Home 1.2.2
1.我们想发送自己的数据,是不是发送的参数有问题
单播到目的地址,这个设置是正确的
zclSampleLight_OnOff=0x10;
endPointDesc_t *epDesc;
epDesc = afFindEndPointDesc( SAMPLESW_ENDPOINT );
AF_DataRequest( (afAddrType_t *)&zclSampleLight_DstAddr, epDesc, ZCL_CLUSTER_ID_GEN_BASIC, 1, (uint8 *)&zclSampleLight_OnOff,
&zcl_TransID, AF_TX_OPTIONS_NONE, AF_DEFAULT_RADIUS );
2.接收端case ZCL_INCOMING_MSG:打断点,收不到数据
char theMessageData[] = "Hello World"; if ( AF_DataRequest( &GenericApp_DstAddr, &GenericApp_epDesc, GENERICAPP_CLUSTERID, (byte)osal_strlen( theMessageData ) + 1, (byte *)&theMessageData, &GenericApp_TransID, AF_DISCV_ROUTE, AF_DEFAULT_RADIUS ) == afStatus_SUCCESS )
