1、我的设备不预定义NV_RESTORE,想让终端设备能一直入网,所以需要让协调器或者路由器一直允许入网,我调用如下语句:NLME_PermitJoiningRequest(255);发现经过254秒后,让然会禁止其他设备入网,请问怎么更改才能让设备一直入网?在zstack 2.5.1中执行NLME_PermitJoiningRequest(255);会允许设备一直入网。
2、分布式网络是否可以使用zgApsUseExtendedPANID建立、加入网络?如果可以请问该如何配置实现?
This network type can be formed by network-forming router devices. In this network topology, all the nodes have the ability to open the network for joining and any router device can deliver the network key to a joining device. The network key will be encrypted at APS layer with a Default Distributed Global key (detailed in Distributed Security Global Link Key). This network key will be delivered via an APS Transport Key Command in which the TC address will be set to 0xFFFFFFFFFFFFFFFF, which tells the joining device that it is joining a distributed security network. The application can consult the value of AIB_apsTrustCenterAddress to see if it has joined a distributed network.
