CC2538用XDS100V3.0仿真下载程序的问题
Other Parts Discussed in Thread: CC2538, Z-STACK
TI工程师们:
大家好!最近用CC2538的“Z-Stack 3.0.2”协议栈开发产品,直接用官网下载的例程。修改“hal_board_cfg.h”文件中的“#ifndef HAL_LCD #define HAL_LCD FALSE//TRUE #endif”,将HAL_LCD宏定义由“TRUE”改为“FALSE”。再重新编译,没有错误。再下载并仿真会出现如下警告:
之后全速运行,程序不会正常运行。相应的Debug log如附件。
Fri Jul 26, 2019 13:50:41: IAR Embedded Workbench 8.32.1 (C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\bin\armproc.dll)
Fri Jul 26, 2019 13:50:41: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config\debugger\TexasInstruments\CC2538.dmac
Fri Jul 26, 2019 13:50:41: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\TexasInstruments\FlashCC2538.mac
Fri Jul 26, 2019 13:50:41: No SWO port found, SWO disabled
Fri Jul 26, 2019 13:50:41: Connecting to TI XDS100v3 ( Probe no: 12345678 ) COM[--/--]
Fri Jul 26, 2019 13:50:42: TI XDS ARM, device revision: 0x00000001, big endian: false, cache: false, board revision: 0x00000000, driver revision: 0x0B020200
Fri Jul 26, 2019 13:50:43: Initial reset was performed
Fri Jul 26, 2019 13:50:43: 416 bytes downloaded and verified (6.45 Kbytes/sec)
Fri Jul 26, 2019 13:50:43: Loaded debugee: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\TexasInstruments\FlashCC2538RAM32K.out
Fri Jul 26, 2019 13:50:43: Target reset
Fri Jul 26, 2019 13:51:19: Unloaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\TexasInstruments\FlashCC2538.mac
Fri Jul 26, 2019 13:51:19: Downloaded E:\zigbee\Z-Stack302_2538_Coordinator\Projects\zstack\HomeAutomation\Sample\CC2538\Coordinator\Exe\SampleSwitch.out to flash memory.
Fri Jul 26, 2019 13:51:19: 524256 bytes downloaded into FLASH (13.53 Kbytes/sec)
Fri Jul 26, 2019 13:51:33: 524256 bytes downloaded into FLASH and verified (10.14 Kbytes/sec)
Fri Jul 26, 2019 13:51:33: Warning:
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D000, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D001, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D008, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D009, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D00A, target byte: 0x08, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D00B, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D00C, target byte: 0xF8, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D00D, target byte: 0x07, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D010, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D011, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D014, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D015, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D020, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D021, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D022, target byte: 0x08, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D023, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D024, target byte: 0xD3, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D025, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D030, target byte: 0xF7, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D031, target byte: 0x27, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D032, target byte: 0x3F, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D033, target byte: 0x19, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D034, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D035, target byte: 0x4B, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D036, target byte: 0x12, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D037, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D038, target byte: 0x03, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D039, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D03A, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D03B, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D03C, target byte: 0xFD, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D03D, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D048, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D04C, target byte: 0x55, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D04D, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D04E, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D04F, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D050, target byte: 0xFD, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D051, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D05C, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D060, target byte: 0x87, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D061, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D062, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D063, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D064, target byte: 0xFD, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D065, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D070, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D074, target byte: 0x35, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D075, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D076, target byte: 0x04, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D077, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D078, target byte: 0xEB, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D079, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D084, target byte: 0xE8, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D085, target byte: 0x03, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D086, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D087, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D088, target byte: 0x25, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D089, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D08A, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D08B, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D08C, target byte: 0x62, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D08D, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D098, target byte: 0x64, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D099, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D09C, target byte: 0x26, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D09D, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D09E, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D09F, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0A0, target byte: 0x62, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0A1, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0AC, target byte: 0x64, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0AD, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0B0, target byte: 0x27, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0B1, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0B2, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0B3, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0B4, target byte: 0xB7, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0B5, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0C0, target byte: 0xB8, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0C1, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0C4, target byte: 0x28, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0C5, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0C6, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0C7, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0C9, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0D4, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0D8, target byte: 0x29, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0D9, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0DA, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0DB, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0DD, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0E8, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0EC, target byte: 0x84, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0ED, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0EE, target byte: 0x04, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0EF, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0F0, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0F1, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0FC, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0FD, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0FE, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D0FF, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D100, target byte: 0x86, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D101, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D102, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D103, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D104, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D105, target byte: 0x03, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D110, target byte: 0x04, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D114, target byte: 0x2A, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D115, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D116, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D117, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D119, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D124, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D128, target byte: 0x2B, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D129, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D12A, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D12B, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D12C, target byte: 0x04, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D12D, target byte: 0x03, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D138, target byte: 0x07, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D13C, target byte: 0x2C, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D13D, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D13E, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D13F, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D140, target byte: 0x1B, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D141, target byte: 0x03, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D14C, target byte: 0x1E, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D150, target byte: 0x2D, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D151, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D152, target byte: 0x08, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D153, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D154, target byte: 0xD3, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D155, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D160, target byte: 0xF7, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D161, target byte: 0x27, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D162, target byte: 0x3F, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D163, target byte: 0x19, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D164, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D165, target byte: 0x4B, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D166, target byte: 0x12, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D167, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D168, target byte: 0x2E, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D169, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D16A, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D16B, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D16D, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D178, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D17C, target byte: 0x2F, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D17D, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D17E, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D17F, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D180, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D181, target byte: 0x03, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D18C, target byte: 0x05, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D190, target byte: 0x30, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D191, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D192, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D193, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D194, target byte: 0x1B, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D195, target byte: 0x03, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1A0, target byte: 0x1E, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1A4, target byte: 0x31, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1A5, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1A6, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1A7, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1A9, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1B4, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1B8, target byte: 0x32, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1B9, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1BA, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1BB, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1BC, target byte: 0xFD, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1BD, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1C8, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1CC, target byte: 0x33, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1CD, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1CE, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1CF, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1D0, target byte: 0xFD, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1D1, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1DC, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1E0, target byte: 0x34, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1E1, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1E2, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1E3, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1E4, target byte: 0x07, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1E5, target byte: 0x03, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1F0, target byte: 0x0A, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1F4, target byte: 0x36, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1F5, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1F6, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1F7, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1F8, target byte: 0xFD, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D1F9, target byte: 0x02, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D204, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D208, target byte: 0x38, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D209, target byte: 0x00, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Verify error at address 0x0027D20A, target byte: 0x01, byte in file: 0xFF
Fri Jul 26, 2019 13:51:33: Warning: Too many verify errors, only the first 200 are displayed
Fri Jul 26, 2019 13:51:39: Warning: There were warnings during download, see Log Window
Fri Jul 26, 2019 13:51:39: Loaded debugee: E:\zigbee\Z-Stack302_2538_Coordinator\Projects\zstack\HomeAutomation\Sample\CC2538\Coordinator\Exe\SampleSwitch.out
Fri Jul 26, 2019 13:51:39: Target reset
Fri Jul 26, 2019 13:51:39: Set SYS_CTRL:EMUOVR Register
Fri Jul 26, 2019 13:51:39: There was 1 warning during the initialization of the debugging session.
这是我遇到的非常严重的一个BUG!希望TI工程师们和相关遇到过这个问题的各位朋友指点!谢谢!
