte: 0x1B, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D195, target byte: 0x03, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1A0, target byte: 0x1E, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1A4, target byte: 0x31, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1A5, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1A6, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1A7, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1A9, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1B4, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1B8, target byte: 0x32, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1B9, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1BA, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1BB, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1BC, target byte: 0xFD, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1BD, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1C8, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1CC, target byte: 0x33, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1CD, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1CE, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1CF, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1D0, target byte: 0xFD, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1D1, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1DC, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1E0, target byte: 0x34, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1E1, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1E2, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1E3, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1E4, target byte: 0x07, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1E5, target byte: 0x03, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1F0, target byte: 0x0A, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1F4, target byte: 0x36, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1F5, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1F6, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1F7, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1F8, target byte: 0xFD, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D1F9, target byte: 0x02, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D204, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D208, target byte: 0x38, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D209, target byte: 0x00, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Verify error at address 0x0027D20A, target byte: 0x01, byte in file: 0xFF
Wed Feb 20, 2019 14:25:06: Warning: Too many verify errors, only the first 200 are displayed
Wed Feb 20, 2019 14:25:09: Warning: There were warnings during download, see Log Window
Wed Feb 20, 2019 14:25:09: Loaded debugee: E:\zigbee\Z-Stack30_cc2538_CoordinatorDemo\Projects\zstack
\HomeAutomation\SampleLight\CC2538\Coordinator\Exe\SampleLight.out
Wed Feb 20, 2019 14:25:09: Target reset
Wed Feb 20, 2019 14:25:10: Set SYS_CTRL:EMUOVR Register
Wed Feb 20, 2019 14:25:10: There was 1 warning during the initialization of the debugging session.
Wed Feb 20, 2019 14:25:18: IAR Embedded Workbench 8.32.1 (C:\Program Files (x86)\IAR Systems\Embedded Workbench
不知会不会有什么影响?各位工程师有没有遇见相似的警告,这是什么造成的?怎么处理?请赐教!谢谢各位!
